    Model Aircraft Plans
    22 Posts 7 Posters 4.4k Views 7 Watching
    • P
      Physicsguy1
      The best part about using SketchUp to create the plans is that you can just use the intersect tool on any model, and you have the plans πŸ˜„. You can snag a model off the warehouse or design your own and you'll have the plans in minutes.
      • Mike LuceyM
        Mike Lucey
        Wow, Physicsguy, that took some time.
        I think you may have the makings there for a good tutorial also. BTW, have you cut all these parts out yet? If not check out the PhlatPrinter post I made recently. Maybe you could get one of the RC modellers to do the job for you.
        Mike
        • P
          Physicsguy1
          Haven't cut anything yet, but I have all the supplies. I'll do a tutorial for this, because this is pretty fun. I might make a peanut scale version so I can find the best center of gravity for flight. What would someone want to see in the tutorial? Any ideas? There will probably be some better methods out there...
          • P
            Physicsguy1
            Here is a VERY basic tutorial: tutorial.skp
            Here is yet another optimized version of the plans:printoutplans.skp
              My 'Slicer.rb' tool could also be used to quickly slice up a model's body/wings/tail etc
              • Mike LuceyM
                Mike Lucey
                Thanks PS,
                What I was suggesting a general 'This Is What I'm At' tut idea. And this is what you have started doing, thanks.
                I lot of tuts show a particular way of making something but I think members would also be interested in seeing more general work flows. I hope I have explained what I have in mind.
                Mike
                • P
                  Physicsguy1
                  All I am getting is that you want something that explains the workflow, right?
                  • Mike LuceyM
                    Mike Lucey
                    PG,
                    I think it would be great to see more about, how folks go about using SketchUp for their work / hobbies. This is the first time I've seen SU being used for what you are doing. I think a lot or members find it interesting. Things like how did you start of the project, rough ups, etc.
                    Mike
                    • P
                      Physicsguy1
                      I will probably get to work on the model itself within 7 days(I know I said yesterday). The remote control portion might be troublesome, so don't expect it to be working soon.
                        MKG
                        Looks great. Apart from the wing bracing (and this is from my aeromodelling youth, which is some time ago)you might want to think about a bit more fuselage bracing too. After all, there's an engine to go in there (lots of torque), a fuel tank, an RC receiver and a couple (or more) servos. That last lot might not weigh too much, but they'll put a large inertial strain on the airframe in a tight turn.
                        The centre of gravity (if I remember rightly) should be on the centre line of the wings when the model is fully loaded, so I think it makes sense to have the fuel tank right on that spot.
                        • P
                          Physicsguy1
                          Thank you for the advice. I thought that the CG had to be at the epicenter of the peak point in the wing camber, though
                            11zulu
                            Hiya Mate
                            You might want to check out these for tips:
                            Site not found Β· DreamHost
                            The owner of this domain has not yet uploaded their website.
                            (waves.ky)
                            http://www.rcgroups.com/forums/showthread.php?t=920416
                            pages 1 to 3 and also
                            http://www.rcgroups.com/forums/showthread.php?t=920416&page=10
                            A step by step building a F4
                            http://www.rcgroups.com/forums/showthread.php?t=947842
                            A step by step:
                            [you will have to signup to see the pictures!]
                            http://www.phlatforum.com/viewtopic.php?f=73&t=129
                            Another Step by Step - the best I can find so far is:
                            http://www.kartonbau.de/wbb2/thread.php?threadid=16473
                            Finally on Youtube something I will be trying out [as I'm a lazy so and so...]:
                            How to create 3D planes from 3-views
                            http://www.youtube.com/watch?v=1FJi1nmVGKg
                            Good Luck!
                            • P
                              Physicsguy1
                              Thank you!
                              Right now I'm going to try to add reinforcements the fuselage and wings, and also try to fit in some alignment spars so I don't end up with 'a blob'. I've also derived some modeling tips from Model Aviation, a magazine popular among members of the aero-modeling community.
                              I will also be working on a flying wing design before I get to work on the original design, so I can test my modeling skills. I'll post some plans for that soon.
                              As for the original, the plans are itching to be printed, but I want to see if I can get enlarged versions of the plans scene in the model, because when they are not of the same scale as the model components, things will be VERY misaligned.
                              • P
                                Physicsguy1
                                Does anyone know if there is a way to align the view so that the print-out component profile dimensions are equal to those in reality? For example; If you laid out a rectangle in SketchUp, and the dimensions were 1"x1", how would i determine the right view so that the square turns out 1"x1" on printing paper? Is there a CAD program capable of this?
                                  http://forums.sketchucation.com/viewtopic.php?p=68460#p68460 is one way... search for 'print to scale' - there are lots of helpful suggestions...
