    [Plugin] [CityGen] - Street Generator [WIP] (0.5.2a)
    124 Posts 37 Posters 135.4k Views 37 Watching
      On the left
      Produde by Jim Foltz + Street Generator By ThomThom + Projection Random Pushpull by Didier Bur
      That one looks like it could be the start of an ancient building ruin. ...that'd be interesting to put through a render...
        @21d said:
        always wanted to do one for myself but again due to my lack of knowledge about this topic,
        never got the chance to do one, UNTIL NOW
        Well,.. I have to confess: I make stuff up as I go along. πŸ˜‰ Lack of knowledge is no hinder. hehe
        Once we got this project rolling, at some point I'd like to set up a thread titled "Build Rome in a Day". πŸ˜„
        @21d said:
        Little Big Project
        I like that name. πŸ˜„
          Your plug can be used also for makes buildings, bricks and parpen πŸ˜‰
          Here
          On the left
          Protrude by Jim Foltz + Street Generator By ThomThom + Projection Random Pushpull by Didier Bur
          On the right
          Protrude by Jim Foltz + Street Generator By ThomThom + Join PushPull by Fredo6
            Hei ThomThom,
            How difficult would it be to make the Street Generator accept a radius value of 0? I don't have much opportunity to draw streets right now but I can see some possible other applications.
            Ha det bra.
            Dave
              sepo
              Thom, I think pavements should be part of the street generator. It would be useful to have ability to control width.
              Btw would it be possible to control radius per individual street. In real life the radius is pretty much variable and depends on visibility...While we are on it would it be possible to include option for visibity splays as well.
                I was wondering if the module that splits the blocks into parcels should do that... ?
                It would need some rewiring of the code to do so. Something I've set aside to look into later.
                  @dave r said:
                  Hei ThomThom,
                  At the moment, is you set the Minimum Rounding Angle (weird name - this'll get cleaned up when I get a webdialog working with better explanation and illustrations.) to more than 180 degrees there won't be any rounding.
                  @dave r said:
                  Ha det bra.
                  Mange takk. πŸ˜„
                    Tusen takk. πŸ˜‰
                    Except for a few other words like lutefisk, lefse, gammelost and some boat-related words, I've about used up my Norwegian. πŸ˜„
                      Sounds like you got a good education in Norwegian traditions. πŸ˜„
                        I'm Norwegian by marriage. πŸ˜† My 5 year old son knows more Norwegian than I do, though.
                          sepo
                          Visibility splays maybe too much to ask . It is relating to junctions and minimum amount of visibility required for vehicles to access main roads or roads general.It determines the building line and type of landscaping. I am thinking loud as I am hoping that tool will be more than for play. Here is just one example of it.
                          http://www.wakefield.gov.uk/NR/rdonlyres/6CB5C5B1-058A-4589-856E-97D1BDF8FABC/0/Highways_PlanningGuidanceNotes.pdf
                          Here is complete manual for designing streets
                          http://www.dft.gov.uk/pgr/sustainable/manforstreets/
                          Pavements, pedestrian and cycle routes are realy in public domain and not in private ownership (with few exception) and as such controlled by highway authority, that is at least in UK, and as such require particular standards.
                          • Chris FullmerC
                            There is a balance between level of automation and level of reality I think. The more automated something is, the harder it is to make it create a realistic, true to life solution. To get a true solution, you can only automate small discreet tasks. It's impossible to feed a script a series of road centerlines and have it come up with a complete accurate city.
                            So I think the conversation that needs to happen is - exactly what variables would need to be known in order to design streets accurately from an urban designers view? The script would need to know the land use types of each street and block and then the designer would have to first input into the script how to react to every possible scenario.
                            I think something like this is do-able, but it would have to be very controlled what variables it needs. And I think it would need a LOT of data and parameters put into it before any reasonable results get output.
                            Just some thoughts. It would be interesting to develop, but an accurate automated city planning tool is a big undertaking.
                              How would splay fit into the generator? It'd adjust each corner radius?
                              Or would it be some extra visualisation?
                              I could imagine this is something that could be extended further down the line. But it'd be a way off. Maybe something to go into a commercial plugin. Like Modulor's.
                              When you move from illustration to simulation things are getting a whole new dimension. There'd have to be a much greater 'knowledge' by the script to calculate thing properly. And that also means the people writing it needs some know-how to the subject.
                              • K
                                kwistenbiebel
                                ...as long as it remains easy to use, I would say.
                                Parametric solutions tend to become quite complicated in their attempt to be easy and complete. πŸ˜„ (e.g Revit...)
                                  Which I why we're keeping it simple for now. We can start looking into more complicated stuff later. And then I'm wondering if it'd be a separate module.
                                    I just updated the OP with a screenshot from 0.5.0 which I'm working on. Added variable street width.
                                    I wonder if there should be an option to Radius: Distance From Corner. That you set the length from the corner where the radius should begin. Question is: what would be the desired default option?
                                    • mitcorbM
                                      mitcorb
                                      Thomthom:
                                      you asked what default distance from corner? In my city, the ordinances require a minimum setback from corner of 40 feet, or approx 12 meters. I believe there is some confusion here whether this should be measured from the intersection of the centerlines or from the intersection of the edges of the streets.
                                      In practical terms, this minimum distance would not be safe if the streets have higher speed limits for vehicles. The setback distance should be established as a function of time as well as distance. But I digress.
                                      Sincerely,
                                      mitcorb
                                        No, if people preferred to set the radius of the corner (from the edge corner) or to specify the distance away from the edge corner to where the radius will begin.
                                        Currently it simply rounds the edge corner by a given radius.
                                        At the moment this would be up to the user to work out. Calculating the radius by the estimated traffic speed would be an advanced feature for later.
                                        At the moment this is as a simple tool for quick visualisation. Mostly for city area, so you'd just enter the average radius you want.
                                        • Chris FullmerC
                                          I agree, simple radius is great.
                                          And I forgot, did we decide that the street generator should create the sidewalks, or is that going to bein the block module? Or de we plan on their being a sidewalk module?
                                            Jernej Vidmar
                                            Maybe It wouldn't be bad if Street Generator would automatically assign different corner radius based on width of the roads connecting? Something like (in pseudocode):
                                            if both_roads == 6m
                                               radius = 4m
                                            elsif road1 == 6m && road2 == 12m
                                               radius = 5m
                                            else #both roads == 12m
                                               radius = 6m
                                            just an idea..
                                            • 2 / 7
