Transitions in a pool
hello,
I'd like to draw transitions in a pool which have different heights and radius.
then put a texture...
I tried different ways but I can't do it correctly.
I'm not sure exactly what you are asking here, but maybe this thread will be useful.
http://www.sketchucation.com/forums/scf/viewtopic.php?f=79&t=16891&p=150952&hilit=pool#p150952 -
yes of course.
'transitions in a pool' -- that means round walls. the skin ruby would just connect with straight lines so rule that one out.
it's hard for me to advise without knowing how accurate you're trying to be (the more accurate, the more time and techniques needed).. the follow me tool (or one of it's ruby variations) will cover the majority.. soap skin bubble or subdivide/smooth will handle the blends between radii.
this pool was designed in sketchup only. it has multiple heights and radii so it is possible to do what you want.
nice job for the pool, i never seen this bowl...
I deleted the edge, did the little part that is flat with the radius I want by using "follow me". then for the deep end, "Follow me" doesn't work.
bad result our manipulation for me
You cannot achieve a varying cross section of the extruded face with the Follow me tool. I think there won't be a "one button" solution for such a shape but combining methods and plugins suggested above can give you a desired result.
I don't want to have a one button solution, just want to understand how i can do my project by trying everything I know (a little) with sketchup.
I tried to paste and copy my transitions and link them with the bottom but no texture appear, so I tried "Follow me"....
i'll have more time later but for now, here's a method using the soap skin bubble plugin which can be downloaded here:
http://www.tensile-structures.de/sb_software.htmluse the follow me tool for the flat parts: (note the deep end and shallow end are different radii cut off a different heights to create a level top)
fill in the blend using a soap skin:
after smoothing:
this is the fast method and visually, it will look right. That said, you can't really use this method to generate working drawings (well, unless the pool is going to be concrete because precise measurements aren't so important when using mud for this type of stuff)
nice pedagogy Jeff and the plug in semm really nice for what i want to do. So that means if I want to create complexe curves pool soap skin is ideal.
So for the deep end and side of water fall is nice too.
I don't understand why the little part is not smooth as the deep end I tried...
you should check out the weld ruby. basically, it makes segments that are joined act as a single line. when you extrude a welded line, it will come out smooth instead of having all the lines as in your drawing.
people that don't even like using rubies still have this one
http://www.smustard.com/script/Weld[edit] that is, if you're talking about what i think you're talking about.
@coach59 said:
I don't want to have a one button solution, just want to understand how i can do my project by trying everything I know (a little) with sketchup...
Sorry, I didn't mean like that. What I was trying to say is that this project could (probably) be done by using several (or at least a few) tools not just one.
SoapSkin and Bubble is generally an ideal tool for it however you will need to "stitch" your pool together from more pieces as well as you will need to experiment with the plugin before reaching the desired result.
The meshes created with the SSB plugin are different from the ones created with the follow me tool Plus it's a group which you should explode once you are satisfied with the shape (only then because after exploding, you won't be able to edit it as a SSB mesh any more).
After the explosion, the side edges of the SSB mesh should "merge" with the edges of the other meshes thus making one, continuous surface after smoothing.
To smooth the whole surface, triple click on it (everything will be selected) then right click on the selection and choose "Soften/smooth edges" from the context menu. A dialog will pop op where check "smooth coplanar edges" then pull the slider to the right until everything gets smooth. If you encounter some "stubborn" lines that don't want to smooth (sometimes it happens), instead of pulling the slider too much to the extreme right (over 90 degrees for instance), use the Ctrl+Eraser tool to soften them individually.
I have sketchup 6, I can't open your file.
I uploaded my last file where I can't use soap skin bubble plug in...and I don't know why. I select more than 3 edges on my transitions. I created more than 3 horizontal edges, and can't creat a skin....can't use SSB
For the SSB plugin you need to select a series of edges (at least three) that form [url]a closed loop[/url]. In your model, there are no edges that would make a closed loop. If you go closer, you'll also notice that many of the edges of the current faces do not even meet each other so even closing them on the top wouldn't help much.
So do I need to rebuilt the transitions ? or create a "group of edges" ?
One of the matter for me as a beginner, was to link directly the transitions with bottom, is there a way to do that? (like selecting a point on the transition and ask to link with bottom?
Problem is that the edges of the (curved) surfaces of your sides do not meet (and merge) with the bottom face. There's a gap between them therefore you'll never achieve a smooth transition between the sides and the bottom.
This also "results" in the lack of closed loops which would be needed for SSB to carry on modelling the pool.
See what I mean:
OK, I've made some modifications in your skp file and what is already done in there is okay. I could even make the SSB surface on one segment (closing the loop on the top -see attached file). However there are still some glitches in the file, see this screenshot. Without fixing them, you won't be able to perform the skinning.
(I saved the skippy back to version 6 for you)
Using SDS, just an idea.
BTW Pete, why didn't you "challenge" the SDS tutorial contest?
I mean with so much "experience" in organic modelling, you could probably have made some really nice examples.
