    [Plugin] RotaScale
    39 Posts 14 Posters 31.9k Views 14 Watching
      By request: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180%26amp;t=19130
      This is just a rough version to get it out there. I got some other projects I need to attend to before I polish this one off.
      Usage:
      • Select everything you want to rotate-scale
      • Tools->RotaScale
      • Pick point of origin
      • Pick a second reference point
      • Pick a third reference point that will determine the rotation and scaling
      Currently I performs a 3D uniform scaling. I'll look into 2D and 1D scaling later. (If anyone cares to give me pointers to how to do this I'd be happy.)
      Changelog
      # CHANGELOG
      # 0.1.0b - 19.05.2009
      #		 * Rotate and Scale.
      # 0.1.1b - 20.05.2009
      #		 * Fixed a bug that occured when there's no rotation.
      # 0.2.0b - 20.05.2009
      #		 * Added CTRL modifier to disable scaling.
      # 0.3.0b - 20.05.2009
      #		 * Added cursors.
      #		 * Minor bugfix.
      # 0.3.1b - 21.05.2009
      #		 * Added some extra methods to the Float class which the script rely on.
      # 0.3.2b - 11.06.2009
      #		 * Normalized the Scale transformation - VfSU has problems if this isn't done it appears.
      # 0.3.3b - 11.06.2009
      #		 * Corrected a potential bug.
      Todo:
      • 2D & 1D Scaling
      • Cleaner UI
      • Toolbar button
      • VCB input
      SketchUp Plugins | PluginStore | SketchUcation
      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
      (sketchucation.com)
      • Chris FullmerC Offline
        Great Thom! I'll check it out,
          AcesHigh
          is this something I cant do by using first the rotation tool and then the scale tool?
          • utilerU Offline
            utiler
            Following with great interest!!!!!!
            Just Curious...
              You can, but the request was a tool to do it in one operation.
                silver_shadow
                Great work!!!
                Now we dont have to work out a scale factor if we want to re size an object or model.
                it does work in some cases, don't know why
                weird.skp
                • free agentF Offline
                  free agent
                  wow thom thanks for working on this i really appreciate it!!
                  its way more than that, the point is also to control the point a group will scale from, rather than just the centre or the corners, it makes lining/scaling reference material up to a model (or vise versa) really quick, so it squashes rotate scale and move into one.
                  thom just looked at the ruby, i works perfect, better than what i had asked for actually, i frikken love it ๐Ÿ˜ i cant tell you how long ive wanted this, thank you.
                  oops first problem ๐Ÿ˜„... it seems you HAVE to rotate, if the first line is on an axis then it wont let u place the second point along the same axis
                    Yea, I expected there to be issues. I didn't test it much. I uploaded a quick update. Think it should take care of that problem.
                    Can you explain further to what you're doing? I can't reproduce any problems.
                      Damned good! ๐Ÿ˜Ž (works in V6 ๐Ÿ˜‰
                        free agent
                        beautiful, thank you, now it works great, i dont see a need for improvement ๐Ÿ˜„
                          works in V6
                          Thanks for checking that. ๐Ÿ˜„ ๐Ÿ‘
                            rv1974
                            Hi Thom
                            When I point the 3rd point with (let's say) cntrl key pressed the script should't change original scale. Could you add this feature? It would be nice imo.
                              Maybe a suggestion ๐Ÿ˜‰
                              Scale is XYZ, maybe useful to have also choice X,Y only! ๐Ÿ˜„
                              ๐Ÿ˜ณ written in the todo list ๐Ÿ˜ณ
                              ๐Ÿ˜ฎ Seems there are Splat bug when Undo v6 ! (but not repetitive)
                                @rv1974 said:
                                Hi Thom
                                Yup. That can be done.
                                  You can yet make this after the rotate scale with the same tool ๐Ÿ˜‰
                                  3 click more and have a resize as you want ๐Ÿ˜‰
                                  here half size wanted ๐Ÿ’š
                                  bug splat don't come back in the v6...curious ๐Ÿ˜ฒ
                                    Let me know if it comes back.
                                      @rv1974 said:
                                      Hi Thom
                                      It is done. ๐Ÿ˜‰
                                        kjc
                                        Hi, im sure this plugin will make things much easier, thanks!
                                        I think it would be even more if pressing "ctrl" button would cause "RotaScaleCopy", the way it works in typical rotation and move tools.
                                          Thanks for a great idea and an already very polished tool...
                                          A minor problem - there are error messages in my Ruby console relating to the
                                          float.round_to()
                                          method.
                                          This is not built in to Ruby - the nearest is
                                          float.round
                                          , I assume you have a round_to.rb auto-loading... perhaps you should include the method code inside your script, I'm sure others will be getting the error ? Here's the code I used to fix it on my PC...Float-round_toEtc.rb - it also includes some other methods like float.floor_to etc...
                                            I thought it was a ruby method. I googled ruby and rounding and I found some references to float_to which I just tried, and it worked. I guess it's a plugin I have installed which added that method.
                                            Thanks for bringing that to my attention TIG.
                                            Though, if I implement this method, might I not risk causing conflict with other script that also implements this method? I suppose if they act identical it might not be a problem..
                                            ...this is why I don't like extending base classes...
