    [Plugin] [CityGen] - Street Generator [WIP] (0.5.2a)
    124 Posts 37 Posters 137.8k Views 37 Watching
      This plugin is a work in progress. It's made public because it is a collaboration project.
      This is in it's very early beginning, so lots of things will change, and lots of bugs are to be expected. Feel free to share your ideas or join in on this project. See this thread for the discussion of the overall project. This thread is the development thread for this specific module.
      Street Generator
      Generates streets from a set of centre line edges.
      Current Properties Dialogue
      Version 0.4.0 Adds option to generate faces for the blocks between the streets. (Separate module?)
      Option to generate faces for blocks.
      Preview of 0.5.0a
Variable street width
      The streets can have custom sizes - defined by the material applied to them. The properties are set in the material name. A street manager windows is planned, but not yet complete. Currently the only way to modify the street properties is manually editing the material name.
      Example of material name: CG_Street_Main_W:20000mm
      • CG_Street_Main_W:20000mm - Materials defining streets must start with this.
      • CG_Street_Main_W:20000mm - Name of the Street. Not currently used - will be used later in the Street Manager.
      • CG_Street_Main_W:20000mm - Defines the width of the street.
      Requirements
      • CityGen - Core (0.1.3a)
      # CHANGELOG
      # 0.1.0a - 15.05.2009 (Thom)
      #		 * Initial build. Offset edges into streets.
      # 0.2.0a - 24.05.2009 (Thom)
      #		 * Rounded corners.
      # 0.3.0a - 30.05.2009 (Thom)
      #		 * Rounded corners are now created as part of the face itself. No more separate group.
      # 0.3.1a - 31.05.2009 (Thom)
      #		 * Added check for the core and correct path installation.
      # 0.3.2a - 31.05.2009 (Thom)
      #		 * Fixed a bug in the core installation check.
      # 0.4.0a - 31.05.2009 (Thom)
      #		 * Finds the blocks between the streets and generates faces.
      #        * Tags generated geometry.
      #        * Version constant.
      # 0.4.1a - 01.06.2009 (Thom)
      #		 * Fixed a syntax error.
      # 0.5.0a - 02.06.2009 (Thom)
      #		 * Variable street width.
      # 0.5.1a - 09.06.2009 (Thom)
      #		 * First draft to webdialog.
      # 0.5.2a - 11.06.2009 (Thom)
      #		 * Some cleanups.
      #		 * Added separate submenu for Streets.
      Developer Log
      Generate Geometry
      The streets generated is marked with an attribute dictionary named: 'CG_Streets'
      The blocks between the streets is marked: 'CG_Block'
      CityBuilder-Street 2.skp
      Version 0.5.2a - Unpack into the CityGen module folder.
        rv1974
        I have this:
        Error Loading File street_gen.rb
        undefined method `menu' for City_Gen:Module 😞
          @rv1974 said:
          I have this:
          Check the "Requirements" - this is a module plugin that depend on another plugin. The comment to the download also points out where it's suppose to be stored as well.
            hmm.. I suppose I could make the module check if the core is loaded and that it's located in the correct location. I can see this being a recurring confusion.
              rv1974
              It works and it's so tasty. Thanks!
              1/ Will it support 0 widht for filleting?
              2/ There's wrong result in a simple L turn: inner radius=outer one (I guess it shuld be based on the offset principle)
                You mean just rounding the edges, not creating the road surfaces?
                Or do you mean no corner radius? (If so, set the corner radius threshold to 180 degrees)
                Yea, left and right edge doesn't relate to each other. All corners get the same radius. I was thinking that the use was more to round the corners in a city environment than generating curved roads. As it is today, it's 'per design'. Keeping things simple. Though I'll keep in mind that it could generate a curve between two edges when there's not an intersection.
                  Added ability to work out the blocks between the streets. Currently only finds the ones completely confined by roads. But hope to be able to detect more.
                  Is 'blocks' the right word?
                  Should this feature be a separate module?
                    21D
                    hoi Thom,
                    I just downloaded the Core and the street gen,
                    placed the core file in the plugins folder, and then placed the street gen file in the core folder,
                    but when i load SU, it gives me this error:
                    Error Loading File city_gen.rb
                    C;/PROGRA~1/Google/GOOGLE~2/Plugins/City_Gen/street_gen.rb;75; syntax error
                    i then went and deleted the street gen file, and loads normally with only the core RB
                    i can find the city gen in the tools dropdown in both cases but only in the later can i load SU with out the error, would you know why???
                    "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                    Le Corbusier
                      Sorry, my bad. A last second typo slipped in. Updated.
                      Thanks for catching that. πŸ˜„
                        dtrarch
                        Hi Thomthom
                        Works perfect now with street_gen.rb in the City_Gen Folder.
                        Very nice idea and lots of fun to play with as it is.
                        Thx a bunch
                        dtr
                          21D
                          hey no prob mate,
                          I am one of those self proclaimed "BETA TESTERS" LOL πŸ˜„
                          I am not at work right now so I won't be able to test it out again until tomorrow
                          but be assured that I am really into this great project of you guys,
                          because I for one am one of those users who know nothing of building "cities" 😳
                          and being able to make one from scratch without much knowledge is an edge for me,
                          because i usually see a lot of great renders of city mock ups
                          and always wanted to do one for myself but again due to my lack of knowledge about this topic,
                          never got the chance to do one, UNTIL NOW.... πŸ˜„ well maybe not exactly now but in the near future, thanks to you guys.
                          again mate it's no problem
                          and thnx for all the effort you and all the other Ruby masters are putting in this Little Big Project πŸ‘ πŸ˜„
                          Le Corbusier
                            On the left
                            Produde by Jim Foltz + Street Generator By ThomThom + Projection Random Pushpull by Didier Bur
                            That one looks like it could be the start of an ancient building ruin. ...that'd be interesting to put through a render...
                              Well,.. I have to confess: I make stuff up as I go along. πŸ˜‰ Lack of knowledge is no hinder. hehe
                              Once we got this project rolling, at some point I'd like to set up a thread titled "Build Rome in a Day". πŸ˜„
                              @21d said:
                              Little Big Project
                              I like that name. πŸ˜„
                                Your plug can be used also for makes buildings, bricks and parpen πŸ˜‰
                                Here
                                On the left
                                Protrude by Jim Foltz + Street Generator By ThomThom + Projection Random Pushpull by Didier Bur
                                On the right
                                Protrude by Jim Foltz + Street Generator By ThomThom + Join PushPull by Fredo6
                                  Hei ThomThom,
                                  How difficult would it be to make the Street Generator accept a radius value of 0? I don't have much opportunity to draw streets right now but I can see some possible other applications.
                                  Ha det bra.
                                  Dave
                                    sepo
                                    Thom, I think pavements should be part of the street generator. It would be useful to have ability to control width.
                                    Btw would it be possible to control radius per individual street. In real life the radius is pretty much variable and depends on visibility...While we are on it would it be possible to include option for visibity splays as well.
                                      I was wondering if the module that splits the blocks into parcels should do that... ?
                                      It would need some rewiring of the code to do so. Something I've set aside to look into later.
                                        @dave r said:
                                        Hei ThomThom,
                                        At the moment, is you set the Minimum Rounding Angle (weird name - this'll get cleaned up when I get a webdialog working with better explanation and illustrations.) to more than 180 degrees there won't be any rounding.
                                        @dave r said:
                                        Ha det bra.
                                        Mange takk. πŸ˜„
                                          Tusen takk. πŸ˜‰
                                          Except for a few other words like lutefisk, lefse, gammelost and some boat-related words, I've about used up my Norwegian. πŸ˜„
                                            Sounds like you got a good education in Norwegian traditions. πŸ˜„
