    Render challenge - water caustics
    35 Posts 19 Posters 16.2k Views 19 Watching
      remus
      Heres my go in indigo. Taking a while to clear up though, so i'll post a (hopefully) cleaner version in the morning.
        Out of challenge : Zbrush for the fun 😄
        • majidM Offline
          majid
          real coustics , pure KT (modeling and rendering, both) ,redused noisetrue caustics out of kt
            remus
            heres it again after 11 hours.
              samprocess
              very cool thread, i'm also want to try some.
              http://i132.photobucket.com/albums/q28/samprocess/Samui/samuilogo30x300.jpg
                remus
                Yeah, just a big volume:
                Made using jim's randomise TIN script followed by 2 SDSs.
                • 2 Offline
                  21D
                  this is my try....it's a simple box, with a flat rect. geo.
                  sent to modo401....textured and rendered
                  Modo 401 handels CAUSTICS now
                  screengrab for some SPECS
                  "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                  Le Corbusier
                  • soloS Offline
                    Excellent Modo 401 show piece, so how is the new Modo so far?
                    Here is a faked caustic I did in December 2006, using Podium version 1.0.
                    http://img224.imageshack.us/img224/286/2006121705520621m17sqo8.jpg
                      sepo
                      This brings some memories 😄
                      • 2 Offline
                        21D
                        Well haven't played to much with it, only been test running it.....the "fur" ellement is just amazing...i'll see if i can post a sample of it used to creat a grass field.
                        as you could see the caustics also looks good, even though i have a dual core machine, it renders pretty fast (see the caustics render screengrab), i am now going to try out the blurry refractions...
                        but all in all, amazing.
                        it's a bit more aimed now for archvis with all the presets that can be used,
                        i am definitly going to learn how to use it, so i can add it to my archvis workflow.
                        Le Corbusier
                        • majidM Offline
                          majid
                          congrats Solo... it is an art work, out of podium!!! 👍
                          • daleD Offline
                            dale
                            Well not totally satisfied yet, but though I'd post the progression.
                            Kerkythea
                            Water Surface is thin glass, IOR 1.33, color changed to blueish, Perlin Noise Fresnel added
                            Rendered with Preset 09 Photon Caustics Medium
                            • majidM Offline
                              majid
                              Kerkythea
                              if you are going to have a better result , maybe give a try over dielectric glass shader ... or maybe download waterpack I've prepared some while ago :
                              http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=fileinfo&id=86
                              also less bump over Z direction is needed...and the best result for true caustics would be reached , using preset no 20...
                              also u may have your camera , just below water surface 😉 ( give it a try 👍 )
                              • RichardR Offline
                                Richard
                                Hey those modo images are amazing!
                                Maxwell - faked!
                                http://img23.imageshack.us/img23/8108/typicalunitsdraftimage7.jpg
                                http://img177.imageshack.us/img177/3204/70225399bt6.jpg
                                Maxwell night - faked! 5 min test render! Needed longer!
                                http://img185.imageshack.us/img185/485/pooltq6.jpg
                                BUILTBRAND.COM.AU
                                • majidM Offline
                                  majid
                                  here are other renderes from differenr scene.. it seems that KT has good caustics handling , but the water material , doesn't let that the caustics be seen from top view ...
                                  from below water view
                                  • F Offline
                                    Fred
                                    I tried something to.
                                    http://img3.imageshack.us/img3/4258/waterf.png
                                    • daleD Offline
                                      dale
                                      Thanks majid
                                      I hope to get time to try this. I do have, and use your waterpack quite often, (thanks for that), but when I try these challenges I like to try to do them from scratch to try and understand some of the principles, and controls and their variables. It also makes me go through some of the tips, tricks, and tutorials on the Kerkythea forum site, from which I always learn.
                                      Thanks for the help.
                                      • olisheaO Offline
                                        olishea
                                        solo....how did u fake the podium caustics?
                                        oli
                                        • soloS Offline
                                          Oliver, it's done with a light and a caustic pattern overlaid onto a texture in PS, actually very simple. Now with blurred reflections and bump mapping it can be done even better.
                                          • olisheaO Offline
                                            olishea
                                            thanks for the reply pete
                                            oli
