    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 283.9k Views 66 Watching
      I can't check any more as I've completely reinstalled it.
      But seeing that I've not done anything to the language files I'd say it's a bug in the upgrading process.
        Sorry but where is the link to the new version 1.1.6? 😳
        All the links shown are for the translation or adding lines...but the new version?
        Seems that will be the Duhduh of the day πŸ’š
          It's a bit weird navigation on the site. It all seem to refer to trial versions, but it's all the same actually. http://www.1001bit.com/v1.1/download_registration_v1.1.shtml
            @Thomthom
            So simple indeed 😳 THX β˜€
              Do shapes like that with a scale factor of 1.618 and can do some nice simulations of snail shells etc and other organic creations. πŸ˜„
                Works really like a charm! 😎 (I have not error message) πŸ˜‰
                Infinite possibilities! β˜€
                  And you can of course make some thickness with the Joint Push Pull of Fredo 6 πŸ˜‰
                  • utilerU
                    utiler
                    Awesome, Pilou!!!
                    And more for you, Goh!!!!
                    Just Curious...
                    • G
                      gohch
                      Thanks guys πŸ˜„
                      Pilou, i love that rendering, real cool! πŸ‘ πŸ‘ πŸ‘
                      and thanks to the support and generosity of so many people; the language packs are ready too!
                      here's a list of them (i've bundled the language pack with 1001bit(v1.1.6) into a single zip file for easy setting up)
                      1001bit(v1.1.6) without language pack -->
                      http://www.1001bit.com/download/1001bit(1.1.6).zip
                      1001bit(v1.1.6) in French (thanks to Pilou 😍 )-->
                      http://www.1001bit.com/language_pack/v1.1/fr/1001bit(v1.1.6)_fr_pilou.zip
                      1001bit(v1.1.6) in Chinese Simplified (thanks to Purplewind 😍 ) -->
                      http://www.1001bit.com/language_pack/v1.1/cn/1001bit(v1.1.6)_cn_purplewind.zip
                      1001bit(v1.1.6) in Spanish (thanks to Oxer 😍 )-->
                      http://www.1001bit.com/language_pack/v1.1/sp/1001bit(v1.1.6)_sp_oxer.zip
                      1001bit(v1.1.6) in German (thanks to Burkhard 😍 )-->
                      http://www.1001bit.com/language_pack/v1.1/de/1001bit(v1.1.6)_de_burkhard.zip
                      There's a Chinese (Traditional) version coming soon...
                      Thanks everyone for your support!!! πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„
                      • P
                        purplewind
                        Thanks again Goh, for this awesome toolset
                        http://www.sketchupbar.com
                        • massimoM
                          massimo Moderator
                          I've tried this toolset and after 10m i removed it. With 29$ you have a collection of plugins that you can get for free (and in many cases they work better) like align, Kt tools, trim and extend, fillet, roof, windowizer ecc. plus a duplicate of native SU commands like array, offset ecc. Maybe i missed something...
                            you miss revolve, extrusion along a path,...etc and all pre-build parametrics elements πŸ˜‰
                            • images help inside πŸ˜‰
                              Plus it's neatly packaged with a uniform UI and continuously maintained.
                              • massimoM
                                massimo Moderator
                                Ok, thanks. I'll give it another try.
                                • G
                                  gohch
                                  hi everyone!
                                  Thanks to Charles Tom of http://www.geoinfo.com.tw there's now a language pack for
                                  1001bit tools in Chinese Traditional繁體中文
                                  404 Not Found
                                  (www.1001bit.com)
                                  Thanks Charles for your support and sharing!:)
                                  • aadbuildA
                                    aadbuild
                                    1001 bit is definately a big time saver when modeling. I have done some great animations and client think they took me weeks where they only realy took hours. The rafters, battens and hips are fantastic
                                    Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                                    https://www.plusspec.com
                                    • G
                                      gohch
                                      Thanks aadbuild for your support!
                                      Have been a bit tight on time working on a shadow analysis tool (in collaboration with Takeshi)
                                      see http://www.1001shadows.com
                                      Hope to get back to 1001bit tools by next month.
                                      cheers!
                                      Goh
                                      • C
                                        CrackerJim
                                        I've downloaded the 1001bit tools and also downloaded the help file from their forum. When I open it, it appears to open in a reader application. The table of contents appears on the left pane but regardless of what I click in the left pane, nothing but invalid address message appears in the reading pane.....
                                        any suggestions?
                                        Thanks for any help,
                                        Jim
                                        • G
                                          gohch
                                          πŸ˜„ πŸ˜„ πŸ˜„ Merry Christmas Everyone!!! πŸ˜„ πŸ˜„ πŸ˜„
                                          1001bit version 1.1.7 update is now ready for download!
                                          3 new tools are added into this update:
                                          Rectangular grille tools: convert edges into rectangular sections.
                                          http://www.1001bit.com/forum_imgs/rgrille1.jpg
                                          http://www.1001bit.com/forum_imgs/rgrille2.jpg
                                          Circular grille tools: convert edges into circular sections.
                                          http://www.1001bit.com/forum_imgs/cgrille1.jpg
                                          http://www.1001bit.com/forum_imgs/cgrille2.jpg
                                          both the grille tools only create grilles on a common plane defined by the first 3 points it finds from the selection.
                                          any edges that are not on the plane will be projected onto the plane.
                                          Extrude while maintaining tapering effect.
                                          http://www.1001bit.com/forum_imgs/extrude2.jpg
                                          πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„ Wishing everyone a very Happy Christmas, and all the best in the coming year! πŸ˜„ πŸ˜„ πŸ˜„ πŸ˜„
                                          • GaieusG
                                            Thanks Goh for the update! this whole toolset seems to be very useful not only for architects actually! πŸ‘
                                            I have also "updated" The Daily CatchUp.
                                            Also, if you don't mind, I have renamed the subject of the topic to
                                            [Plugin 1001bit Tools - Architectural tools for SketchUp]
                                            and moved it into our new Plugins forum. This seems to be more straightforward for this topic as it is a discussion between developer and users rather than about ruby methods (or what) between developers.
                                            • 12
                                            • 13
                                            • 7 / 13
