    The VUE thread
    extensions
    122 Posts 29 Posters 32.8k Views 29 Watching
      ark
      How is the renderspeed i VUE compared to e.g. V-ray or Modo renderengine?
      It seems that VUE can make some nice renders!
      • soloS Offline
        It's difficult to compare them as Vue's advantage is atmospheres and procedural terrains that generally are cumbersome for any render engine, but pretty damn fast with Vue.
        Like all render engines speed is also relative to your machine and Vue is optimal on a 64 bit machine with a good GPU and as many cores and ram as possible.
        Again one can set up and tweak render settings in Modo and Vray to an extent that they give fantastic results at crippling render times and with Vue it's the same, just play around with your atmosphere settings and you will notice how speeds can change.
        So I'd say Vue and Vray are pretty much similar as far as render speeds go (I cannot talk about Modo as I know nothing of it's render speeds) and really contingent on your render settings.
          craftycurate
          @solo said:
          Are you running a 64 bit system? as the new 7.4 has great import support for SU7 now on a 32 bit system and not yet supported on 64bit.
          Richard out of habit I only use .3ds export which you cannot do due to your SU version. I posted a ticket with E-on as I had a few 'sidebyside' issues with the new update so until that's resolved I'm still using 7.21.
          I'm using 32-bit.
          I was able to import SKPs into 7.4 when exporting as SUv6 models.
            The Vue 3D Environment Competition 2009 may be of some interest. Great prizes. 😉
              archigrafix
              SOLo
              By the passed I bought VUE3.1 and vue4...but never managed to use them in professionnal conditions...
              Today attracted by what I heard about VUE7 I decided to give it a new try:
              Just downloaded: VUE7 infinite 7.5PLE
              of course first thing I did..? importing a SU model!
              (...SKP is an import option nice. Before trying I read all the tread and was already a little bit worry about some strange behaviour in this import process...)
              first attempt, with a SU6 failed...its beginning nicely! then tried SU7, SU5, a very simple SU6model etc...
              nothing works...what a shame to sell fonctions that do not work at all...Of course its PLE but thats no excuse in my point of view..!
              However I kept cool and tried with a 3ds file...then miracle all works fine. Only cameras are not imported
              I then begin to play with materials and all the stuff...boom badaboom!!!
              nice bug splat!
              I'll give it another try lately, perhaps I get no chance with vue... hum!
              For now I cant get out of my mind that there are real professionnal softwares you can rely on in real professionnal conditions and others that are a little...young!
              Agir comme un homme de pensée, et penser comme un homme d'action...
              • Chris FullmerC Offline
                Post you .skp model here. Maybe there is something wrong with it?
                  archigrafix
                  thanx chris but its not a problem with one specific file tried with many skp... no way
                  So now I use 3DS... have to say the truth it works real fine. All materials textures etc are at the right place. the only missing thing is camera position. Perhaps someone can tell if theres a way to get those SU camera positions?
                    You are not getting the camera positions in 3dsmax? What file format?
                    • soloS Offline
                      archigrafix, I do not use the Vue importers, they are buggy, in fact nearly every 3rd party render app I've used seems to have crappy importers.
                      I use .3ds from SU, works great.
                        archigrafix
                        Ok solo
                        tried many times the 3ds importer and works fine in usual situations.
                        Now I get many more questions about vue possibilities, to know if its worth the investment for me:
                        Have you tried some interior renderings? If yes how do you set vue (atmosphere etc...) to get a good/fast results?
                        • soloS Offline
                          Archigrafix, Firstly Vue originally was not intended for interiors but for rich looking exteriors, however since version 5 people have been requesting that e-on work on the radiosity engine so that it can be used for interiors.
                          So now with version 7, Vue has a much improved radiosity engine that is capable of rendering interiors pretty well.
                          As for good and fast, like most render apps those two hardly work together, Vue's interior radiosity does come with a slight time cost, where Vue is probably the fastest landscape render solution it is not the same for interiors.
                          Like many render apps hardware plays a huge role, a Good video card and ram helps in navigating and previewing and as many cores as possible at the highest speed helps towards faster final rendering.
                          Below is an exercise I did where I copied a scene I saw on the Modo site (a quick SU model I made) and then did a few interior renders with different lighting effects from sunlight filtering in, omni lighting, volumetric lights and light emitting materials.
                          The original renders are 1024 x 560 (scaled down to post here) and rendered in around 4 to 6 minutes each.
                          http://img43.imageshack.us/img43/6751/bath1b.jpg
                          http://img339.imageshack.us/img339/7270/bath2.jpg
                          http://img3.imageshack.us/img3/2745/bath3.jpg
                          http://img376.imageshack.us/img376/9764/bath4.jpg
                          http://img3.imageshack.us/img3/4187/bath6.jpg
                          http://img397.imageshack.us/img397/1879/bath5.jpg
                          http://img269.imageshack.us/img269/8638/bath7.jpg
                          http://img198.imageshack.us/img198/7382/bath8.jpg
                            Pete, I hate to bug you, but do you have a few simple models like the one above that you would be willing to provide to the forum here? For example, I would be very interested in seeing the sketchup version of that, and the Vue version of it. An indoor and an outdoor scene would be awesome!
                              archigrafix
                              Great images solo..!
                              what are your setup for typical interior scene with sunlight coming from outside?
                              For now there are many things I am a little desorientated in vue:
                              1- in materials: what is difference between highlights and reflexions? I see in Vue preset materials that a metallic material get highlights and no reflexion but reflect however..
                              2- how do you scale procedural material to get realistic results... Is it a test and see process?
                              3- radiosity vs global illumination: I thought radiosity was a little obsolete notion those days with all other global illumination renderer (vray etc...). I suppose radiosity is mostly used in interior scene?
                              4- how do setup a fresnel effect in reflective materials?
                              thats all for the moment!
                              thanx again
                              • soloS Offline
                                Chris, I do not quite understand your request, you want the .skp and the .vob?
                                Archigrafix, the best way to help you is with a bunch of amazing training videos, all free, that will cover everything you need, starting from the beginning.
                                http://www.geekatplay.com/vuetutorialsnew.php
                                • honoluludesktopH Offline
                                  honoluludesktop
                                  If I may, one vote for a .skp. Since my own are not so good, I love to play with the models, of others.
                                  I see some discussion on 32 vs 64 bit systems, has anyone measured the diference with SU on either system? I looked up global illumination. Reciprocity, as well as ray tracing are elements of it.
                                    @Pete, yeah, I was hoping for the sketchup model and the .vob file. Just to sort of see how they look in each system.
                                    However, the tutorials are probably more like what I really need 😆 Thanks for the link. I'll be checking those out shortly! Thanks Pete,
                                      james840a
                                      Im New to this forum, thought id post here first as im looking at the Vue to help with landscape renderings from SU Pro7. Im currently using SketchUp Pro7 with 3D max w/ RCPs to render, on Vista64. But I like the VUE landscaping features to add more realistic greenery to the scene. I mostly do single shot renderings, no animations. I downloaded the PLE of Vue7.5 to try out and was looking through the import file types, and didnt see .skp type. No big deal ill use .3ds unless someone recommends a different file type.< just read it only in Win32
                                      Anyways just subscribing to this thread.
                                      James
                                        James, did you install Vue xStream so you can use Vue directly inside of your 3dsmax? That looks great. I have not tried it yet though. But it looks great to be able to workin side of 3dsmax and access all the great VUE features, and render using Mental Ray.
                                        Do you use xStream Pete? Or are you using infinite?
                                        • soloS Offline
                                          I use infinite, I do not use the Vue to Max, cinema 4d, Xsi, Maya integration as of yet, I may look into it for future work, as of yet I have had no need for it.
                                          I have heard a rumor that a future version of Vue will have a Vray direct plugin as well as a Cuda possibility, so unless I have a project that forced me to use the current integrations with 3rd paty apps, I will hold off and see how E-on develops it's stand alone brand.
                                          • EarthMoverE Offline
                                            EarthMover
                                            That's interesting. Why not though.....7.5 already supports vray. I wonder how well it will go over with the Vue crowd? (Those who don't already have Max and Vray) I'm guessing it will be around $800 like all the other Vray plugs? Now Vue just needs better modeling tools and it will be one step closer to a stand alone app.
                                            Content Creator at Skapeup
                                            • 4 / 7
