    Script slows down exponentially - help?
    19 Posts 6 Posters 1.2k Views 6 Watching
    • Chris FullmerC Offline
      Bummer, that did not seem to help. I used group.hidden=true and adding groups still slowed down the more groups there were in the model.
        That's interesting... hmm...
        • AdamBA Offline
          AdamB
          Just for completeness, try hiding them in a hidden Layer.
          I'm presuming its not "creating groups quickly" per se but the need to check every existing group for interaction with the new one that is taking time.
          So if you have N groups in a flat hierarchy is it as slow as N groups in a deeply nested hierarchy (where SU can early out on these tests).
          Adam
            todd burch
            Do you have Outliner open while doing this?
              @Todd, nope, I've got it closed.
              @Adam, I'll try putting them on a new hidden layer. That could be worth trying too.
              I did try grouping them each, then adding the first chunk to a single group, hoping SU would only recognize the 1 big group and then go faster in the next chunk of groups to process - no luck. It was just as slow.
              So I'll try the hidden layer too in an hour or two.
              • Didier BurD Offline
                Didier Bur
                Maybe a problem with the memory. I recently developped a script that creates a bunch of groups on the fly, and first I noticed that entities.add_group is buggy, and second that the more groups there are, the slower the process is.
                So I made an alias of the method "add_group" of the "entities" class, and added the garbage collector in this alias. No more bug splats and a quicker process.
                Put that in your code so the memory is "cleaned" from time to time:
                GC.start
                Hope this helps,
                DB
                  Hi Didier, is there also a file to include? or do I really just need to add the line
                  GC.start
                  somewhere in my script and it will just work?
                  Thanks so much, sounds like the problem I am experiencing and I'll be glad to see a fix for it!
                    Didier Bur
                    Hi Chris,
                    Putting GC.start just before the suspicious instructions will do.
                    No file to include, this is pure Ruby.
                    See: http://www.rubycentral.com/book/ref_m_gc.html
                    Regards,
                    DB
                      Components are not affected by this?
                        Didier Bur
                        No, components aren't affected. The add_group method is buggy because when a script creates a lot of groups on the fly, sometimes the new empty group is stored (as usual) like a component definition, but has NO instance. This leads to a bug splat. Below is the alias method used to avoid the bug:
                        class Sketchup;;Entities
                                alias add_group_su add_group
                                def add_group(*args)
                        	GC.start
                                g=self.add_group_su(*args)
                                while g.class!=Sketchup;;Group
                        		puts "retry add_group" # trace
                         Sketchup.active_model.definitions.purge_unused
                        return g
                        DB
                          Thanks, I've been trying to figure out how to make this "alias" with no luck. I'll use your snippet.
                          So if you include it in your script and I include it mine, and other people put it in theirs, does it start doing weird things to the poor add_group method?
                            Hmm, thats not helping speed things up for me. Iterating over 7,500 entities and grouping them in all_connected groups takes 187 seconds the way I have it right now.
                            adding the alias method above to my script makes it take 209 seconds. And as I've mentioned, I've got it spliiting the entities into groups of 1000 so I can see how the slow down is happening. And the method doesn't seem to help. Each block of 1000 takes twice as long as the previous block.
                            Here's my entire script if you care to look at how I put it together.
                            require 'sketchup.rb'
                            		GC.start
                            			#puts "retry add_group" # trace
                            		return g
                            module Clf_loosegroups
                            	# Make groups of all geometry in the selection set or active_entities.
                            	def Clf_loosegroups.main
                            		now = Time.now
                            		model = Sketchup.active_model
                            		@entities = model.active_entities
                            		sel = model.selection
                            		if sel[0]
                            			ents = sel.to_a
                            		else
                            			ents = @entities.to_a
                            		if Sketchup.version_number < 7000000
                            			model.start_operation "Make Groups"
                            		else
                            			model.start_operation "Make Groups", true
                            		#this divides the given entities into groups of 1000 and then sends them to be turned into groups
                            		chunk = 1000
                            		count = (ents.length/chunk)+1
                            		new_arr = []
                            		@top_level = ents[0].parent
                            		count.times do |e|
                            			place_number = (e*chunk)
                            			new_arr = ents[place_number,chunk]
                            			puts new_arr.length
                            			Clf_loosegroups.maker(new_arr)
                            		model.commit_operation
                            		now2 = Time.now
                            		puts now2-now
                            	#this takes each given entity, finds all_connected, then adds all that to a groups, unless the given entity is already a part of a group
                            	#That would happen when an entity it was connected to was already sent to this method in a previous block.
                            	def Clf_loosegroups.maker(ents)
                            		nowa = Time.now
                            		while ents.length > 0
                            			if ((ents[0].is_a? Sketchup;;Edge) || (ents[0].is_a? Sketchup;;Face)) && ents[0].parent == @top_level
                            				to_group = ents[0].all_connected
                            				ents = ents - to_group
                            				group = @entities.add_group(to_group)
                            			else
                            				ents = ents - [ents[0]]
                            		nowb = Time.now
                            		puts "---------"
                            		puts nowb-nowa
                            		puts "---------"
                            	end # maker
                            #----------Menu system----------
                            if( $submenu )
                            	organizer = $submenu
                            	if !file_loaded?(__FILE__) then
                            		organizer.add_item("Loose Geometry to Groups") { Clf_loosegroups.main  }
                            else
                            	if !file_loaded?('clf_menu_loader') then
                            		$clf_tools_menu = UI.menu("Plugins").add_submenu("Chris Fullmer Tools")
                            		$clf_tools_menu.add_item("Loose Geometry to Groups") { Clf_loosegroups.main  }
                            file_loaded('clf_menu_loader')
                            file_loaded(__FILE__)
                              Jim
                              How do I reproduce the bug?
                                Jim
                                Well, I do get a BugSplat every time I try to explode my groups made using your script, Chris.
                                I am only creating 100 groups total.
                                  Thats odd. I never get bugsplats. I'll see if I can make it splat.
                                  I've attached my file - pre any tweaks I've trined from this thread. I've also included the file I used in the video.
                                  (its large and might take a few moments to load - sorry!
                                  [flash=944,759:2xbb34vu]http://www.chrisfullmer.com/chrisfullmer/forums/group_slowdown.swf[/flash:2xbb34vu]
                                  And again, I'm not sure its a "bug". Seems more like a sketchup issue. It gets slower at making groups when there are already lots in the model. If anyone think s of anything else, great! But don't stay up late thinking about it πŸ˜„
                                  group slowdown.skp
                                  clf_loose2groups.rb
