    Render test, please...tomsdesk 2.5d trees?
    extensions
    56 Posts 12 Posters 12.6k Views 12 Watching
      Same forest - seen from lower angle.
      This is where you need more tree variations in different colour tones.
      • T
        tomsdesk
        Thomas, I will now definately consider doing a couple of PR sets to see how it goes. I've shy-ed away from them because the pngs are so much more expensive...bytewise (most of my NPR pngs are way less than 100k, this one is pushing 400k and smaller than most would need to be).
        Would the grayscale "you-color-them" idea still work?
        Really nice example shots BTW...thank you very much for showing the possibilities!
        2.5D Trees & Shrubs!
          I'm personally not that bothered about the filesizes. Storage is cheap. If the pixel dimmensions are the same they will consume the same amount in memory as the compressed images need to be decompressed in order to be used.
          For V-Ray for Sketchup the grayscale doesn't work that well, as VfSU blends them in an odd way. And Even if they did blend it correctly I'd prefer to not have grayscale - because the textures will look flat. You end up with a very limited amount of colours. I'd like to have the varius shades of green in the texture as they look more alive then.
          • T
            tomsdesk
            Full-bore it is then! Soon as I get my move on I'll get started.
            Is this the kind of thing that will trip the rest of y'alls triggers?
            • EdsonE
              Edson
              hi tom,
              i would say PR trees would be at least as desirable as NPR, perhaps even more. i would not doubt buying packages of trees like the ones shown here by thomas.
              http://www.mahfuz.arq.br
                For the sake of insanity I did a test with ~1 000 000 faces - resulting in ~52600 trees. This is with the same tree as in the last test. I didn't optimise the tree trunk.
                I think I'm close to what I can push through the system. When rendering it peaked at 1.8GB RAM usage.
                • GaieusG
                  That's very promising. You could (of course for each project, one by one) export somekind of a background filled with trees and such,use it as a skybox, hdri background or whatever and only use "real 3d" trees in the very close-up of your model. Something like this:
                  You can export such backgrounds straight from SU or from LightUp or Vue... - depending on the "PR realism" you want to achieve...
                  This way it would still look "organic" to the project itself (not a totally different, strange background), keep the file size and navigation reasonable and still achieve some convincing results. Surely shadow directions and the time of the day should more or less match but that's always the case with other backgrounds, too.
                    Yes, for that scale even pure clipmaps would do.
                    What you describe by keeping the level of detail relevant for the current view is the method I use normally.
                    This was merely a test for the sake of ... testing?
                    • GaieusG
                      Surely clipmaps would also do but they still tax rendering time when a lot of them are present in a scene.
                      And yes of course I see you are doing this for a test - it just generated some ideas...
                        Yes, and with VfSU said to support Proxies it'd be interesting to see if an automated Level Of Detail system can be implemented. Have simple lines in SU representing a tree, then have the renderer use different proxy element based on the distance from the camera. That'd be a very nice setup.
                        I'm getting more optimistic in regards to vegetation and SU. 😄
                          Oh, you mean generate a backdrop from an SU model - custom fitted to the project? hmm... grabs thinking-hat
                          • GaieusG
                            Yes, exactly.
                            • 3 / 3
