    Script slows down exponentially - help?
    19 Posts 6 Posters 960 Views 6 Watching
    • Chris FullmerC Offline
      Hi folks, I am re-writing my first script, which iterates through the model and takes the first entity, finds everything connected to it, and then groups that. Then moves on to the next entity.
      My script is working great.
      But the problem is that it gets slower the more entities I try to do at once.
      500 entities < .1 seconds
      2000 ents = 4 seconds
      5000 ents = 20 seconds
      So I thought I could break up my "grouping" into arrays of 500 elements, which goes so fast. So I send an array of 500 entities to my grouping method. The first 500 element array flys through, then the second takes 4 times as long, then the 3rd takes another 4 times as long. On and on. I'm unsure why the method processes more slowly the more times it gets run.
      Does this make any sense? Here is the code. I've got a lote of "Time" stuff in there because I am testing it for speed:
      module Clf_loosegroups
      	# Make groups of all geometry in the selection set or active_entities.
      	def Clf_loosegroups.main
      		now = Time.now
      		model = Sketchup.active_model
      		@entities = model.active_entities
      		sel = model.selection
      		if sel[0]
      			ents = sel.to_a
      		else
      			ents = @entities.to_a
      		if Sketchup.version_number < 7000000
      			model.start_operation "Make Groups"
      		else
      			model.start_operation "Make Groups", true
      		chunk = 1000
      		count = (ents.length/chunk)+1
      		new_arr = []
      		now21 = 0
      		now22 = 0
      		count.times do |e|
      			place_number = (e*chunk)
      			new_arr = ents[place_number,chunk]
      			puts new_arr.length
      			Clf_loosegroups.maker(new_arr)
      		model.commit_operation
      		now2 = Time.now
      		puts now2-now
      	def Clf_loosegroups.maker(ents)
      		nowa = Time.now
      		puts ents.length
      		while ents.length > 0
      			if (ents[0].is_a? Sketchup;;Edge) || (ents[0].is_a? Sketchup;;Face)
      				to_group = ents[0].all_connected
      				ents = ents - to_group
      				group = @entities.add_group(to_group)
      			else
      				ents = ents - [ents[0]]
      		nowb = Time.now
      		puts "---------"
      		puts nowb-nowa
      		puts "---------"
      	end # maker
      Any thoughts?
        Hey, after some more playing, I think I've found the culprit.
        SketchUp gets slower at creating groups the more groups it already has in the model. So where I said my script will work with 1000 entities in .1 seconds or whatever, well thats only true when SketchUp does not have any groups already in the model.
        If SketchUp already had 5000 groups in the model, then that same process takes up to a minute (some of these times are only close approximations).
        So it is not my script's fault, but it is in SketchUp's ability to create groups quickly.
        • AdamBA Offline
          AdamB
          Have you tried (programmatically) hiding existing groups?
          Adam
            No I have not. That might prove to be interesting! I'll give it a try and report back, thanks Adam.
              Bummer, that did not seem to help. I used group.hidden=true and adding groups still slowed down the more groups there were in the model.
                That's interesting... hmm...
                • AdamBA Offline
                  AdamB
                  Just for completeness, try hiding them in a hidden Layer.
                  I'm presuming its not "creating groups quickly" per se but the need to check every existing group for interaction with the new one that is taking time.
                  So if you have N groups in a flat hierarchy is it as slow as N groups in a deeply nested hierarchy (where SU can early out on these tests).
                  Adam
                    todd burch
                    Do you have Outliner open while doing this?
                      @Todd, nope, I've got it closed.
                      @Adam, I'll try putting them on a new hidden layer. That could be worth trying too.
                      I did try grouping them each, then adding the first chunk to a single group, hoping SU would only recognize the 1 big group and then go faster in the next chunk of groups to process - no luck. It was just as slow.
                      So I'll try the hidden layer too in an hour or two.
                      • Didier BurD Offline
                        Didier Bur
                        Maybe a problem with the memory. I recently developped a script that creates a bunch of groups on the fly, and first I noticed that entities.add_group is buggy, and second that the more groups there are, the slower the process is.
                        So I made an alias of the method "add_group" of the "entities" class, and added the garbage collector in this alias. No more bug splats and a quicker process.
                        Put that in your code so the memory is "cleaned" from time to time:
                        GC.start
                        Hope this helps,
                        DB
                          Hi Didier, is there also a file to include? or do I really just need to add the line
                          GC.start
                          somewhere in my script and it will just work?
                          Thanks so much, sounds like the problem I am experiencing and I'll be glad to see a fix for it!
                            Didier Bur
                            Hi Chris,
                            Putting GC.start just before the suspicious instructions will do.
                            No file to include, this is pure Ruby.
                            See: http://www.rubycentral.com/book/ref_m_gc.html
                            Regards,
                            DB
                              Components are not affected by this?
                                Didier Bur
                                No, components aren't affected. The add_group method is buggy because when a script creates a lot of groups on the fly, sometimes the new empty group is stored (as usual) like a component definition, but has NO instance. This leads to a bug splat. Below is the alias method used to avoid the bug:
                                class Sketchup;;Entities
                                        alias add_group_su add_group
                                        def add_group(*args)
                                	GC.start
                                        g=self.add_group_su(*args)
                                        while g.class!=Sketchup;;Group
                                		puts "retry add_group" # trace
                                 Sketchup.active_model.definitions.purge_unused
                                return g
                                DB
                                  Thanks, I've been trying to figure out how to make this "alias" with no luck. I'll use your snippet.
                                  So if you include it in your script and I include it mine, and other people put it in theirs, does it start doing weird things to the poor add_group method?
                                    Hmm, thats not helping speed things up for me. Iterating over 7,500 entities and grouping them in all_connected groups takes 187 seconds the way I have it right now.
                                    adding the alias method above to my script makes it take 209 seconds. And as I've mentioned, I've got it spliiting the entities into groups of 1000 so I can see how the slow down is happening. And the method doesn't seem to help. Each block of 1000 takes twice as long as the previous block.
                                    Here's my entire script if you care to look at how I put it together.
                                    require 'sketchup.rb'
                                    		GC.start
                                    			#puts "retry add_group" # trace
                                    		return g
                                    		now = Time.now
                                    		if sel[0]
                                    			ents = sel.to_a
                                    		else
                                    		else
                                    		#this divides the given entities into groups of 1000 and then sends them to be turned into groups
                                    		chunk = 1000
                                    		new_arr = []
                                    		@top_level = ents[0].parent
                                    		count.times do |e|
                                    			puts new_arr.length
                                    		now2 = Time.now
                                    		puts now2-now
                                    	#this takes each given entity, finds all_connected, then adds all that to a groups, unless the given entity is already a part of a group
                                    	#That would happen when an entity it was connected to was already sent to this method in a previous block.
                                    		nowa = Time.now
                                    			if ((ents[0].is_a? Sketchup;;Edge) || (ents[0].is_a? Sketchup;;Face)) && ents[0].parent == @top_level
                                    			else
                                    		nowb = Time.now
                                    		puts "---------"
                                    		puts nowb-nowa
                                    		puts "---------"
                                    	end # maker
                                    #----------Menu system----------
                                    if( $submenu )
                                    	organizer = $submenu
                                    	if !file_loaded?(__FILE__) then
                                    		organizer.add_item("Loose Geometry to Groups") { Clf_loosegroups.main  }
                                    else
                                    	if !file_loaded?('clf_menu_loader') then
                                    		$clf_tools_menu = UI.menu("Plugins").add_submenu("Chris Fullmer Tools")
                                    		$clf_tools_menu.add_item("Loose Geometry to Groups") { Clf_loosegroups.main  }
                                    file_loaded('clf_menu_loader')
                                    file_loaded(__FILE__)
                                      Jim
                                      How do I reproduce the bug?
                                        Jim
                                        Well, I do get a BugSplat every time I try to explode my groups made using your script, Chris.
                                        I am only creating 100 groups total.
                                          Thats odd. I never get bugsplats. I'll see if I can make it splat.
                                          I've attached my file - pre any tweaks I've trined from this thread. I've also included the file I used in the video.
                                          (its large and might take a few moments to load - sorry!
                                          [flash=944,759:2xbb34vu]http://www.chrisfullmer.com/chrisfullmer/forums/group_slowdown.swf[/flash:2xbb34vu]
                                          And again, I'm not sure its a "bug". Seems more like a sketchup issue. It gets slower at making groups when there are already lots in the model. If anyone think s of anything else, great! But don't stay up late thinking about it πŸ˜„
                                          group slowdown.skp
                                          clf_loose2groups.rb
