    [Plugin] Skin.rb
    237 Posts 66 Posters 205.7k Views 66 Watching
    • Bob JamesB
      Bob James
      skin26.rb on iMac: sooooo useful in ducting construction and all sorts of other things!
      Many, many thanks,christian_dl (and ThomThom) ๐Ÿ‘
      Also looking forward to Chris' ruby ๐ŸŽ‰
      • W
        watkins
        Dear Christian,
        Your skin-26 doesn't seem to be compatible with the icons for skin22. Only 2 of the 5 icons appear. Could you please produce a folder of icons which are compatible with your script?
        Regards,
        Bob
        • utilerU
          utiler
          I agree Bob. The skin ruby icons are the ones i always have trouble with...
          Just Curious...
          • mitcorbM
            mitcorb
            Something makes me believe that Architectboy is no longer involved with Sketchup, or Ruby. He may have moved on to other interests as he got older. He just didn't resign formally. He certainly showed that he has the talent.
            If one of the moderators cares to pursue this, I think I know his full name and what region he last resided. I otherwise will respect his privacy.
            mitcorb
            • C
              christian_dl
              @watkins said:
              Dear Christian,
              Regards,
              Bob
              Dear Bob,
              As I found out.
              The v22 is the only one with a 5 icons Toolbar.
              Also in this Version there is no Settingdialog. I think thats the Reason for the 5 Icons.
              This Version also works within Groups and Components.
              All later Version have a three icons Toolbar and the Settings dialog.
              I don't know exactly why the Author of Skin changed this Behavior.
              Also he changed back to active_model.entitities. Why ever??
              With skin-26.rb i repair only the NamedOptions and changed back to active_model.active_entitities.
              Because on OSX, Skin doesn't work at all since v23.
              Because i'm not a mathematical genius i don't know very well about changes to the 3D Code.
              So If you satiesfied with v22, stay there.
              Best Regards
              Christian
              • utilerU
                utiler
                good advice, Christian, Ta.
                Just Curious...
                • Bob JamesB
                  Bob James
                  This was done with skin26 on MacPro. There's no smoothing and there's one icon not showing (but it works - preferences). On my iMac at home all three icons show.
                  The Skin folder has four icons in it.
                  Settings
                  • ToboboT
                    Tobobo
                    I want to know where to author of the script is?
                    I hope we have(Edit: n't) scared him off? If i remember he was a young lad. (Maybe)
                    Dyslexics rule KO!!
                    Toby
                    Philippians 4:13
                    • Bob JamesB
                      Bob James
                      This is an older version of the Skin folder that has six icons in it that results in three being shown with skin26.rb.
                      Note that "Smooth" is unavailable (no other choice).
                      I might add that it took several tries to get the result shown (all sorts of weird results).
                      • C
                        christian_dl
                        Dear Bob,
                        Thats the same Result as on my Mac. Should be 6 Icons.
                        As I found out. The ..L.png's are for Windows. The ..S.png's are for OSX.
                        The Smoothing Option is not implemented, because the Author promised this for a Version 3. See a Posting in this Thread before.
                        I compared the Code v22 with v26 and there are a lot of changes to the 3D Routines as well.
                        It tooks time to re-think (understanding) the Code. On the other Hand it's a good Way learning Ruby. May be any-one-other in this Forum has a brief Knowledge to interpret the Changes.
                        Regards Christian
                        • Bob JamesB
                          Bob James
                          Regards Christian
                          Thanks for the investigation report: now it makes sense that only three icons show (and that I should be patient and wait for version 3 for smoothing).
                          • utilerU
                            utiler
                            Speaking of the author, has anyone see the him around...? ๐Ÿ˜•
                            Just Curious...
                            • ToboboT
                              Tobobo
                              I noticed his profile pic has changed recently.
                              Toby
                              Philippians 4:13
                              • ToboboT
                                Tobobo
                                @tobobo said:
                                I hope we have scared him off?
                                You might want to add the word "not" in there. ๐Ÿ˜’
                                Yeah thanks Coen. I've changed the post but i can be so dense. ๐Ÿ˜ณ
                                Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through, Must read posts through,
                                Toby
                                Philippians 4:13
                                • N
                                  NewOne
                                  Sorry, what version is the final one? I tried Skin 2.2, but I remember that a few weeks ago I found a version that included som kind of line division in smaller segments.
                                  Thank you.
                                  • L
                                    lorca
                                    Is this the same/different plugin by author D. Belvin?
                                    • N
                                      NewOne
                                      Have no idea... I just look for a "skin" plugin that works well.
                                      • W
                                        windman
                                        i tried to use this plugin to skin my rc sailplane fuselage formers. i could not manage it to work anyway.
                                        then i draw simple squares on same axis to try. i tried to skin between two shapes, but nothing works. something i did should be wrong i guess.
                                        • utilerU
                                          utiler
                                          Or Kirill2008's wonders!!!
                                          [Plugin] 2 Faces + Path - http://forums.sketchucation.com/viewtopic.php?f=180&t=21658
                                          [Plugin] Blend - http://forums.sketchucation.com/viewtopic.php?f=180&t=21134
                                          ๐Ÿ‘
                                          Just Curious...
                                            It would appear that the author of the Skin plugin has moved on to other things or for whatever reason has no interest in making his plugin work correctly. Chris Fullmer has done an excellent plugin called Loft that does work and, I think, does a nicer job anyway. Why not just use it instead?
                                            • 11
                                            • 12
                                            • 10 / 12
