    Hardware recommendations
    409 Posts 97 Posters 208.7k Views 97 Watching
      Sir
      I just had a new computor built for me so i could get a project done in time... did it, but had to take the tower home for some weekend work!
      Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3
            Processor: Intel(R) Pentium(R) 4 CPU 3.40GHz with HT tech
               Memory: 2046MB DDR3 corsair RAM
          Card name: NVIDIA GeForce 8400 GS 512.0 MB
      gotta say it works like a dream for SKP, but other things that can actually use multi procs are a bit slower... AutoCAD 2010 im looking at you you pice of RAM hoggin VM sucking piece of c***
      • W
        Wazzer
        Hi Guys My search for a new company laptop continues
        I would like your opinion on this note book for use with Sketchup and AutoCAD.
        Its a Lenovo W500
        Intel Core 2Duo T9400
        4GB Ram DDR3 1066Mhz
        ATI mobility FireGL V5700 512mb
        200gb Hard drive at 7200rpm
        I use it primarily for Designing Mechanical components with AutoCAD and Sketchup.
        Cheers
        Ben
          remus
          Looks good, although you might want to try and find out how well the graphics card will work with SU.
          • AnssiA
            Anssi
            It seems that if you must have a 15-inch Lenovo workstation, you are stuck with the FireGL - all the models with QuadroFX seem to be with 17-inch screens. You should definitely test it.
            Anssi
            • W
              Wazzer
              Thanks for the reply guys
              The problem is that the Lenovo notebooks with QuadroFX and 17inch screens are Massivly more expensive than the 15 inch notebooks. I mean they are about 4 times the price!!!
              They tell me we just dont have the budget for one.
              I am also concernd that the FireGL graphics card wont play nicely with sketchup
              Does anyone have any experience of these cards with SketchUp?
              I wont have access to one to run any tests on it until we order it and recieve it. This is obviously far too late if its no good.
              The problem is I am being pushed into making a decsion very soon and i cant afford to make a mistake.
              Cheers All
                remus
                The only info i can find on it is the following:
                FireGL v3100 - 128MB; Windows XP sp3
                Problems selecting and painting.
                Shadows display incorrectly.
                OpenGL version 6.14.10.7660
                2D driver version 6.14.10.6822
                Not looking good so far ๐Ÿ˜ž
                • W
                  Wazzer
                  OK i think we may have a winner
                  I have resigned to the fact that i will not find a suitable Notebook with the performance i want within the budget the company has set so i have relented adn decided on a Desk Top
                  Please can you check out the specs of the following PC and let me know what you think, I quite like it.
                  Processor Intel Xeon W3570 Processor ( 3.20GHz 1333MHz 8MB )
                  Operating system Windows XP pro SP3
                  System graphics NVIDIA Quadro FX 1800 768MB
                  Total memory 4 GB DDR3 SDRAM 1066MHz
                  Hard drive device 500GB 7200rpm
                  Cheers guys
                  Ben
                  • AnssiA
                    Anssi
                    Last week I tested a desktop with a four-core Xeon with a clockspeed of 2.53 GHz and the same video card that you are contemplating. IMO SU worked OK with it. Comparing to a 3.6 GHz P IV with a QFX 1300 card it was somewhat faster but not stratospherically. So you should be OK. Frankly, as things now stand, it is about the fastest system for SU that money can buy at the moment. The graphics card is not the most expensive one but I am not convinced that it should be.
                    Anssi
                    • C
                      chango70
                      If you are only using SU then I strongly recommend against Quadro FX cards. The performance gain from optimzed openGL is marginal at best which doesn't justify the price difference. I have tested both Quadro FX 3700 and Geforce 9800 GT on my system (They are roughly equivalent hardware wise) and there is no difference in SU performance, however, Quadro is 6x the price. Don't fall for it. Quadro does play nicely with Rhino though thats why I stuck with it.
                      • W
                        Wazzer
                        HI Guys
                        Thanks for the responses.
                        The problem i have is that this is a company computer and they have to buy something "off the shelf" and it has to be from Lenovo.
                        So far the above specification is the best i can find for a reasonable outlay. If you guys know of a better spec lenovo Computer for a reasonable price please let m eknow as i am now Desparate!!!
                        Thanks again for the feed back
                        Ben
                        • AnssiA
                          Anssi
                          Hi Ben,
                          In fact I am in the same fix as you. Company policy limits our choice to a particular make. The model range that I have to choose from does not even carry the CPU that you chose, so we are settling to a somewhat slower clockrate and a more expensive video card instead.
                          However, as I said in my previous post, your choice is about the fastest desktop computer that you can get, and choosing a different make will not help, as adding a second CPU does nothing for SU. The Lenovo workstation I tested was a bit noisy, though. The modern Xeon processors are based on the same technology as the i7 range, and the new features really seem to help single-threaded apps work faster than with the Core2Duo-range CPUs.
                          Anssi
                          • K
                            Khai
                            One hardware addon I'm finding a joy to use with Sketchup is the Belkin N52te gamepad. it's basically a programmable keypad for the left hand. once setup it's lovely to use with SU ๐Ÿ˜„
                            • W
                              Wazzer
                              Hi guys
                              Thanks for the feedback
                              Our IT manager has changed his mind again and I am now getting the Lenovo W700 DS Work station Note Book. And its actually been ordered!!
                              Will let you know how it runs when it arrives next week.
                              Thanks for the help guys
                              Ben
                              • GaieusG
                                Well, I finally join the hardware club now. Thinking about this desktop:
                                • Processor: INTEL Core2 Duo E8400 3.00GHz
                                • Memory: 4GbDDR3 1333Mhz
                                • Video card: nVidia 9600GT / HTD I / 1Gb
                                  (plus all the rest but the above are the essential).
                                  I'll be using it with a 32 bit Windows XP (for the time being) so no "need" for much more RAM ATM for instance.
                                  remus
                                  Thats quite a nice little setup youve got there gai looks envious
                                  • GaieusG
                                    Ah well, I really hope so. My laptop (I've been using for a year now but had got it from Mike so it's a rather old piece despite of its originally good specs) is really dying. It took about an hour and a half today to get it to start! ๐Ÿ˜ฎ
                                    Also it keeps shutting down at the most unexpected moments (probably due to overheating) so forget about rendering for instance. I now put a big "family fan" against its back and also put it on "legs" so that the air stream can blow under its bottom... ๐Ÿ˜•
                                    • GaieusG
                                      @jackson said:
                                      Csaba, considering your laptop's current AND previous owners, could explain a lot! ๐Ÿ˜‰
                                      ๐Ÿ˜„
                                      Yes, indeed. I know I'll have to do the whole cleaning job, really. Once my new machine is up and running (hopefully some time early next week), I'll do it with the lappy. I just don't want to risk ending up with no computer at all as I have ongoing works (and of course, SCF ๐Ÿ˜’ ).
                                      As for the reinstall; yeah, that will also happen. Although I think it was just about half a year or so when I last did it. However I'm afraid the lappy-lady is actually dying so I may even get it checked and if it's worth, maybe change a part or two.
                                        Jackson
                                        Yikes! Silly question, but have you cleaned the inside of the laptop?
                                        A quick guide for anyone who thinks they may need to do this:
                                        1. Unplug the power cable and take out the battery.
                                        2. Unscrew all the access panels on the underside, turn the laptop back right way up, open the screen/lid to 90ยฐ and stand it on its side. This is to create as many "holes" in the laptop chassis as possible so dust can be blown out effectively, even back out through the keyboard.
                                        3. Using compressed air, blow a few extremely short bursts of air backwards through all the exhaust vents. This dislodges all the grunge which has accumulated on the leading edges of grilles, heatsinks and obstructions due to the constant one-directional air flow. Then do a couple of short bursts from the opposite direction (i.e. into the fan air intake) to ensure the dust you just blew backwards hasn't simply lodged somewhere else instead. Repeat this back-and-forth process a few times until you can't see any more dust coming out of either "end".
                                        COMMON SENSE WARNING: Of course, if you're using an air compressor be very careful to limit the pressure and hold the nozzle back a few inches/cms from the actual vents as you can easily dislodge or damage components otherwise.
                                        1. If you can get access to the fan, CPU and GPU heatsinks, a large soft watercolour paint brush is great for getting in the nooks and crannies to get them shiny again (not unlike archeology!). A couple of gentle blasts of compressed air after brushing and they'll be like new.
                                        I do this at least 3 or 4 times a year and (even though I only use it at home) a cloud of extremely fine dust is inevitably emitted from my laptop's innards every time.
                                        A well-insulated CPU (i.e. covered in a nice fur coat of lovely fluffy dust) and blocked pipes will overheat in seconds and blowing more air through it (with an extra fan for example) could just cause more dust to accumulate, exacerbating the problem. All the more so in a smokey atmosphere which, Csaba, considering your laptop's current AND previous owners, could explain a lot! ๐Ÿ˜‰
                                        Re: the incredibly slow start-up, it really sounds like you need to do a full OS resintall.
                                        Jackson
                                          Jackson
                                          @gaieus said:
                                          Yes, indeed. I know I'll have to do the whole cleaning job, really. Once my new machine is up and running (hopefully some time early next week), I'll do it with the lappy. I just don't want to risk ending up with no computer at all as I have ongoing works (and of course, SCF ).
                                          I would have thought that a frequently critically overheating PC would be putting your work at a much greater risk than blowing some air through it now and again. ๐Ÿ˜†
                                          Jackson
                                            johnsenior1973
                                            Without looking back over this thread, it seems to me that most people on here are talking about higher end, $1,500+ machines.
                                            How does SU run on the very cheapest, GMA laptops available for around $300/400?
                                            The PC I have right now is nearly three years old, bottom of the range eMachines desktop - Pentium 4 3.06Ghz, 384mb RAM, ati radeon xpress 200. For me, I really haven't had any problem with SU and the speed is perfectly acceptable for me.
                                            How would this $378 Acer laptop from Wal Mart compare to my present one? http://www.walmart.com/catalog/product.do?product_id=11068044 How would the 9 inch netbooks perform? http://www.walmart.com/catalog/product.do?product_id=11319320
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 20
                                            • 21
                                            • 14 / 21
