    [Plugin] Skin.rb
    237 Posts 66 Posters 159.5k Views 66 Watching
      christian_dl
      @watkins said:
      Dear Christian,
      Your skin-26 doesn't seem to be compatible with the icons for skin22. Only 2 of the 5 icons appear. Could you please produce a folder of icons which are compatible with your script?
      Regards,
      Bob
      Dear Bob,
      As I found out.
      The v22 is the only one with a 5 icons Toolbar.
      Also in this Version there is no Settingdialog. I think thats the Reason for the 5 Icons.
      This Version also works within Groups and Components.
      All later Version have a three icons Toolbar and the Settings dialog.
      I don't know exactly why the Author of Skin changed this Behavior.
      Also he changed back to active_model.entitities. Why ever??
      With skin-26.rb i repair only the NamedOptions and changed back to active_model.active_entitities.
      Because on OSX, Skin doesn't work at all since v23.
      Because i'm not a mathematical genius i don't know very well about changes to the 3D Code.
      So If you satiesfied with v22, stay there.
      Best Regards
      Christian
      • utilerU Offline
        utiler
        good advice, Christian, Ta.
        Just Curious...
        • Bob JamesB Offline
          Bob James
          This was done with skin26 on MacPro. There's no smoothing and there's one icon not showing (but it works - preferences). On my iMac at home all three icons show.
          The Skin folder has four icons in it.
          Settings
          • ToboboT Offline
            Tobobo
            I want to know where to author of the script is?
            I hope we have(Edit: n't) scared him off? If i remember he was a young lad. (Maybe)
            Dyslexics rule KO!!
            Toby
            Philippians 4:13
              Bob James
              This is an older version of the Skin folder that has six icons in it that results in three being shown with skin26.rb.
              Note that "Smooth" is unavailable (no other choice).
              I might add that it took several tries to get the result shown (all sorts of weird results).
                christian_dl
                Dear Bob,
                Thats the same Result as on my Mac. Should be 6 Icons.
                As I found out. The ..L.png's are for Windows. The ..S.png's are for OSX.
                The Smoothing Option is not implemented, because the Author promised this for a Version 3. See a Posting in this Thread before.
                I compared the Code v22 with v26 and there are a lot of changes to the 3D Routines as well.
                It tooks time to re-think (understanding) the Code. On the other Hand it's a good Way learning Ruby. May be any-one-other in this Forum has a brief Knowledge to interpret the Changes.
                Regards Christian
                  Bob James
                  Regards Christian
                  Thanks for the investigation report: now it makes sense that only three icons show (and that I should be patient and wait for version 3 for smoothing).
                  • utilerU Offline
                    utiler
                    Speaking of the author, has anyone see the him around...? 😕
                    Just Curious...
                    • ToboboT Offline
                      Tobobo
                      I noticed his profile pic has changed recently.
                      Toby
                      Philippians 4:13
                      • ToboboT Offline
                        Tobobo
                        @tobobo said:
                        I hope we have scared him off?
                        You might want to add the word "not" in there. 😒
                        Yeah thanks Coen. I've changed the post but i can be so dense. 😳
                        Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through,
                        Toby
                        Philippians 4:13
                        • N Offline
                          NewOne
                          Sorry, what version is the final one? I tried Skin 2.2, but I remember that a few weeks ago I found a version that included som kind of line division in smaller segments.
                          Thank you.
                            lorca
                            Is this the same/different plugin by author D. Belvin?
                            • N Offline
                              NewOne
                              Have no idea... I just look for a "skin" plugin that works well.
                              • W Offline
                                windman
                                i tried to use this plugin to skin my rc sailplane fuselage formers. i could not manage it to work anyway.
                                then i draw simple squares on same axis to try. i tried to skin between two shapes, but nothing works. something i did should be wrong i guess.
                                • utilerU Offline
                                  utiler
                                  Or Kirill2008's wonders!!!
                                  [Plugin] 2 Faces + Path - http://forums.sketchucation.com/viewtopic.php?f=180&t=21658
                                  [Plugin] Blend - http://forums.sketchucation.com/viewtopic.php?f=180&t=21134
                                  Just Curious...
                                    It would appear that the author of the Skin plugin has moved on to other things or for whatever reason has no interest in making his plugin work correctly. Chris Fullmer has done an excellent plugin called Loft that does work and, I think, does a nicer job anyway. Why not just use it instead?
                                      aea
                                      my non works .
                                        I wonder what it is about this plugin that gives so many people such a hard time. It works just fine for me.
                                        • mitcorbM Offline
                                          mitcorb
                                          My copy of skin.rb seems to work fine.
                                          In my case, I have both skin.zip and skin23.zip in my plugins folder. There is a skin folder residing in the plugins folder that contains menu button png's.
                                          Again, in my case, I installed skin first, then I installed skin23. I guess this process has something to do with it.
                                          No guarantees.
                                          • utilerU Offline
                                            utiler
                                            Dave, I think it is because there are a number of versions right throughout the thread..... I too had trouble. So much so, i removed it all together.....
                                            Just Curious...
                                            • 11
                                            • 12
                                            • 6 / 12
