    [Request] 'Clever Clay' mode
    34 Posts 13 Posters 7.2k Views 13 Watching
    • PixeroP
      Pixero
      I'm very interested in this too.
      Is there a way to go back to previous materials or should you save a special file for it?
      Maybe Thomthom could make it work with Vray?
      • Chris FullmerC
        It would be possible to switch back to original materials. But the script might have to hide little faces in the model with all the original materials so they don't get purged on accident.
          sepo
          Podium already can do this. In Podium if you use colour by layer it will render clay model with colour you choose as front face. Also preserves transparency and reflections.
            MrWip
            After reflexion, there is maybe two main way to do it:
            • A global change of all the material, by erasing the old ones and replacing them by the new materials ( just like global material changer does), and the script may use something like : if transparency level = 100 , pick one (it does not have to be always grey in fact), and if transparency < 100 (or maybe this one could be enter by hand, so the semi transparent material (80/90 % of transparency for example) could be also change to opaque in the same operation ) pick another one.
              This method will be destructive, but Chris idea is maybe a good solution to avoid it.
            _ A global change of all material by only one, directly, but with the respective material transparency levels.
            I don't know which one will be the simplest to code, and which one will be the quickest to run in the end...
            If it work kinda like grey scale, there will be no problem with Vray, because it works just fine in that case (a grey model is render grey by Vray). And if its a global change of material it will also work, because Vray will use the last material present on the geometry... so normally that's not an issue.
            http://www.wip-archi.com
            • GaieusG
              Kerkythea can also do this. In fact, you can already export your model as a clay model which will then render everything BUT transparent/reflective (say "thin glass") materials clay.
              Ah yes, and it's free.
              (Sorry Sid, I couldn't resist) 😉
                sepo
                Lol...I have not realised you have become KB as well.
                • GaieusG
                  I might guess what "K" means but what about "B"?
                    I'm not sure how you would revert back positioned textured faced. Think that's going to be problematic.
                    And even more so with V-Ray material; 100% impossible as there's to access to the special layers and materials in V-Ray. The only way to remove all the extra reflection/refrection,bumpmaps etc would be to delete the V-Ray attribute dictionary. To do so, V-Ray must be unloaded while you do that, otherwise it'll restore the setting when you save. V-Ray only reads the V-Ray data in the .skp file when you open the models; from that point it only writes back. Removing the V-Ray attributes means you loose all your V-Ray settings as well.
                      sepo
                      Kerky Bashers to quote Free Agent. 😉
                        MrWip
                        Gaieus,
                        I know about Kerkythea, I'm also working with it... but what I'm looking for is something that works inside sketchup, without regards for the render apps use afterward.
                        If it change well the materials, then you can use your model in Vray, Kerkythea, Artlantis, or any other, just as a classic model.
                        And after thomthom answer, I think that this plugin will be destructive : save your model, turn it into clay with transparency, render it, and go back to the previous save ( or just undo if it's possible) to continue working on it.
                          Just to add the final nail to the coffin of a non-destructive plugin; V-Ray tend to interfere with the Undo operations when materials are modified.
                          Hopefully this will change in VfSU2.
                          • GaieusG
                            OK, I understand. 😉
                            OK, understand this, too.
                              MrWip
                              Is there a way to know if someone (but I don't want to force anyone of course...) will have time (or is interested, at least...) to make modifications to 'Global_Material_Change.rb' (it seems the easiest way to do it finally), in order to have a script able to do what we're looking for ?
                              • Chris FullmerC
                                Generally speaking, only the author of a script can change it, unless they have put in their copyright info that it is free to copy and change and distribute. I haven't looked at global material changer to see what is permissible.
                                Otherwise a new script would not be impossible to write.
                                  MrWip
                                  Thanks Chris... and by the way,I think (but it's not original in fact) that you're doing a really amazing job on loft, bending, and others. In addition, you're almost on every post, responding to everyone, and that's great!
                                  So,I don't want to change this ruby particularly, it's just that a ruby like this one seems to be just what we need for... In fact, after checking in the .rb, the one I'm working with have been created by TIG, so I should maybe contact him directly...
                                  • K
                                    kwistenbiebel
                                    I am in need for such a 'clever clay' method as well.
                                    In early design phases, this is the way to go. Monomaterial renders but with transparency for glass.
                                    Great for 'scale model' look as well.
                                    • X
                                      xrok1
                                      And then along came Twilight! 😉
                                      • FletchF
                                        Fletch
                                        @kwistenbiebel said:
                                        I am in need for such a 'clever clay' method as well... Monomaterial renders but with transparency for glass...Great for 'scale model' look as well.
                                        Of course kb, as xrok1 has pointed out, surely you know this, but this is now two simple clicks in Twilight. Unlike the 'others' who make you physically change ALL your materials back and forth... it AUTOMATICALLY CONVERTS ALL MATERIALS to 'flat white' EXCEPT for light emitter surfaces, and glass materials, and it does it by simply picking 'Clay' render preset and hit the render button... all within SketchUp. This way of course you can quickly check lighting for interiors or exteriors.
                                        This is an innovation that came first to Kerkythea by request of it's users and is now is in Twilight.
                                        Fletch
                                        • K
                                          kwistenbiebel
                                          Thanks, but I need the clay method to use with other render engines.
                                          Also, the ability to use a textured material as the override material is something on my wishlist.
                                            Would this help?
