    SketchyPhysics3 Release Candidate 1
    64 Posts 18 Posters 37.5k Views 18 Watching
      Alienizer
      Here's your flying car Wacov 😆
      http://tbn3.google.com/images?q=tbn;-c_Xrc1AIozArM;http://www.davidchess.com/words/log200711a.jpg
      Well, I suppose we could have only one setting instead of "material to material". What about...
      Friction: range from 0% to 100%
      The higher the number, the more friction.
      Say...
      Glass will slide very easily on a smooth wood table.
      Glass will slide a bit on sand paper.
      Glass will not slide at all on Scotch tape.
      Sand paper will slide a bit on Scotch tape.
      So we can say...
      Glass.Friction == 1; // because it slides easy on smooth surfaces.
      WoodTop.Friction == 3; // About like glass but not as much.
      SandPaper.Friction == 30; // because it does slides on smooth surfaces, such as when sanding wood.
      ScotchTape.Friction == 100; // because it doesn't slide at all on just about any surfaces.
      Now we can calculate how to affect the velocity of an object when it slides on another...
      if F1 == F2 then V == F1 else V == Abs(F1-F2);
      where...
      F1 = friction of the first object.
      F2 = friction of the second object.
      V the resulting percentage the objects speed should decrease on every frame...
      Glass --> Glass = 1%
      Glass --> WoodTop = 2%
      WoodTop --> Glass = 2%
      Glass --> SandPaper = 29%
      Glass --> ScotchTape = 99%
      SandPaper --> ScotchTape = 80%
      SandPaper --> WoodTop = 27%
      ScotchTape --> WoodTop = 97%
      I'm from Mars and moved to Earth to alienize you. Unfortunately, I became humanized.
      • C
        CPhillips
        Miss a few days, and get left in the dust... So much can change in a week!
        ...oh, on mac, after installation, why do I get the message
        %(#FF0000)[Error Loading File sketchyphysics.rb
        no such file to load -- dl]
        I must have done SOMETHING wrong... tried it twice to no avail...
        Sorry, I forgot a file. Its attached and I will update the ZIP.
        Put this in your plugins/SketchyPhysics3/ folder.
        • W
          Wacov
          I see what you're saying but we're basically stuck with however the physics engine does materials. No way around it, no way to edit the engine, and really no option of changing engines at this point. Sliders in a new window for material config, like you say from 0 to 100%, would be good, but if possible I'd like to be able to set rubber to have high friction against glass, and low against, say, a carpet. The carpet would have quite good friction and the rubber would have very high friction, so if we only used a general system then it wouldn't work realistically. We can't simulate the interaction between the rubber and every fibre in the carpet, so this would be the best solution
            Alienizer
            I see what you mean. But since "material to material" can take a very long time to set up, perhaps we can use my suggestion to at least setup the default settings for "material to material"? It'll be better than all being zero!
            • W
              Wacov
              That's what I mean. A default setting, but with user-controlled exceptions would be perfect; there should be some pre-made templates, say, wood, metal, rubber, glass, stone, fabric, plastic, polysterene, and cardboard... just off the top of my head. This would mean that, as long as people used them, the materials that use exceptions would be cross-compatible between models.
                mptak
                First off...Y'all are incredible. It warms my soul to see people so jazzed about something
                with so much possibility (and reality in a virtual sense)
                However...I am still locked in a semi_autocad world and have found the following snafu.
                If I import a solid model from Autocad, I think that the program assigns names of group#1, group#2, group#3 to all of the solids.
                This seems to cause SP3RC1 to stop working.
                However, if I just used the entity info tool and edit out the names it all works.
                Anyone else have the same problem....I am introducing my Autocad students (it is in the course title) to workflow and this extra step might actually
                be good for them but on the other hand it is maddening when you just want to hook up an xbox controller and throw virtual tomatoes.
                Keep rockin!
                  Sgt.A.Johnson
                  Keep rockin!
                  Ive never had this problem before but throwing virtual tomatoes is a bit of a new one. I hope your joking.
                  • C
                    CPhillips
                    That shouldnt be a problem. I renamed a few objects like that and they still worked. There might be something else going on. Post a model that fails and I'll take a look.
                    • EscapeArtistE
                      EscapeArtist
                      Another "gee whiz!" post:
                      Gotta say thanks to the creator of SP. I'm amazed. I certainly didn't expect it to be such a well thought out program, and as soon as I played with the realtime simulator I was hooked. Fantastic. Now I get to spend even more time banging my head on the keyboard using sketchup while trying to learn a new, complex tool. My wife won't be as thrilled about the plugin as I am... 😄
                      EDIT:
                      Heh, Just got playing with it and already have a question. I created a static ground and a cylinder object, made an end of the cylinder a "thruster" and "launched" it from the ground. After I let off the thrust to let the object fall to the ground, it fell right the ground. Reapplying thrust to arrest the fall bringing it back up to the level of the ground and allowing the object to settle gently onto the plane worked fine.
                      Did I run up against a limit for object interaction/collision?
                      • W
                        Wacov
                        Collisions can only be detected when an object is interesecting another in the given frame... if an object is moving fast enough to be on one side in one frame, and the other side in the next, no collision will be detected. There's a possiblity of raycast-collision detection being introduced, which will accurately detect collisions between objects at any speed.
                        • EscapeArtistE
                          EscapeArtist
                          Good to know. Thanks for the reply.
                            artturbine
                            Windows installer:
                            http://sketchyphysics2.googlecode.com/files/SketchyPhysics3RC1-WinInstaller.exe
                            Mac (and Windows) version as a Zip:
                            http://sketchyphysics2.googlecode.com/files/SketchyPhysics3RC1-MacAndWin-Fixed.zip
                            Edit Mar 30:
                            Updated Mac version with missing .bundle file.
                            [/quote]
                            I am looking forward to trying out sketchy physics on my Mac but when I click on the download link I get this error message
                            Forbidden
                            Your client does not have permission to get URL /files/SketchyPhysics3RC1-MacAndWin-Fixed.zip from this server. (Client IP address: 66.183.157.173)
                            You are attempting to perform an activity that you have insufficient permissions for. If you feel this is in error, please contact the project administrator.
                            any suggestions???
                            • P
                              phy
                              It looks like CPillips is doing some work on the sketchyphysics home page http://code.google.com/p/sketchyphysics2/. you 'll have to wait a little bit before you can download sketchyphsics
                              Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                              • P
                                phy
                                The links work again.
                                • F
                                  FrenchFRI3S
                                  When i build alot i get this error. It said something about not being able to save a dump file when i press play. When i hit ok i just get the send info thing to windows. I'll send a picture. Also does anyone know of a tutorial is for sp3 rc1 or is that for the finnishing version? Thanks CPhillips 😎 👍 👍
                                  SP3 RC1 ERROR
                                  • P
                                    Physicsguy1
                                    Check out the Wiki for information. As for the problem, I don't think it is the size, but sometimes it fails to start. If it persists then let us know.
                                    • F
                                      FrenchFRI3S
                                      Thanks an its happened more than once so far and it may have something to o with the size because it happens when i have a high poly model and when i on't it starts right up. What happens is when i do have a high poly model in there and i start sketchyphysics it will freeze up for a moment and the that message will come up. I will check wiki about that tho. I on't think its a big deal but it could be a big step up for more joints and moving parts. Good luck with it tho. 💚
                                      • halroachH
                                        halroach
                                        I'm getting this error:
                                        Failed to load /Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/dl.bundle
                                        I have placed all of the files from "SketchyPhysics3RC1-MacAndWin-Fixed" into /Library/Application Support/Google SketchUp 7/SketchUp/plugins/ on my mac...
                                        suggestions?
                                        FlexTools - Super Quick Windows, Doors, Slats...
                                        • W
                                          Wacov
                                          Did you empty out the folders? The internal folders in the .zip need to remain intact. Extracting to the plugins folder is the easiest way to go
                                          • halroachH
                                            halroach
                                            The folders are intact. I have extracted the zip as it is, maintaining the folder structure just as I do with every other plugin I have installed. I double checked to see that the dl.bundle file is where it is supposed to be. I tried overwriting it with the dl.bundle that was posted here... but I still get the same error. I'll try removeing all the plugins I have to see if maybe something is interfering...
                                            • 3 / 4
