    Autocad topography
    23 Posts 6 Posters 4.1k Views 6 Watching
      jalba
      ok. i'm getting it now. thanks for the help πŸ˜„
        jalba
        ok., now i'm getting a grasp of what i must do. But if you see attached the land boundary is not a perfect square. When applying the "from countours" command, the left hand side is not shaping well (looks like a big ditch).
        What to do in this situation? πŸ˜•
        topography drawing
        • C
          caddict
          difficult to understand the problem...can you post the .skp file
            jalba
            Here's the file. Hope you could understand. The reason it is such in a irregular pattern is because the extreme outer edge represents the boundary.
            When applying the command you suggested, i ended up with a big ditch on the left hand side of the drawing.
            SAMPLE LAND.
            • GaieusG
              Note that you can always edit a mesh manually. Turn on hidden geometry to see all the lines making up the mesh, double click on it to edit and simply delete what you don't need (see attached example where I got rid of the extreme left edges - now definitely not in a political meaning of this extreme left πŸ˜„ ).
              You can also make alterations in it with the Smoove tool (also from the Sandbox), outline buildings, roads and such with the Drape tool and create "terraces" or anything (for buldings, roads etc. again) with the Stamp tool.
              Untitled-3.zip
                jalba
                guess i'll have to go by trial and error.
                but...uhh....dumb question.....how to display hidden edges?
                • AnssiA
                  Anssi
                  View menu>Hidden geometry
                  Anssi
                  • GaieusG
                    And step by step. Don't worry, it's the same for everyone at the beginning. You'll get it eventually.
                      jalba
                      ok...ew issue...
                      i adjusted my countour lines on Autocad with each step up @ 1m. Checked a side view of it and everything was planar.
                      When i import it however, some of the lines are sent off canter. Quite annoying!!!!
                      How can i correct this?
                      you can see the lines that are of canter by watching the side view. please not that each contour is at a 1m interval.
                      henderson.skp
                      • C
                        caddict
                        not sure what you mean by off canter
                        first thought...in SU are you viewing in orthographic (camera>parallel projection)
                        i guess you are refering to some of the contours sitting many metres above the main group.
                        difficult to find an explanation for this...are these misplaced lines properly placed in the autocad file?
                        • Chris FullmerC
                          I took the terrain and moved those stray lines straight down until they into the topography where I thought they would go (I could have mis-placed them). Then I ran from contours over the whole thing. And I tidied up the edge on the left by erasing some lines that were created, but not accurate.
                          Take a look at it and see if that is about what you want.
                          henderson tin.skp
                            jalba
                            hehehe you won't believe this but the reason those particular lines were offseting too much was because in the original Acad document, they were classed as 2D polylines instead of normal polylines!!!! lolz
                            Exploded them and reformed them as normal polylines. Reimported and everything is back to normal.
                            Thanks anyways peeps!!!
                            • Chris FullmerC
                              Oh I'd believe almost anything. Especially when it comes out of autocad..... πŸ˜„
                                jalba
                                HAHAHA!!!! low blow for the acad. You know no matter hw many times i try to figure out 3D rendering in Acad, it is still such a bitch!!!
                                  sowmya
                                  sandbox is sucj a fantastic tool... i a doing a major complicated counctry side countours and its pure magic. One feature which would be handy is when its processing to make the contour, a STOP button to cancel the process if needed...
