    SketchyPhysics3 Release Candidate 1
    64 Posts 18 Posters 37.5k Views 18 Watching
    • C
      CPhillips
      I dont know. That how the physics engine is setup.
      • W
        Wacov
        I suppose that could be useful; something like rubber could have the same friction value as rock, but it'd stick to glass really well.
        • W
          Wacov
          What I'm really interseted to know is if we can use multiple physics materials in the static mesh... so you could have slippery mud next to rock and sand, all with their own settings. I've noticed that the realism becomes pretty unreliable if you use more than one static mesh in a large model, so that's not really an option.
            Alienizer
            I think the material interaction should not be done using the "material to material" approach. We should use the laws of physics. In real life, what make rubber stick to glass? Well, there is how porous the object is, its flexibility, how smooth it is. That's 3 things I can think of right now. Having settings such as these for each material would simplify the task, and then we would not need to do material to material.
            I'm from Mars and moved to Earth to alienize you. Unfortunately, I became humanized.
            • W
              Wacov
              Unfortunately, flexible (deformable) geometry is totally impossible with the current engine. You could probably make stuff bounce, but that's it. Bouyancy would be a useful setting, but as far as porous objects... maybe something can increase gradually in density when it enters the bouyancy plane? True fluid simulation has already been ruled out, although some physics engines support it, SU probably can't handle dynamic geometry that complex. I see what you're saying about smoothness though.
              I agree with you, but specific settings could come in handy. Maybe there could be a general blanket effect, but with user-defined exceptions? The laws of physics have already been thrown out of the window 😄 ... flying cars, anyone?
              • B
                BTM
                Miss a few days, and get left in the dust... So much can change in a week!
                ...oh, on mac, after installation, why do I get the message
                %(#FF0000)[Error Loading File sketchyphysics.rb
                no such file to load -- dl]
                I must have done SOMETHING wrong... tried it twice to no avail...
                  Alienizer
                  Here's your flying car Wacov 😆
                  http://tbn3.google.com/images?q=tbn;-c_Xrc1AIozArM;http://www.davidchess.com/words/log200711a.jpg
                  Well, I suppose we could have only one setting instead of "material to material". What about...
                  Friction: range from 0% to 100%
                  The higher the number, the more friction.
                  Say...
                  Glass will slide very easily on a smooth wood table.
                  Glass will slide a bit on sand paper.
                  Glass will not slide at all on Scotch tape.
                  Sand paper will slide a bit on Scotch tape.
                  So we can say...
                  Glass.Friction == 1; // because it slides easy on smooth surfaces.
                  WoodTop.Friction == 3; // About like glass but not as much.
                  SandPaper.Friction == 30; // because it does slides on smooth surfaces, such as when sanding wood.
                  ScotchTape.Friction == 100; // because it doesn't slide at all on just about any surfaces.
                  Now we can calculate how to affect the velocity of an object when it slides on another...
                  if F1 == F2 then V == F1 else V == Abs(F1-F2);
                  where...
                  F1 = friction of the first object.
                  F2 = friction of the second object.
                  V the resulting percentage the objects speed should decrease on every frame...
                  Glass --> Glass = 1%
                  Glass --> WoodTop = 2%
                  WoodTop --> Glass = 2%
                  Glass --> SandPaper = 29%
                  Glass --> ScotchTape = 99%
                  SandPaper --> ScotchTape = 80%
                  SandPaper --> WoodTop = 27%
                  ScotchTape --> WoodTop = 97%
                  • C
                    CPhillips
                    Sorry, I forgot a file. Its attached and I will update the ZIP.
                    Put this in your plugins/SketchyPhysics3/ folder.
                    • W
                      Wacov
                      I see what you're saying but we're basically stuck with however the physics engine does materials. No way around it, no way to edit the engine, and really no option of changing engines at this point. Sliders in a new window for material config, like you say from 0 to 100%, would be good, but if possible I'd like to be able to set rubber to have high friction against glass, and low against, say, a carpet. The carpet would have quite good friction and the rubber would have very high friction, so if we only used a general system then it wouldn't work realistically. We can't simulate the interaction between the rubber and every fibre in the carpet, so this would be the best solution
                        Alienizer
                        I see what you mean. But since "material to material" can take a very long time to set up, perhaps we can use my suggestion to at least setup the default settings for "material to material"? It'll be better than all being zero!
                        • W
                          Wacov
                          That's what I mean. A default setting, but with user-controlled exceptions would be perfect; there should be some pre-made templates, say, wood, metal, rubber, glass, stone, fabric, plastic, polysterene, and cardboard... just off the top of my head. This would mean that, as long as people used them, the materials that use exceptions would be cross-compatible between models.
                            mptak
                            First off...Y'all are incredible. It warms my soul to see people so jazzed about something
                            with so much possibility (and reality in a virtual sense)
                            However...I am still locked in a semi_autocad world and have found the following snafu.
                            If I import a solid model from Autocad, I think that the program assigns names of group#1, group#2, group#3 to all of the solids.
                            This seems to cause SP3RC1 to stop working.
                            However, if I just used the entity info tool and edit out the names it all works.
                            Anyone else have the same problem....I am introducing my Autocad students (it is in the course title) to workflow and this extra step might actually
                            be good for them but on the other hand it is maddening when you just want to hook up an xbox controller and throw virtual tomatoes.
                            Keep rockin!
                              Sgt.A.Johnson
                              Keep rockin!
                              Ive never had this problem before but throwing virtual tomatoes is a bit of a new one. I hope your joking.
                              • C
                                CPhillips
                                That shouldnt be a problem. I renamed a few objects like that and they still worked. There might be something else going on. Post a model that fails and I'll take a look.
                                • EscapeArtistE
                                  EscapeArtist
                                  Another "gee whiz!" post:
                                  Gotta say thanks to the creator of SP. I'm amazed. I certainly didn't expect it to be such a well thought out program, and as soon as I played with the realtime simulator I was hooked. Fantastic. Now I get to spend even more time banging my head on the keyboard using sketchup while trying to learn a new, complex tool. My wife won't be as thrilled about the plugin as I am... 😄
                                  EDIT:
                                  Heh, Just got playing with it and already have a question. I created a static ground and a cylinder object, made an end of the cylinder a "thruster" and "launched" it from the ground. After I let off the thrust to let the object fall to the ground, it fell right the ground. Reapplying thrust to arrest the fall bringing it back up to the level of the ground and allowing the object to settle gently onto the plane worked fine.
                                  Did I run up against a limit for object interaction/collision?
                                  • W
                                    Wacov
                                    Collisions can only be detected when an object is interesecting another in the given frame... if an object is moving fast enough to be on one side in one frame, and the other side in the next, no collision will be detected. There's a possiblity of raycast-collision detection being introduced, which will accurately detect collisions between objects at any speed.
                                    • EscapeArtistE
                                      EscapeArtist
                                      Good to know. Thanks for the reply.
                                        artturbine
                                        Windows installer:
                                        http://sketchyphysics2.googlecode.com/files/SketchyPhysics3RC1-WinInstaller.exe
                                        Mac (and Windows) version as a Zip:
                                        http://sketchyphysics2.googlecode.com/files/SketchyPhysics3RC1-MacAndWin-Fixed.zip
                                        Edit Mar 30:
                                        Updated Mac version with missing .bundle file.
                                        [/quote]
                                        I am looking forward to trying out sketchy physics on my Mac but when I click on the download link I get this error message
                                        Forbidden
                                        Your client does not have permission to get URL /files/SketchyPhysics3RC1-MacAndWin-Fixed.zip from this server. (Client IP address: 66.183.157.173)
                                        You are attempting to perform an activity that you have insufficient permissions for. If you feel this is in error, please contact the project administrator.
                                        any suggestions???
                                        • P
                                          phy
                                          It looks like CPillips is doing some work on the sketchyphysics home page http://code.google.com/p/sketchyphysics2/. you 'll have to wait a little bit before you can download sketchyphsics
                                          Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                                          • P
                                            phy
                                            The links work again.
                                            • 2 / 4
