    Startup Switches
    17 Posts 6 Posters 4.7k Views 6 Watching
    • W Offline
      watkins
      Dear Jim,
      Does that mean that one could load different plugin folders, e.g. plugin_arch, plugin_mech etc?
      Regards,
      Bob
      • alexschreyerA Offline
        alexschreyer Extension Creator
        Thanks for your great suggestions. I like both solutions. The require_all one will be a good solution for the computer lab application that I have in mind.
        I figured it might be a good idea to wrap that behavior into a plugin. So here's my first attempt (plugin_loader.rb):
        require 'sketchup.rb'
        def load_plugin_file
          filename = UI.openpanel "Select a SketchUp Plugin File (With RB Extension)", "", ""
          load filename
        def load_plugin_folder
          # How can we select a folder easily with Ruby???
          # require_all foldername
        filename = "plugin_loader.rb"
        if !file_loaded?(filename)
          # get the SketchUp plugins menu
          plugins_menu = UI.menu("Plugins")
          my_menu = plugins_menu.add_item("Load plugin... (file)") { load_plugin_file }
          my_menu = plugins_menu.add_item("Load plugins... (folder)") { load_plugin_folder }
          # Let Ruby know we have loaded this file
          file_loaded(filename)
        Does anyone know a good solution to get a directory path using a selection box?
        Cheers,
        Alex
        Author of "Architectural Design with SketchUp":
        http://sketchupfordesign.com/
          Jim
          @watkins said:
          Dear Jim,
          Regards,
          Bob
          In theory, but it depends on how the script is written. There may be some plugins that make assumptions about where they are installed and where their support files are located, and thus will not work when moved outside the Plugins folder.
            Jim
            Cheers,
            Alex
            Not using the the Ruby API. I don't know off-hand if anyone has ever posted another solution.
              Thanks, Jim. I was thinking about a (dirty) way: Let user select file in folder and then parse the directory path. Apparently that needs some conversion of backslashes into forward ones inbetween to get the Ruby functions to do it but it may work. Another option is a UI library, of course.
              Cheers,
              Alex
                This is turning more into a Ruby topic...
                I tried the plugin loader with a few plugins and as Jim assumed some load and some don't. I don't know too much about Ruby, but one that puzzled me because it didn't work was the oniondome.rb. It requires only the 'parametric.rb' and 'bezier.rb' scripts, which in turn require only 'sketchup.rb'. All are in the same folder (/plugins/inactive/).
                Are there any SU Ruby functions that assume a file to be in the Plugins folder although no absolute path is given in a plugin?
                Cheers,
                Alex
                  Jim
                  Well, here is the code for require_all:
                  def require_all(dirname)
                      begin
                          rbfiles = Dir[File.join(dirname, "*.rb")]
                          $;.push dirname
                          rbfiles.each {|f| require f}
                      rescue
                          puts "could not load files from #{dirname}"
                  You will see a special variable $: which is an array and contains the load paths used by the load and require methods. Here is the result of entering $: in the Ruby Console on my PC:
                  ["C;/Program Files/Google/Google SketchUp 7/Plugins", "C;/Program Files/Google/Google SketchUp 7/Tools", "C;/Program Files/Google/Google SketchUp 7/Plugins/Podium"]
                  The require_all method adds the sub-directory to the load path before trying to require the .rb file, so any support files can technically be stored in the sub-folder also.
                  I will check out oniondome.rb to see if there is anything unusual there... it works for me. You do need to use the full path such as;
                  require_all(File.join(Sketchup.find_support_file("plugins"),"inactive"))
                    Thanks, Jim! That's when Ruby is starting to turn cryptic on me...
                    Seems somewhat straight-forward, though. All we need now is the directory selection dialog.
                    I wanted to preset the file selection dialog to the plugin folder, seems like I can do that with $:[0]. Sweet!
                    Cheers,
                    Alex
                      Jim
                      That may work, but I am unsure if the order will be identical on every system SketchUp is installed on. I would just use
                      plugins_folder = Sketchup.find_support_file("Plugins")
                        >     begin
                        >         $;.push dirname
                        >     rescue
                        >     end
                        > end
                        Does this override the existing built-in require_all method?
                        I used require_all in CityGen to load the modules, but I don't want it loading the sub-folder. If this overrides the existing method it could potentially cause problems.
                          Jim
                          No, it IS the require_all method from sketchup.rb. It was meant as a reference.
                            Ah. -so it loads al ruby resources in the sub-folders as well?
                            • Chris FullmerC Offline
                              I don't think that it loads the sub folders at all. It looks like it just loads the .rb files from the specified psth.
                                I think that the built-in require_all method doesn't load anything other than *.rb files in the given folder. My snippet in the other thread made it do sub-folders too...
