    Intersection problem
    6 Posts 3 Posters 302 Views 3 Watching
    • numbthumbN Offline
      numbthumb
      Hi everyone,
      I don´t know if this has been answered before, but I have noticed that, when intersecting spherical objects, surface becomes somehow "shrinked" after the intersection, as seen on the picture I´ve attached.
      Has it something to do with scaling up the object prior to intersection ( and rescaling afterwards )? Does it affect texturing?
      Comfortably numb...
        Do it with Menu > View > Hidden Geometry 'on' and see what's happening - also use X-ray mode to see if there's stuff inside that's clashing...
          Well, if you scale (but especially when you rescale) everything proportionally, this shouldn't happen. There might be some fault in the process but do what TIG says and reveal hidden geometry to checkout the details.
            numbthumb
            I´ve tried to do so, but I can´t tell what´s wrong with it. Here are the screenshots with hidden geometry turned on, in X-ray mode, before and after the intersection ( I didn´t clean up the model afterwards ).It still looks the same in monochrome view.
            Can you help me with this?
            Comfortably numb...
              As was said, what size is this thing ? If it's very small [a few cm] it can cause problems as any newly made faces can get too small to be made correctly. If so try scaling it all by x10, redo intersection and then scale back x0.1...
                numbthumb
                It´s about 400 cm in diameter.
                Unless this means that the model is seriously messed up, I can get over it. But I guess that this affects the texturing also?
                Comfortably numb...
