    Transitions in a pool
    32 Posts 6 Posters 2.6k Views 6 Watching
      coach59
      I don't want to have a one button solution, just want to understand how i can do my project by trying everything I know (a little) with sketchup.
      I tried to paste and copy my transitions and link them with the bottom but no texture appear, so I tried "Follow me"....
      • jeff hammondJ Offline
        i'll have more time later but for now, here's a method using the soap skin bubble plugin which can be downloaded here:
        http://www.tensile-structures.de/sb_software.html
        use the follow me tool for the flat parts: (note the deep end and shallow end are different radii cut off a different heights to create a level top)
        fill in the blend using a soap skin:
        after smoothing:
        this is the fast method and visually, it will look right. That said, you can't really use this method to generate working drawings (well, unless the pool is going to be concrete because precise measurements aren't so important when using mud for this type of stuff)
          coach59
          nice pedagogy Jeff and the plug in semm really nice for what i want to do. So that means if I want to create complexe curves pool soap skin is ideal.
          So for the deep end and side of water fall is nice too.
          I don't understand why the little part is not smooth as the deep end I tried...
            you should check out the weld ruby. basically, it makes segments that are joined act as a single line. when you extrude a welded line, it will come out smooth instead of having all the lines as in your drawing.
            people that don't even like using rubies still have this one πŸ˜„
            http://www.smustard.com/script/Weld
            [edit] that is, if you're talking about what i think you're talking about.
              @coach59 said:
              I don't want to have a one button solution, just want to understand how i can do my project by trying everything I know (a little) with sketchup...
              Sorry, I didn't mean like that. What I was trying to say is that this project could (probably) be done by using several (or at least a few) tools not just one.
              SoapSkin and Bubble is generally an ideal tool for it however you will need to "stitch" your pool together from more pieces as well as you will need to experiment with the plugin before reaching the desired result.
              The meshes created with the SSB plugin are different from the ones created with the follow me tool Plus it's a group which you should explode once you are satisfied with the shape (only then because after exploding, you won't be able to edit it as a SSB mesh any more).
              After the explosion, the side edges of the SSB mesh should "merge" with the edges of the other meshes thus making one, continuous surface after smoothing.
              To smooth the whole surface, triple click on it (everything will be selected) then right click on the selection and choose "Soften/smooth edges" from the context menu. A dialog will pop op where check "smooth coplanar edges" then pull the slider to the right until everything gets smooth. If you encounter some "stubborn" lines that don't want to smooth (sometimes it happens), instead of pulling the slider too much to the extreme right (over 90 degrees for instance), use the Ctrl+Eraser tool to soften them individually.
                coach59
                I have sketchup 6, I can't open your file.
                I uploaded my last file where I can't use soap skin bubble plug in...and I don't know why. I select more than 3 edges on my transitions. I created more than 3 horizontal edges, and can't creat a skin....can't use SSB
                http://img6.hostingpics.net/pics/411455test5.jpg
                  For the SSB plugin you need to select a series of edges (at least three) that form [url]a closed loop[/url]. In your model, there are no edges that would make a closed loop. If you go closer, you'll also notice that many of the edges of the current faces do not even meet each other so even closing them on the top wouldn't help much.
                    coach59
                    So do I need to rebuilt the transitions ? or create a "group of edges" ?
                    One of the matter for me as a beginner, was to link directly the transitions with bottom, is there a way to do that? (like selecting a point on the transition and ask to link with bottom?
                      Problem is that the edges of the (curved) surfaces of your sides do not meet (and merge) with the bottom face. There's a gap between them therefore you'll never achieve a smooth transition between the sides and the bottom.
                      This also "results" in the lack of closed loops which would be needed for SSB to carry on modelling the pool.
                        See what I mean:
                          OK, I've made some modifications in your skp file and what is already done in there is okay. I could even make the SSB surface on one segment (closing the loop on the top -see attached file). However there are still some glitches in the file, see this screenshot. Without fixing them, you won't be able to perform the skinning.
                          (I saved the skippy back to version 6 for you)
                          test5-1.skp
                          • soloS Offline
                            Using SDS, just an idea.
                            http://img223.imageshack.us/img223/6848/pol1a.gif
                              BTW Pete, why didn't you "challenge" the SDS tutorial contest?
                              I mean with so much "experience" in organic modelling, you could probably have made some really nice examples.
                                coach59
                                SDS ?
                                For the endpoint, I think I have the solution, I put the axis (green/blue/red..) where I want to my endpoint go to link. Then I can move it.
                                I created a group can push BUD en X/Y fonction on SSB but not skin.
                                I changed ratio and pressure on test 5-1.
                                I think I m not enough patient.....or "brilliant"
                                test5-1c.skp
                                • soloS Offline
                                  SDS = Subdivide and smooth, IMO the best way to achieve this and can be pretty accurate if you get your proxy right.
                                  Csaba, regarding the competition, there are a few reasons, one, I had some work come in that took a lot of my time, and as you know doing a good tutorial does take time and especially if I did one, the expectations would have been much higher. So I guess I was scared to fail and never had the time to succeed.
                                    coach59
                                    I saw too Deform Plugin discussion that would be great too, but it doesn't exist.
                                      @solo said:
                                      ...especially if I did one, the expectations would have been much higher. So I guess I was scared to fail and never had the time to succeed.
                                      Well, according to Dale, there were no crowds taking part unfortunately.
                                      What deform plugin do you mean?
                                      SSB does indeed needs some patience until you get the hang of it. Don't get distracted or discouraged by the initial lack of immediate success.
                                        coach59
                                        There is a version 6 there now for you.
                                        for what ?
                                        Gaieus you helped me a lot by pointing my mistakes; I will try again to achieve the project to understand SSB. I am sure I am near to understand.
                                        For the deform plugin it is a topic about an idea for this plug in
                                        http://forums.sketchucation.com/viewtopic.php?f=180&t=19321
                                          Ah, I remember that topic. It's a cool idea however it's not been implemented yet.
                                          • soloS Offline
                                            Another way of using SDS.
                                            [flash=480,360:190vhwqi]http://www.youtube.com/watch/v/FYQESyCetMA[/flash:190vhwqi]
