    [Plugin] Sculpt Tools (help)
    188 Posts 46 Posters 87.9k Views 46 Watching
      Dan
      @cadfather said:
      if you made the face a component, and mirrored the other half, you could work one half of the face..
      the way rubies are going, sketchup 8 will have to deliver..
      Hey, you're right!
      I totally forgot this... 😳
      I still wonder this is a native SU feature πŸ‘Ώ
      • N Offline
        notareal
        Okay, I've sorta got the Shift-to-reverse-tool working. It makes sculpting a lot easier; either that, or I've just gotten a lot better 🀣
        Sure it will help. Looks great so far!
        Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
          BTM
          @kwistenbiebel said:
          Looks promising....I think we are going to need a UV-unwrapper for texturing stuff like that.
          The down side to all this, as BTM states himself, will be the inability of Sketchup to handle a medium high poly count .
          … The plugin can handle moving over 4000 points at a time, although that's with a fair amount of lag, but still not too bad.
          @earthmover said:
          Are you using another plugin to subdivide the mesh that you are sculpting?
          It's good to hear you say FREE plugin.....as I thought for sure you were going to go commercial with it.
          I don't know exactly what you mean, but I used 'add detail' to subdivide the sphere, mostly around the face, before sculpting.
          … Also, i've added the ability to pick between an S-curve ( http://en.wikipedia.org/wiki/S_curve ) , or just a linear smoothness for the transformation. the S-curve is the kind of smoothing that seems to be used by the smoove tool, and makes the sculpting a bit smoother, although the math does make it a bit slower than the basic smoothing ability, which, when brushed on like it would be, smooths quite well anyways ( all the videos and pictures so far were made with the linear smoothing).
            Tekelwriter
            drooling WOW! I love messing with Blender's sculpting tools. It includes: Draw, Smooth, Pinch, and Inflate (each of these, except Smooth, with an option for additive or subtractive). I am very eagerly anticipating the release of this plugin.
              BTM
              of those tools, bulge would be draw, carve would be draw + shift, pull would be pinch, and push would be pinch + shift. πŸ˜„
              I'm still thinking of a way to do smooth, and a kind of inflate tool. πŸ˜‰ I'm going to try my idea of a smooth tool soon.
                mitcorb
                -BTM:
                In one of your previous responses you said you used "add detail" to the sphere to subdivide it. Is this an available plugin?
                • E Offline
                  EarthMover
                  "Add Detail" is one of the sandbox tools.
                  Content Creator at Skapeup
                    remus
                    Is 'Wow' any good? πŸ˜„
                      BTM
                      New Tool Added: Smooth πŸ˜„
                      one half of face smoothed
                      (unfortunately, it's slower than the other tools, because it has to find the mean of all the other ends of the lines the point being transformed is part of. That takes a little while)
                      … Any opinions? β˜€
                        Looks fantastic!
                        so when do I get to play with it? πŸ’š
                          BTM
                          @solo said:
                          Looks fantastic!
                          πŸ‘ I don't know yet πŸ˜„
                          I'm thinking it has enough tools for a first release now, mostly to test and play with, but there's no visual help, and the settings dialog used by all the tools is still just an inputbox (maybe I could convince someone to make a webdialog…). there is a toolbar now, but the icons aren't that great. Also, some of the controls in the dialog don't make that much sense; strength is a divider, which should usually be at around 10-40 for most tools, but for smooth, it should be 2-10. Because it's a division, Lower numbers are stronger.I can change that really easily, but it might take a bit of time.
                          … Anyways, out of those things there are only a few I have to fix/ do before I put out a first release, but when I do, I'll also need someone to make a proper ZIP file of the tools. My mac tends to make ZIPs that aren't very Windows friendly, and to find the files in them involve deleting files, and searching for the files I put in the ZIP. 😳
                          … As for a specific day / time: I'd guess between today and thursday, possibly friday.
                          Hopefully today.
                            Sounds good to me πŸ˜„
                              sepo
                              This is fantastic. I have missed it somehow .....can't wait to try it myself. πŸ‘ πŸ‘
                                BTM
                                OK, I'm ready to release it, but due to the fact that the ZIP files my mac makes turn out funny on windows, I'll need someone else to agree to make it into a ZIP file, and hopefully look through the tools, if I messed up on anything. πŸ˜„ If someone agrees, I'll send them a ZIP file with the tools. (though they apparently require a bit of searching to find the files on a windows computer, that's why I need someone else to make a normal one, my mac makes funny ones). After I PM the weird ZIP to someone, they'd PM me back with the files in a proper ZIP file, and then I'd post it. Can anyone volunteer? πŸ˜‰
                                  BTM
                                  Okay, I got a volounteer πŸ˜„
                                    Click Draw
                                    Hurry!....Please!!!! πŸ˜„
                                    Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                      sepo
                                      I sent you a PM.. with question...
                                        remus
                                        chomps at bit
                                          sepo
                                          Hmmm.. the icons are not showing although have tool bar ...but can't make it work. I have a feeling I am not having everything.
                                            BTM
                                            There could be 2 problems, I overlooked them when I sent you the ZIP. One, is that I don't know what flags returns when no keys are pressed on windows. If it's not the same as mac, it won't work. Other than that, I included a line of code twice for each tool by accident, but it should only cause it to have 2 of the tools in the plugins menu, and shouldn't change anything else. Can someone see what 'flags' returns when no key is pressed on windows? On my mac it's 256, so in the code I put if flags == 256 + MK_LBUTTON , etc. I think that's probably why the tools aren't working. Other than that, the Thumbs.bd file shouldn't be there, but that doesn't seem to make a difference.
                                            • 3 / 10
