    Script slows down exponentially - help?
    19 Posts 6 Posters 1.4k Views 6 Watching
    • T
      todd burch
      Do you have Outliner open while doing this?
      • Chris FullmerC
        @Todd, nope, I've got it closed.
        @Adam, I'll try putting them on a new hidden layer. That could be worth trying too.
        I did try grouping them each, then adding the first chunk to a single group, hoping SU would only recognize the 1 big group and then go faster in the next chunk of groups to process - no luck. It was just as slow.
        So I'll try the hidden layer too in an hour or two.
        • Didier BurD
          Didier Bur
          Maybe a problem with the memory. I recently developped a script that creates a bunch of groups on the fly, and first I noticed that entities.add_group is buggy, and second that the more groups there are, the slower the process is.
          So I made an alias of the method "add_group" of the "entities" class, and added the garbage collector in this alias. No more bug splats and a quicker process.
          Put that in your code so the memory is "cleaned" from time to time:
          GC.start
          Hope this helps,
          DB
          • Chris FullmerC
            Hi Didier, is there also a file to include? or do I really just need to add the line
            GC.start
            somewhere in my script and it will just work?
            Thanks so much, sounds like the problem I am experiencing and I'll be glad to see a fix for it!
            • Didier BurD
              Didier Bur
              Hi Chris,
              Putting GC.start just before the suspicious instructions will do.
              No file to include, this is pure Ruby.
              See: http://www.rubycentral.com/book/ref_m_gc.html
              Regards,
              DB
                Components are not affected by this?
                • Didier BurD
                  Didier Bur
                  No, components aren't affected. The add_group method is buggy because when a script creates a lot of groups on the fly, sometimes the new empty group is stored (as usual) like a component definition, but has NO instance. This leads to a bug splat. Below is the alias method used to avoid the bug:
                  class Sketchup;;Entities
                          alias add_group_su add_group
                          def add_group(*args)
                  	GC.start
                          g=self.add_group_su(*args)
                          while g.class!=Sketchup;;Group
                  		puts "retry add_group" # trace
                   Sketchup.active_model.definitions.purge_unused
                  return g
                  DB
                  • Chris FullmerC
                    Thanks, I've been trying to figure out how to make this "alias" with no luck. I'll use your snippet.
                    So if you include it in your script and I include it mine, and other people put it in theirs, does it start doing weird things to the poor add_group method?
                    • Chris FullmerC
                      Hmm, thats not helping speed things up for me. Iterating over 7,500 entities and grouping them in all_connected groups takes 187 seconds the way I have it right now.
                      adding the alias method above to my script makes it take 209 seconds. And as I've mentioned, I've got it spliiting the entities into groups of 1000 so I can see how the slow down is happening. And the method doesn't seem to help. Each block of 1000 takes twice as long as the previous block.
                      Here's my entire script if you care to look at how I put it together.
                      require 'sketchup.rb'
                      		GC.start
                      			#puts "retry add_group" # trace
                      		return g
                      module Clf_loosegroups
                      	# Make groups of all geometry in the selection set or active_entities.
                      	def Clf_loosegroups.main
                      		now = Time.now
                      		model = Sketchup.active_model
                      		@entities = model.active_entities
                      		sel = model.selection
                      		if sel[0]
                      			ents = sel.to_a
                      		else
                      			ents = @entities.to_a
                      		if Sketchup.version_number < 7000000
                      			model.start_operation "Make Groups"
                      		else
                      			model.start_operation "Make Groups", true
                      		#this divides the given entities into groups of 1000 and then sends them to be turned into groups
                      		chunk = 1000
                      		count = (ents.length/chunk)+1
                      		new_arr = []
                      		@top_level = ents[0].parent
                      		count.times do |e|
                      			place_number = (e*chunk)
                      			new_arr = ents[place_number,chunk]
                      			puts new_arr.length
                      			Clf_loosegroups.maker(new_arr)
                      		model.commit_operation
                      		now2 = Time.now
                      		puts now2-now
                      	#this takes each given entity, finds all_connected, then adds all that to a groups, unless the given entity is already a part of a group
                      	#That would happen when an entity it was connected to was already sent to this method in a previous block.
                      	def Clf_loosegroups.maker(ents)
                      		nowa = Time.now
                      		while ents.length > 0
                      			if ((ents[0].is_a? Sketchup;;Edge) || (ents[0].is_a? Sketchup;;Face)) && ents[0].parent == @top_level
                      				to_group = ents[0].all_connected
                      				ents = ents - to_group
                      				group = @entities.add_group(to_group)
                      			else
                      				ents = ents - [ents[0]]
                      		nowb = Time.now
                      		puts "---------"
                      		puts nowb-nowa
                      		puts "---------"
                      	end # maker
                      #----------Menu system----------
                      if( $submenu )
                      	organizer = $submenu
                      	if !file_loaded?(__FILE__) then
                      		organizer.add_item("Loose Geometry to Groups") { Clf_loosegroups.main  }
                      else
                      	if !file_loaded?('clf_menu_loader') then
                      		$clf_tools_menu = UI.menu("Plugins").add_submenu("Chris Fullmer Tools")
                      		$clf_tools_menu.add_item("Loose Geometry to Groups") { Clf_loosegroups.main  }
                      file_loaded('clf_menu_loader')
                      file_loaded(__FILE__)
                        Jim
                        How do I reproduce the bug?
                          Jim
                          Well, I do get a BugSplat every time I try to explode my groups made using your script, Chris.
                          I am only creating 100 groups total.
                          • Chris FullmerC
                            Thats odd. I never get bugsplats. I'll see if I can make it splat.
                            I've attached my file - pre any tweaks I've trined from this thread. I've also included the file I used in the video.
                            (its large and might take a few moments to load - sorry!
                            [flash=944,759:2xbb34vu]http://www.chrisfullmer.com/chrisfullmer/forums/group_slowdown.swf[/flash:2xbb34vu]
                            And again, I'm not sure its a "bug". Seems more like a sketchup issue. It gets slower at making groups when there are already lots in the model. If anyone think s of anything else, great! But don't stay up late thinking about it πŸ˜„
                            group slowdown.skp
                            clf_loose2groups.rb
