    Render challenge - water caustics
    35 Posts 19 Posters 15.3k Views 19 Watching
      remus
      heres it again after 11 hours.
        samprocess
        very cool thread, i'm also want to try some.
          remus
          Yeah, just a big volume:
          Made using jim's randomise TIN script followed by 2 SDSs.
          • 2 Offline
            21D
            this is my try....it's a simple box, with a flat rect. geo.
            sent to modo401....textured and rendered
            Modo 401 handels CAUSTICS now
            screengrab for some SPECS
            "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
            Le Corbusier
            • soloS Offline
              Excellent Modo 401 show piece, so how is the new Modo so far?
              Here is a faked caustic I did in December 2006, using Podium version 1.0.
              http://img224.imageshack.us/img224/286/2006121705520621m17sqo8.jpg
                sepo
                This brings some memories 😄
                • 2 Offline
                  21D
                  Well haven't played to much with it, only been test running it.....the "fur" ellement is just amazing...i'll see if i can post a sample of it used to creat a grass field.
                  as you could see the caustics also looks good, even though i have a dual core machine, it renders pretty fast (see the caustics render screengrab), i am now going to try out the blurry refractions...
                  but all in all, amazing.
                  it's a bit more aimed now for archvis with all the presets that can be used,
                  i am definitly going to learn how to use it, so i can add it to my archvis workflow.
                  Le Corbusier
                  • majidM Offline
                    majid
                    congrats Solo... it is an art work, out of podium!!! 👍
                    • daleD Offline
                      dale
                      Well not totally satisfied yet, but though I'd post the progression.
                      Kerkythea
                      Water Surface is thin glass, IOR 1.33, color changed to blueish, Perlin Noise Fresnel added
                      Rendered with Preset 09 Photon Caustics Medium
                      • majidM Offline
                        majid
                        Kerkythea
                        if you are going to have a better result , maybe give a try over dielectric glass shader ... or maybe download waterpack I've prepared some while ago :
                        http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=fileinfo&id=86
                        also less bump over Z direction is needed...and the best result for true caustics would be reached , using preset no 20...
                        also u may have your camera , just below water surface 😉 ( give it a try 👍 )
                        • RichardR Offline
                          Richard
                          Hey those modo images are amazing!
                          Maxwell - faked!
                          http://img23.imageshack.us/img23/8108/typicalunitsdraftimage7.jpg
                          http://img177.imageshack.us/img177/3204/70225399bt6.jpg
                          Maxwell night - faked! 5 min test render! Needed longer!
                          http://img185.imageshack.us/img185/485/pooltq6.jpg
                          BUILTBRAND.COM.AU
                          • majidM Offline
                            majid
                            here are other renderes from differenr scene.. it seems that KT has good caustics handling , but the water material , doesn't let that the caustics be seen from top view ...
                            from below water view
                            • F Offline
                              Fred
                              I tried something to.
                              http://img3.imageshack.us/img3/4258/waterf.png
                              • daleD Offline
                                dale
                                Thanks majid
                                I hope to get time to try this. I do have, and use your waterpack quite often, (thanks for that), but when I try these challenges I like to try to do them from scratch to try and understand some of the principles, and controls and their variables. It also makes me go through some of the tips, tricks, and tutorials on the Kerkythea forum site, from which I always learn.
                                Thanks for the help.
                                • olisheaO Offline
                                  olishea
                                  solo....how did u fake the podium caustics?
                                  oli
                                  • soloS Offline
                                    Oliver, it's done with a light and a caustic pattern overlaid onto a texture in PS, actually very simple. Now with blurred reflections and bump mapping it can be done even better.
                                    • olisheaO Offline
                                      olishea
                                      thanks for the reply pete
                                      oli
                                      • daleD Offline
                                        dale
                                        another attempt
                                          sepo
                                          Richard , that wood panel texture is great. Could you tell what it is? Arroway? Love that pool render. Nice, clean design.
                                          • RichardR Offline
                                            Richard
                                            Thanks mate the design is one of my own! The texture for the timber panel? The one with the screws in I might have edited an arroway and rebuilt to rid the tiling, fix colour and bump, add screws etc. I get so anal the screws even have the head bumped and discoloration of the timber around the head along the grain and the decking a slight cupping in the bump!! My mother was german!
                                            http://img193.imageshack.us/img193/5108/striptimberpanelling.jpg
                                            BUILTBRAND.COM.AU
