    [Plugin] [CityGen] - Street Generator [WIP] (0.5.2a)
    124 Posts 37 Posters 133.4k Views 37 Watching
      rv1974
      I have this:
      Error Loading File street_gen.rb
      undefined method `menu' for City_Gen:Module 😞
        @rv1974 said:
        I have this:
        Check the "Requirements" - this is a module plugin that depend on another plugin. The comment to the download also points out where it's suppose to be stored as well.
          hmm.. I suppose I could make the module check if the core is loaded and that it's located in the correct location. I can see this being a recurring confusion.
            rv1974
            It works and it's so tasty. Thanks!
            1/ Will it support 0 widht for filleting?
            2/ There's wrong result in a simple L turn: inner radius=outer one (I guess it shuld be based on the offset principle)
              You mean just rounding the edges, not creating the road surfaces?
              Or do you mean no corner radius? (If so, set the corner radius threshold to 180 degrees)
              Yea, left and right edge doesn't relate to each other. All corners get the same radius. I was thinking that the use was more to round the corners in a city environment than generating curved roads. As it is today, it's 'per design'. Keeping things simple. Though I'll keep in mind that it could generate a curve between two edges when there's not an intersection.
                Added ability to work out the blocks between the streets. Currently only finds the ones completely confined by roads. But hope to be able to detect more.
                Is 'blocks' the right word?
                Should this feature be a separate module?
                  21D
                  hoi Thom,
                  I just downloaded the Core and the street gen,
                  placed the core file in the plugins folder, and then placed the street gen file in the core folder,
                  but when i load SU, it gives me this error:
                  Error Loading File city_gen.rb
                  C;/PROGRA~1/Google/GOOGLE~2/Plugins/City_Gen/street_gen.rb;75; syntax error
                  i then went and deleted the street gen file, and loads normally with only the core RB
                  i can find the city gen in the tools dropdown in both cases but only in the later can i load SU with out the error, would you know why???
                  "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                  Le Corbusier
                    Sorry, my bad. A last second typo slipped in. Updated.
                    Thanks for catching that. πŸ˜„
                      dtrarch
                      Hi Thomthom
                      Works perfect now with street_gen.rb in the City_Gen Folder.
                      Very nice idea and lots of fun to play with as it is.
                      Thx a bunch
                      dtr
                        21D
                        hey no prob mate,
                        I am one of those self proclaimed "BETA TESTERS" LOL πŸ˜„
                        I am not at work right now so I won't be able to test it out again until tomorrow
                        but be assured that I am really into this great project of you guys,
                        because I for one am one of those users who know nothing of building "cities" 😳
                        and being able to make one from scratch without much knowledge is an edge for me,
                        because i usually see a lot of great renders of city mock ups
                        and always wanted to do one for myself but again due to my lack of knowledge about this topic,
                        never got the chance to do one, UNTIL NOW.... πŸ˜„ well maybe not exactly now but in the near future, thanks to you guys.
                        again mate it's no problem
                        and thnx for all the effort you and all the other Ruby masters are putting in this Little Big Project πŸ‘ πŸ˜„
                        Le Corbusier
                          On the left
                          Produde by Jim Foltz + Street Generator By ThomThom + Projection Random Pushpull by Didier Bur
                          That one looks like it could be the start of an ancient building ruin. ...that'd be interesting to put through a render...
                            Well,.. I have to confess: I make stuff up as I go along. πŸ˜‰ Lack of knowledge is no hinder. hehe
                            Once we got this project rolling, at some point I'd like to set up a thread titled "Build Rome in a Day". πŸ˜„
                            @21d said:
                            Little Big Project
                            I like that name. πŸ˜„
                              Your plug can be used also for makes buildings, bricks and parpen πŸ˜‰
                              Here
                              On the left
                              Protrude by Jim Foltz + Street Generator By ThomThom + Projection Random Pushpull by Didier Bur
                              On the right
                              Protrude by Jim Foltz + Street Generator By ThomThom + Join PushPull by Fredo6
                                Hei ThomThom,
                                How difficult would it be to make the Street Generator accept a radius value of 0? I don't have much opportunity to draw streets right now but I can see some possible other applications.
                                Ha det bra.
                                Dave
                                  sepo
                                  Thom, I think pavements should be part of the street generator. It would be useful to have ability to control width.
                                  Btw would it be possible to control radius per individual street. In real life the radius is pretty much variable and depends on visibility...While we are on it would it be possible to include option for visibity splays as well.
                                    I was wondering if the module that splits the blocks into parcels should do that... ?
                                    It would need some rewiring of the code to do so. Something I've set aside to look into later.
                                      @dave r said:
                                      Hei ThomThom,
                                      At the moment, is you set the Minimum Rounding Angle (weird name - this'll get cleaned up when I get a webdialog working with better explanation and illustrations.) to more than 180 degrees there won't be any rounding.
                                      @dave r said:
                                      Ha det bra.
                                      Mange takk. πŸ˜„
                                        Tusen takk. πŸ˜‰
                                        Except for a few other words like lutefisk, lefse, gammelost and some boat-related words, I've about used up my Norwegian. πŸ˜„
                                          Sounds like you got a good education in Norwegian traditions. πŸ˜„
                                            I'm Norwegian by marriage. πŸ˜† My 5 year old son knows more Norwegian than I do, though.
                                            • 1 / 7
