    [REQ] Lock texture coordinates
    28 Posts 7 Posters 4.0k Views 7 Watching
      dacad
      Thanks for the answer Gaieus.
      A ruby or a sk feature like these is very important because without it we have to texture the mesh everytime we change his form, but if this worked we just have to texture it once and make infinite poses with the mesh while keeping always the same textures position.
      Just for curiosity, no one else thinks this would be usefull or need it for sketchup?
        Of course I think it would be cool.
        From another point of usage imagine that I texture a cylinder with a certain, carved stone pattern and then I bend it with the new Shape bender plugin and all the textures are "stuck" to the geometry and I have a beautifully textured, ribbed arch for a Romanesque or Gothic church.
        So not only "posing" could benefit from something like this. 😉
          dacad
          Completly agree with you Gaieus.
          Because most architectural stuff i've doing is more "cubic" stuff i almost forgot how usefull that could be for more than organic models. But using shape bender, as you said, would have to make a plugin like these compatible with all other modeling plugins, like a plugin working inside other plugin...don't think this is possible or is it?
          Maybe these shoulde be a sketchup 8 request instead of a ruby request...the problem is i really don't believe if it matters or not what we need for them...😞
          • Chris FullmerC Offline
            I have no idea if something like this is possible in Ruby. Seems like it could be. I've never looked at textures because I rarely use them. But I do see how it would be nice if it worked the way you described in some instances.
              Problem is: observers. In order for this to work you need to detect when the model changes. And that is a can of blood-thirsty angry spaceworms.
              What I somewhat imagine a ruby would work: the selected face is set to "lock textures". The ruby then samples the UV coordinates from each vertex (or selected points required). When the geometry changes, the ruby would then reapply the texture co-ordinates.
              Given the headache I've had with observers and UV mapping I'm not sure if I'd touch this with a 10' stick. ...at least not for now...
              Possible if it'd be acceptable to have a manual function to readjust the textures; might make things easier.
                That idea of taking all the UV's and then re-applying them - is that fairly stable? I could incorporate it into shape bender, for eaxmple. So it wouldn't fix the problem outside of shape bender, but at least shape bender would be able to do it. AND I wouldn't have to touch any model observers.
                  When you set textures in SU you take a set of 3D points and specify some co-ordiates on the texture that should relate to them.
                  ie.
                  point1 -> 0.0, 0.0
                  point2 -> 0.5, 0.0
                  point3 -> 0.5, 0.5
                  If point 1-3 was points in a rectangle face, then that would map the texture to tile half across the face.
                  So, what I imagine, is that applying the same UV co-ordinates to the same points when the points move, should make the texture 'lock'.
                  However, your Bender widget subdivides the mesh. So you'd have to sample the UV mapping after you subdivide, but before you apply the transformations.
                    Interesting, thats something I'll look into the next release of shape bender.
                      I'm listening guys, I'm listening... 😳
                      (BTW Thom; this is one aspect I mentioned before)
                        dacad
                        Thanks for the explanation thomthom and Chris Fullmer.
                        I was hoping it would be possible but that's too bad...😞. Even if it were updated manually as thom said it would still be great because i think most people would just want the textured model for the final image and not while modeling, posing or whatever, it wouldn't work just for animations.
                        I'm starting to see ruby as a way for sketchup developers don't work to much...
                          I might be possible. It's just not very easy to do. At least not automatically. UV mapping is one of the areas in SU scripting that currently feel like a bit of black magic.
                            dacad
                            I mean that since ruby was introduced it was at the beggining a great way to add specific functions and automatize some actions, and then turn into part of sketchup develpment itself (every "new" stuff that it's presented it's a ruby plugin like DCs and sandbox, and this brings a dated engine to his knees) and the only hope to solve bugs and limitations of the software (we need a plugin to work as follow me was supost to, or just to draw a basic curve shape...) without google having to do nothing (the users work for advance features and solving bugs in the tools instead of the developers).
                            Keep in mind that we don't have any new modeling tool, animation tool or mapping/texture tool since follow me and sandbox in sketchup 4-5...but i believe that this develpment path was more a marketing decision then a development one, but still a (very) bad marketing decision
                              dacad
                              But back to topic, maybe the best way for this need is to export the mesh to other 3d package texture it there and import it again to set up the final scene, but the big problem here is that importers have big problems with keeping the textures in place with uvwarping or big meshs...But is there any better way to do this??
                                dacad
                                thanks thomthom.
                                That's what i suspected. with so many software i use to each task, i'm starting to mix up shortcuts keys lolol.
                                  A different application might be the way to go at the moment. SU isn't very ideal for rigging. And I'm a believer of using the right tool for the right job. I think that SU might not be the right tool for this.
                                  • W Offline
                                    Whaat
                                    Here are some methods to load and save UV sets. If someone wants to use them to create a 'lock texture' plugin, that's fine with me. 😄
                                    def store_uvs(ents,uvset)
                                    face=0
                                    case uvset
                                    	when 0
                                    		key="uv0"
                                    	when 1
                                    		key="uv1"
                                    	when 2
                                    		key="uv2"
                                    	when 3
                                    		key="uv3"
                                    Sketchup.active_model.start_operation "Save UV set"
                                    for e in ents
                                    	if (e.valid?) and (e.class==Sketchup;;Face)
                                    		polymesh=e.mesh 5
                                    		uvs=polymesh.uvs 5
                                    		for i in (0..uvs.length-1)
                                    			uvs[i]=uvs[i].to_a  #converts the Point 3D objects to arrays so they won't be transformed
                                    		e.set_attribute 'uvs',key,uvs
                                    	face=face+1
                                    	Sketchup.set_status_text("Stored uvs for #{face} faces.")
                                    UI.messagebox "UVs saved for #{face} faces."
                                    Sketchup.active_model.commit_operation
                                    end #function
                                    ###################position a texture on a material from a stored UV set
                                    def position_map(entities,set)
                                    face=0
                                    failed=0
                                    return if set=="SU"
                                    key="uv"+set.to_s
                                    p "positioning map"
                                    p entities
                                    for e in entities
                                    	p e
                                    		uvs=e.get_attribute 'uvs',key    #gets the stored array of uv coordinates for this face for the given uv set
                                    		p uvs
                                    		if uvs
                                    			pos=[]
                                    			polymesh=e.mesh 5   #get a polygon mesh representation of the face
                                    			polygons=polymesh.polygons
                                    			poly_index=0
                                    			begin
                                    				for p in polygons[poly_index]
                                    					point=polymesh.point_at(p.abs)
                                    					if point
                                    						pos.push(point)
                                    						pos.push(uvs[p.abs-1])
                                    				e.position_material e.material, pos, true
                                    				face=face+1
                                    				Sketchup.set_status_text("Loaded uvs for #{face} faces")
                                    			rescue  #this is required because SketchUp sometimes fails to position the texture properly
                                    				poly_index=poly_index+1
                                    				if polygons[poly_index]
                                    					pos=[]
                                    					retry  #try to postion texture again using next polygon in the face
                                    				else
                                    					failed=failed+1
                                    if failed>0
                                    	stext="Unable to load
                                    	UVs for #{failed} faces.  Loaded UVs for #{face} faces."
                                    else
                                    	stext="Loaded UVs for #{face} faces."
                                    #UI.messagebox (stext)
                                    end  #end position map
                                      dacad
                                      WOW, thanks Whaat. Has always you're great!:)
                                      My knowledge in ruby is very limited so can anyone help with this? (or change the name of this topic to "[Request]Lock texture coordinates")
                                      Thanks in advance
                                        remus
                                        Unfortunately it isnt quite as easy as that. Ruby has it's own separate commands that dont necessarily match those that you see in the SU UI.
                                        I suppose you could think of it as ruby seeing a different UI to what the user sees: sometimes the stuff we see matches up with what ruby sees, sometimes ruby sees extra stuff we dont see and sometimes we see stuff ruby doesnt see.
                                          Jackson
                                          I was going to post a request/enquiry regarding this precise issue when I found this post. What baffles me is that this can already be done per individual face via the left click texture position editor (Right click on face>Texture>Position>Enter) which is fine for cuboids, but is pretty much useless when working on large triangulated meshes.
                                          As it's already possible on a per face basis in SU is it not relatively simple to write a ruby which simply repeats this action on all selected faces? Easy for me to say seeing as am and most likely always will be completely useless at programming, but Matthieu Noblet's "Components to Groups" script got me thinking. In principle it does almost exactly what we want- allows you to select geometry/groups/components, then performs a series of right click actions upon it/them. In that case it is:
                                          Select Component>Explode>Group>Deselect>Select Next Component>Explode, Group,... etc.
                                          Could the same principle (or even some of the same code) not be applied to this problem so you select a mesh, and the ruby then starts the sequence: Select Face>Texture (i.e. Open Texture Editor)> Position>Enter>Select Next Face,... etc?
                                          I've had a look in Matthieu's C2G code, but like I said, even basic ruby is beyond me. Matthieu's a very generous guy who I'm sure if requested would be willing to allow someone to edit and redistribute parts of it for a good cause. This ability, combined with all the recent "organic" modelling ruby scripts would be incredibly useful for SU users like myself who would rather keep 3D Max and Rhino OUT of their workflow!
                                          I understand of course (or at least I think I do) that SU has major UV mapping shortfalls- as I understand it, if you stretch/deform a face in SU elasticly, there's no way for SU to stretch the texture accordingly so edges still tile with adjacent faces (though that does make me wonder how Whaat's UV Spherical Mapping tool works?), but even an automation of the current Texture>Position>Enter would be of enormous benefit.
                                          p.s. guess who just spent 2 days texturing a tree! 😢
                                          Jackson
                                            That doesn't lock anything. If you map a texture to a face (quad - or whatever - doesn't matter) and do the Position trick - then when you move an edge or vertex the texture doesn't stick with it.
                                            I wonder if you're asking for something else..?
                                            • 2 / 2
