    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    245 Posts 66 Posters 283.9k Views 66 Watching
    • F
      fozmicro
      Hello!!!!
      I think interesting a portuguese (br) translation pack
      • BurkhardB
        Burkhard
        German language ready, including image changes. Should come soon πŸ˜„
        Have fun
        http://www.ia-plus.de
        • G
          gohch
          Hi guys, 2 more language packs ready for download!!!
          Spanish language pack, thanks to Oxer's hardwork πŸ‘ πŸ‘ πŸ‘
          http://www.1001bit.com/discussions/viewtopic.php?f=17&t=54
          German language pack, thanks to Burkhard's hardwork πŸ‘ πŸ‘ πŸ‘
          http://www.1001bit.com/discussions/viewtopic.php?f=17&t=55
          And... Portugues language pack coming soon... courtesy of fozmicro. πŸ‘ πŸ‘ πŸ‘
          It's really encouraging for me to see different people translating 1001bit tools into different languages.
          Many many thanks to everyone's hardwork and support!!!
          GohCH
          • F
            fozmicro
            20% complete translation from portugues (br).
            πŸ€“
              New version with this crazzy Plugin πŸ˜‰ See details here
              http://www.1001bit.com/forum_imgs/revsurf-1.gif
              This tool produce a revolved surface from selected edges, and the edges do not have to be co-planar.
              You can specify the angle, segments along the rotation, and also the scale.
              http://www.1001bit.com/forum_imgs/revsurf-2.gif
              http://www.1001bit.com/forum_imgs/revsurf-3.gif
                That last one looks like the fender of an old car. πŸ˜„
                • G
                  gohch
                  Thanks Pilou, for putting the notification here. I was having problem logging in with Firefox; finally got in with IE. πŸ˜•
                  And you're right about the 'crazzy' tool πŸ˜†
                  I haven't been able to figure out what can you use this 'scaling' function for; but seems like good fun anyway πŸ˜„
                  Other improvements in version 1.1.6 includes:
                  1. sorted out a bug in thepanel dividertool. Please see details in windows and doors topic.
                  2. sorted out a bug in the hip rooftool. You can now generate hip roof directly from extruded top surface.
                  3. Improvement on setting up: no longer need to define path; as long as the 1001bit folder is located within Sketchup's plugins folder; it'll be fine.
                    You can still choose to define custom location for your 1001bit folder. Just keep your original path file (eg. 1001bit_path_win_su7.rb) or create a new path file
                    1001bit_path.rb file with a text editor and have the following line in the file
                  $GH1001bit_path="/your custom path/1001bit"
                  place the file inside Sketchup's plugins folder. note the name of the file is not important, as long as it has a .rb extension and it get run when SU loads.
                  I have not included the language folder in the standard zip file so that it will not overwrite the translated language file that you currently have.
                  However, the images are included. For those who are using language packs with translated images, you'll have to reload the images from the language pack again, after setting up v1.1.6
                  For details on necessary changes in language pack translations, please refer
                  http://www.1001bit.com/discussions/viewtopic.php?f=17&t=48&p=210#p210
                  Thanks for everyone's support and have fun with 1001bit tools! πŸ˜„ πŸ˜„ πŸ˜„
                  Goh C H
                    1. sorted out a bug in the hip roof tool. You can now generate hip roof directly from extruded top surface.
                    Ah, this is a welcomed change. πŸ‘
                    1. Improvement on setting up: no longer need to define path; as long as the 1001bit folder is located within Sketchup's plugins folder; it'll be fine.
                    Another good change. πŸ‘
                      BTw, your FAQ seem to be broken. http://www.1001bit.com/faqs.html Only see the first three FAQ's.
                        Ohh The Hip Roof even lets you select multiple faces now. Nice addition as well.
                        • utilerU
                          utiler
                          Hi GOH, the upgrade sounds great!!!!
                          For some reason, this update is not loading... i get this error...
                          Sorted now... πŸ‘ πŸ‘
                          Just Curious...
                            I got the same error.
                            I had to completely remove 1001bit and reinstall it.
                            • BurkhardB
                              Burkhard
                              If you have the language file in the 1001bit folder, make sure you have set the lines 39 into the main txt files like discribed in
                              http://www.1001bit.com/discussions/viewtopic.php?f=17&t=48&start=10
                              Should work then
                                I've never installed any language files for 1001bit. Bog standard installation.
                                • BurkhardB
                                  Burkhard
                                  Check 1oo1bit folder for the language folder. Take a look at 1oo1bitmenue.txt file if there are both lines included. (t and st 39 )
                                    I can't check any more as I've completely reinstalled it.
                                    But seeing that I've not done anything to the language files I'd say it's a bug in the upgrading process.
                                      Sorry but where is the link to the new version 1.1.6? 😳
                                      All the links shown are for the translation or adding lines...but the new version?
                                      Seems that will be the Duhduh of the day πŸ’š
                                        It's a bit weird navigation on the site. It all seem to refer to trial versions, but it's all the same actually. http://www.1001bit.com/v1.1/download_registration_v1.1.shtml
                                          @Thomthom
                                          So simple indeed 😳 THX β˜€
                                            Do shapes like that with a scale factor of 1.618 and can do some nice simulations of snail shells etc and other organic creations. πŸ˜„
                                            • 12
                                            • 13
                                            • 7 / 13
