    [Plugin] 'Camera2Vue.rb'
    36 Posts 12 Posters 41.3k Views 12 Watching
    • soloS Offline
      Here is a quick pdf tutorial with installation files:
      http://www.box.net/shared/md8inqn1yd
        Alex Jenyon
        @Solo: That's brilliant - thank you so much for taking the time to put that together. Mind if I host a mirror of it on my own server?
        @craftycurate: Can you upload / email me the skippy file, and let me know which version of 'Vue' you are using? I'll look into it, see if I can some up with a solution for you. alex [at] aj-concepts.net
        Cheers
        AJ
        Concept artist / Matte painter
        www.aj-concepts.net
        • soloS Offline
          Sure thing Alex.
            Alex Jenyon
            Okay, I've got a workaround for folks who only have SUfree.
            I have absolutely no idea WHY it works, but it seems to - so please test it and see if you can work it out yourself.
            1. Export the geometry as a google earth .kmz file
            2. Rename the file from name.kmz to name.zip (i.e. change the file type to .zip)
            3. Unzip the .zip file
            4. Open the 'models' folder, and find 'name.dae' - this is a collada file
            5. Import the collada file to 'Vue'
            6. Scale it by 3.937. No, I have no idea why, but it seems to work. Anyone know why it's this value?
            (To do this, if you're not sure: Select your object, and click on the 'size' icon - the cube that's been stretched vertically. Calculate what the 'x' size of the object multiplied by 3.937 is. Then lock x, y and z sizes together - using the padlock icon - and enter this value in the 'x' size field. All the values should scale together.)
            1. Follow the rest of my method to match the camera.
            AJ
            www.aj-concepts.net
              sepo
              Will it work with Vue 5 Infinite ?
                sepo
                Ok I will try and let you know. Thanks for your reply. I never really upgraded from Vue 5 as I hated camera...Donno if it is any better now.
                  Alex Jenyon
                  @sepo - I don't know, and don't have any way of testing it.... Only one way to find out, I guess.
                  I'm using fairly basic python commands in Vue, but I think the command to select the camera changed between Vue 6 and Vue 7, which might mean the script doesn't work.
                  You could try deleting the first two lines of the python script, manually selecting the camera in Vue, and then running the script normally.
                  Otherwise, you might need to do a bit of digging into the python documentation for Vue 5 to get it working seamlessly, but it shouldn't be too tricky.
                  AJ
                  www.aj-concepts.net
                    craftycurate
                    AJ
                    Thanks Alex - it works beautifully. Looks pixel perfect. Here's an example render.
                    Thanks for all your help & for providing this great script - I'll be interested to try it with some architectural models.
                      sepo
                      Are you saying it works with Vue 5?
                        craftycurate
                        By the way, a workflow tip that will help with the scaling issue (via Alex's Collada method).
                        If your SKP model has a nice bounding box, simply measure the length of one of those sides in SKP, and then paste that dimension into the corresponding dimension in Vue.
                        If that isn't possible, scaling by 3.937 will do the same job.
                          craftycurate
                          OK another render, to prove the method works with complex models which would show up flaws.
                          I've added a subtle outline, which is the SKP render, overlaid on a Vue 7 Global Radiosity render, though it looks great with a simple Ambient Occlusion one too.
                          View in full size to see the detail.
                          Richard
                            matteo
                            So, there is no need for trigonometric conversions to convert degrees into 35mm camera FoV, as I feared.
                            Here the steps to make it work in Vue 7 Esprit.
                            1. Run the plugin 'camera to vue' inside sketchup and, when you're prompred to save the python script, save it as simple text by adding the '.txt' extension to the name you choosed to save it.
                            2. Open it with a text editor and leave it open.
                            3. In Vue just go to the options panel and under 'display options' check -show camera Fov in Object properties-.
                            4. Select the camera and copy and paste from the previous opened text all the single values of camera position and rotation, plus Sketchup's field of view in the upper right panel.
                            You're done:
                            render and enjoy!
                            /matteo
                            hire me: http://www.nonsolo3d.it/ !
                              matteo
                              The funny standard measure unit of Vue, 10,00cm, divided by one inch (2,54cm) equals 3,93700787
                              But don't ask me why this is needed 😲
                                SU always uses inches, so if Vue uses cm (10cm...?) then that's why you need that conversion I guess.
                                  rcossoli
                                  thank you very much, this is very useful for everyone! 😎
                                  THREEDIMENSIONSWEB dot COM
                                    mirjman
                                    a quick question about the process included in the .zip - while this script puts the camera in the correct location, how do you ensure that the imported .obj comes in at the same coordinates? in my experience the object is always centered on 0,0,0 in vue regardless of coordinates in sketchup - or does the script track the camera's relative location to the geometry's center point?
                                    hope this makes sense!
                                    • soloS Offline
                                      When importing the .obj uncheck the centre object and resize in dialogue.
                                        mirjman
                                        obvious! thanks
                                          sags
                                          thank you very much for sharing.. 👍
                                          • 2 / 2
