    Unicode, UTF8 and Ruby
    19 Posts 6 Posters 3.5k Views 6 Watching
    • Didier BurD
      Didier Bur
      Hi all,
      Anyone ever challenged to deal with unicode and UTF8 strings conversions ?
      This is driving me mad.
      We have in French some special letters like à,é,è,ç,ê, and so on, and many other languages have their own characters set as well
      When I try to retrieve the name of a material (material.display_name) in a script, I have to translate it first with a LanguageHandler object and the materials.strings local file.
      This returns a string, from the prepared $mat_strings I have built with LanguageHandler.
      Of course sometimes french materials names have special characters in them: béton, plâtre, etc.
      When the script sends such strings to an output file, these characters are NOT converted, for instance the string "Matière 1" is output as "Matière 1".
      I've searched through several ruby forums and it appears there is no easy method to get the correct translation. iconv library is a pain.
      Can anyone point me to the right direction, or has an idea ?
      DB
      • GaieusG
        When I was translating Fredo's bezier spline rb, I was asked to use backslashes before these special characters (like \é for é). Or were they slashes?
        And I guess you know this - to make your scripts work with French menus etc. so I suppose this is not the problem...
        • Didier BurD
          Didier Bur
          I was not aware of the backslash thing. So I'll try that first. Thanks Gaeius.
          Functions like: str=str.gsub(/(è)/, 'e') works also but is not universal and supresses the accentuation.
          DB
          • Didier BurD
            Didier Bur
            MMmmmm, slash and backslash doesn't work either.
            And using special characters in the ruby code generate errors when loading 👿
            DB
            • fredo6F
              @didier bur said:
              Hi all,
              Didier,
              I am unclear of where are the French strings coming from in your exemple. Is it from a file? or from a constant definition?
              As Gaieus mentioned, in Ruby, it is careful to put a backslashbefore any character which is not straight ASCII, like many accentuated characters.
              So, to define a constant:
              Text = "b\éton"
              and not
              Text = "béton"
              Otherwise you may get an error when loading the script (but not always)
              This also works from and to the Ruby Console
              Now, I don't know what happens when reading and writing from files, as I never tried.
              Could you attach your files so that I try
              PS: The only things I noticed concerns the dialog boxes, where you have a different encoding and decoding of the accentuated characters, which makes the == comparison fail. This seems to be due to the fact that Sketchup uses Windows SDK dialog boxes, which have a different encoding method.
              • Didier BurD
                Didier Bur
                Bonjour Fredo,
                Le problème ne vient pas d'un fichier. J'ai des noms de matériaux à récupérer dans un modèle SketchUp, pour les re-exporter vers une feuille Excel. Quand tu récupère le nom d'un matériau pour une face f, f.material renvoie par exemple une chaîne s "béton". Quand tu écris cette chaîne dans le fichier Excel, par exemple fichier.puts(s) tu n'obtiens pas "béton", mais "béton", parce que les caractères accentués sont codés sur 2 octets au lieu d'un. Et Ruby n'a pas de méthode pour convertir de l'UTF8 en Unicode.
                Je suis obligé de faire une fonction comme celle-là:
                def ocr_change_name(str)
                  # replace non-digit non-letter with empty string
                  str = str.gsub(/([ -#;'"$£=()|{}&+<>,;@-])/, '')
                  #replace french characters
                  str=str.gsub(/(Ã )/, 'a')
                  str=str.gsub(/(â)/, 'a')
                  str=str.gsub(/(é)/, 'e')
                  str=str.gsub(/(ê)/, 'e')
                  str=str.gsub(/(ë)/, 'e')
                  str=str.gsub(/(î)/, 'i')
                  str=str.gsub(/(ï)/, 'i')
                  str=str.gsub(/(ô)/, 'o')
                  str=str.gsub(/(ù)/, 'u')
                  str=str.gsub(/(ç)/, 'c')
                Mais c'est valable juste pour le français, pas pour les autres langues. Galère...
                DB
                • T
                  todd burch
                  UTF8 doesn't work with the SU Ruby API. I figured out this sad bit of news when I wrote the 3DTextTool.
                  UTF8 works in Ruby just fine.
                  Google knows. They've known for the past several maintenance updates.
                  Todd
                    I came upon this somewhere... Don't know if it has any ideas that help ?
                    US-ASCII.rb
                    • fredo6F
                      @didier bur said:
                      Bonjour Fredo,
                      Then, with the explanation from Todd, I understand why I had problem with the dialog boxes, as Windows does support UTF8.
                      • Didier BurD
                        Didier Bur
                        TIG, it seems the "register" method is missing. Apparently not a standard method...
                        DB
                          But couldn't we (you!) use the pack / unpack tricks to convert between the two encoding ?
                            Todd
                            That was my first problem when I first tried to write ruby plugins; writing in UTF-8. From doing websites I've grown into the custom of using UTF-8 to account for most languages. I figured that I was doing something wrong and meant to go back and have another look at some point. So, essentially UTF-8 is no-go? And this is due to the SU API - not Ruby?
                            • Didier BurD
                              Didier Bur
                              Good advice, thanks TIG 👍
                              DB
                                Yes. You can't use FileTest.exist?(Sketchup.active_model.path) if the file has unicode. The 'path' SUp reports looks OK with say ascii_chr=233 for 'é', however the FileTest sees the 'é' as a unicode and so returns false - although they both 'look' the same, the character encoding is different.
                                My clunky fix only works on the top-most file (or folder) containing the unicode parts, as the Dir.entities(dir) falls over if there are accents earlier in the path...
                                It can't be beyond the wit of man to take 'Sketchup.active_model.path' and encode it as unicode in a way that would match the Ruby built-ins like FileTest.exist?(path) or Dir.entities(dir)... however it is beyond the wit of me... 😕
                                  I think that I couldn't even get UTF-8 scripts to run... I'll have a look at Ruby + SU + UTF. Wonder if Ruby has some nice encoding methods.
                                  Seeing how there's many scripts that uses localisation it's be very nice to have UTF-8.
                                  .SKP has a weird combination of UTF+8 and regular ACSII. Seems that it wasn't originally UTF-8 and it was later added. Maybe we're running into problems due to this.
                                    233.chr ### a plain ascii é
                                    é
                                    233.chr+233.chr ### 2 number plain ascii é make éé
                                    éé
                                    195.chr ### a plain ascii capital A with an umlaut
                                    Ã
                                    169.chr ### a plain ascii the (c)opyright symbol
                                    195.chr+169.chr ### BUT these 2 number ascii codes added together = one unicode é that looks like an ascii é !!!
                                    é
                                    ??? go figure ???
                                      UTF only uses two bytes for some of the characters. For most of the latin characters it uses 1byte equal to normal ASCII.
                                        Didieret al...
                                        After more than a year and a bit...
                                        typical usage: file_found?(Sketchup.active_model.path)
                                        returns trueif the file found,
                                        even with accented unicode characters in name/path,
                                        e.g. qualisé.skp
                                        EDIT: see here for latest file... http://forums.sketchucation.com/viewtopic.php?p=169225#p169225
                                          file_found?(path) that fixes ascii in SUp Ruby path and unicode in returned filepath returning false negatives with 'FileTest.exist?(path)' - even with accented characters - is updated and moved here... http://forums.sketchucation.com/viewtopic.php?p=169225#p169225
