    NprTools
    extensions
    83 Posts 9 Posters 15.4k Views 9 Watching
      I had RpTools_1_1_IA07t.zip
      when I went to the download page it says: "Version: IA07"
      • Al HartA Offline
        Al Hart
        One other thing (and this may be the one!)
        When you reinstall NprTools, make sure you select NprTools and not RpTools.
        There is an old version of RpTools on the download page which is replacing the newer version of NprTools.
        I'm sure that is the problem.
        I will try to get it fixed. (1/2 or our staff is on vacation this week, so some things are getting a little delayed)
        Al Hart
        IRender nXt from Render Plus
          Doh! 😳 Downloading "Version: IE24b" now... I didn't read properly...
            Why does it look like it's softing out the sketchy shadows?
            And what is the Washout slider?
            • Al HartA Offline
              Al Hart
              I worked hard to try to make the shadows soft. 😄
              Which part of "soft" didn't you want?
              (If you don't want the 5 softer areas (see arrows), then set the number of iterations to 1 - so the soft shadow effect is not used for the Sketchy Shadows.
              If you want the all the shadows darker (more white), then make sure that your "Shadow" material is solid black, since any lightness in the material will make the shadows softer.
              Washout moves the original image more towards white, black or grey. This is helpful when you are using a fairly solid (50% or more) shadow pattern, and want the original drawing to be made darker by the shadows.
              This is a normal image with dark shadow lines
              http://wiki.renderplus.com/images/a/a6/House1-white-SS-d.png
              Here the base image is washed out
              http://wiki.renderplus.com/images/b/be/House1-white-SS-bd.png
              Wash out may make more sense when you are using both sun and shadow lines, and want the base image to be close to grey.
              Al Hart
                Sketchy shadows with soft shadows is a nice feature. I just couldn't work out what to do if I didn't want them. For the Blueprint type of sketch I'm trying to do I prefer them without.
                Looking at the wiki, it seems to be possible to have the shadow texture aligned to the screen and not to the geometry?
                  linea
                  Al
                  NPR tools looks great I haven't tried it yet, but will get around to it soon. Just a thought, would it be possible for the sketchy shadows to display as a series of dots as opposed to lines?
                    You can any any SU textured material as the shadow pattern. 😉
                    • Al HartA Offline
                      Al Hart
                      If you don't want soft shadows, set the iterations to 1. I used to have a check box "Use soft shadows" on the Sketchy Shadows dialog box. Perhaps I will put it back.
                      If you want the texture aligned to the screen, rather than to the faces in the model, use Soft Shadows, rather than Sketchy Shadows. You can still make them "non-soft" with just one iteration, but use the Texture Shadow Color mode to use an image as a mask for the shadows.
                      Also, in your earlier example you have very broad soft shadows. Try using 10 iterations but only 2 days and 15 minutes, and you will get just a little softening at the edges.
                      Al Hart
                      • Al HartA Offline
                        Al Hart
                        We have uploaded a new version of NprTools- IF16.
                        See: Downloads
                        This version has combined Soft Shadows and Sketchy Shadows into a single tab dialog - which uses the same settings for both and which should also be easier to use.
                        We have also added some radio button presets for Shadow Softness and Spread which should make it easier to get the desired effects. (After adding lots of options to let you control shadow softness, patterns, intensity, and other things the application has become rather complex. These radio settings will make it easier to get started. However you can still adjust iterations, days and times as desired in Custom mode.)
                        http://wiki.renderplus.com/images/d/db/Soft-Shadows-Dialog.jpg
                        Al Hart
                        • 5 / 5
