    [Request] 'Clever Clay' mode
    34 Posts 13 Posters 6.5k Views 13 Watching
      Kerkythea can also do this. In fact, you can already export your model as a clay model which will then render everything BUT transparent/reflective (say "thin glass") materials clay.
      Ah yes, and it's free.
      (Sorry Sid, I couldn't resist) 😉
        sepo
        Lol...I have not realised you have become KB as well.
          I might guess what "K" means but what about "B"?
            @pixero said:
            I'm very interested in this too.
            Is there a way to go back to previous materials or should you save a special file for it?
            Maybe Thomthom could make it work with Vray?
            I'm not sure how you would revert back positioned textured faced. Think that's going to be problematic.
            And even more so with V-Ray material; 100% impossible as there's to access to the special layers and materials in V-Ray. The only way to remove all the extra reflection/refrection,bumpmaps etc would be to delete the V-Ray attribute dictionary. To do so, V-Ray must be unloaded while you do that, otherwise it'll restore the setting when you save. V-Ray only reads the V-Ray data in the .skp file when you open the models; from that point it only writes back. Removing the V-Ray attributes means you loose all your V-Ray settings as well.
              sepo
              Kerky Bashers to quote Free Agent. 😉
                MrWip
                Gaieus,
                I know about Kerkythea, I'm also working with it... but what I'm looking for is something that works inside sketchup, without regards for the render apps use afterward.
                If it change well the materials, then you can use your model in Vray, Kerkythea, Artlantis, or any other, just as a classic model.
                And after thomthom answer, I think that this plugin will be destructive : save your model, turn it into clay with transparency, render it, and go back to the previous save ( or just undo if it's possible) to continue working on it.
                http://www.wip-archi.com
                  Just to add the final nail to the coffin of a non-destructive plugin; V-Ray tend to interfere with the Undo operations when materials are modified.
                  Hopefully this will change in VfSU2.
                    OK, I understand. 😉
                    OK, understand this, too.
                      MrWip
                      Is there a way to know if someone (but I don't want to force anyone of course...) will have time (or is interested, at least...) to make modifications to 'Global_Material_Change.rb' (it seems the easiest way to do it finally), in order to have a script able to do what we're looking for ?
                      • Chris FullmerC Offline
                        Generally speaking, only the author of a script can change it, unless they have put in their copyright info that it is free to copy and change and distribute. I haven't looked at global material changer to see what is permissible.
                        Otherwise a new script would not be impossible to write.
                          MrWip
                          Thanks Chris... and by the way,I think (but it's not original in fact) that you're doing a really amazing job on loft, bending, and others. In addition, you're almost on every post, responding to everyone, and that's great!
                          So,I don't want to change this ruby particularly, it's just that a ruby like this one seems to be just what we need for... In fact, after checking in the .rb, the one I'm working with have been created by TIG, so I should maybe contact him directly...
                            kwistenbiebel
                            I am in need for such a 'clever clay' method as well.
                            In early design phases, this is the way to go. Monomaterial renders but with transparency for glass.
                            Great for 'scale model' look as well.
                            • X Offline
                              xrok1
                              And then along came Twilight! 😉
                              • FletchF Offline
                                Fletch
                                @kwistenbiebel said:
                                I am in need for such a 'clever clay' method as well... Monomaterial renders but with transparency for glass...Great for 'scale model' look as well.
                                Of course kb, as xrok1 has pointed out, surely you know this, but this is now two simple clicks in Twilight. Unlike the 'others' who make you physically change ALL your materials back and forth... it AUTOMATICALLY CONVERTS ALL MATERIALS to 'flat white' EXCEPT for light emitter surfaces, and glass materials, and it does it by simply picking 'Clay' render preset and hit the render button... all within SketchUp. This way of course you can quickly check lighting for interiors or exteriors.
                                This is an innovation that came first to Kerkythea by request of it's users and is now is in Twilight.
                                Fletch
                                  kwistenbiebel
                                  Thanks, but I need the clay method to use with other render engines.
                                  Also, the ability to use a textured material as the override material is something on my wishlist.
                                    Would this help?
                                      Fletch, don't include (embed) forum stuff because if one's not logged in the Twilight Forums, cannot see them. Attach them directly instead for instance.
                                      • FletchF Offline
                                        Fletch
                                        Thanks, DaveR - hadn't seen it yet! 😳
                                        here's what Dan has done with the Twilight Plugin Clay render mode...
                                        (I did a tiny bit of tonemapping, hope he doesn't mind)
                                        Fletch
                                        • FletchF Offline
                                          Fletch
                                          Thanks, G... sorry! fixed the post above now. 😄
                                          Fletch
                                          • majidM Offline
                                            majid
                                            maybe it is easy to do such renders using otherplugins, but my in my opinion, having such ruby will make new ideas....and will expand plugin boundries... dear mate, keep in going plz 😄
