    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • CadFatherC
      CadFather
      ..amazing, Fredo. ๐Ÿ˜ฒ
      • boofredlayB
        boofredlay
        This is absolutely beautiful, thank you.
        • urgenU
          urgen
          ...cool! ๐Ÿ‘
          --pupil forever...------
          • W
            watkins
            Dear Fredo,
            This is how it's done in Inventor
            and variable
            Kind regards,
            Bob
            • ely862meE
              ely862me
              ๐Ÿ˜ฒ
              Another masterpiece!!Works like a charm!
              Thank you very much!
              Elisei
              Elisei (sketchupper)
              Come and See EliseiDesign
              • fredo6F
                @watkins said:
                Dear Fredo,
                and variable
                Kind regards,
                Bob
                Apparently Inventor does just fillet, whether fix or variable offset. I have not seen the 3-direction rounding of corners. And the profile seems to be always an arc of circle.
                  remus
                  What a nice surprise ๐Ÿ˜„ Once again, thank you fredo, your hard work is always appreciated.
                  • ely862meE
                    ely862me
                    only one small thing .. when making this fillet some holes becomes filled ..can this be fixed ?
                    • fredo6F
                      Actually, it is Sketchup that automatically generate the faces. RoundCorner algorithm does not 'see' them.
                      I need to see if I can do something, but no guarantee!
                      • PixeroP
                        Pixero
                        It would be great if the round corner could be turned off and just turn it on before render.
                        • W
                          watkins
                          Fredo,
                          This gives more details on the fillet and chamfer options for Inventor
                          http://www2.ivcc.edu/perez/Placed%20Features.pdf
                          Regards,
                          Bob
                          • W
                            watkins
                            Dear Fredo,
                            I forgot to say that I think you are absolutely brilliant! Thank you for all your hard work in not only writing these scripts, but documenting them so well. You really are a very generous chap.
                            Kind regards,
                            Bob
                            • fredo6F
                              @watkins said:
                              Fredo,
                              Regards,
                              Bob
                              Thanks. Interesting, but my first reaction would be that I understand why some of you prefer Sketchup, which is so much natural to use for this type of shapes (except maybe for the variable radius filleting).
                              • W
                                watkins
                                For the mechanically minded, RoundCorner is just perfect for all those radiussed and chamfered features. Setting the offset equal to the radius on the end of a pin will round the end of the pin beautifully.
                                Using RoundCorner.skp
                                • Bob JamesB
                                  Bob James
                                  Just loaded this plugin for the first time. I drew a circle and, using the default parameters, clicked to proceed and got this ๐Ÿ˜ฎ
                                  Not sure what it is, but it sure neat ๐Ÿ˜‰ Black hole generator maybe. ๐Ÿ’ญ
                                  Now on to more serious testing. ๐Ÿ˜Ž
                                  • Jean-FrancoJ
                                    Jean-Franco
                                    you have to change the default parameter (1000mm) to a smaller value or draw a bigger circle.
                                    Jean-Franco
                                    • Bob JamesB
                                      Bob James
                                      Yes, I knew that but just wanted to see what would happen with the randomly sized circle I drew. ๐Ÿ˜„
                                      Still a fascinating result!
                                      • fredo6F
                                        Actually creating black holes and big bang effects was the primary goal of the plugin. It is just a side effect that it sometimes round edges and corners, but promised, I'll fix this inconvenience:D ๐Ÿ˜„
                                        • Bob JamesB
                                          Bob James
                                          Fix it? FIX IT??? It's perfect already ๐Ÿคฃ
                                            ddcddc
                                            This is great stuff! thank you so much for your effort!
                                            • 74
                                            • 75
                                            • 4 / 75
