    Autocad topography
    23 Posts 6 Posters 4.1k Views 6 Watching
    • GaieusG
      Jason,
      What you attached as "flat..." is really flat. I mean the contour lines are on the same height (z axis value). So first of all you need to "lift" (move) each one to the appropriate height so that the Sandbox can create a proper mesh. Otherwise it will also be flat.
        jalba
        so....no can do when i lift each face by the desired height huh, then smooth off?
        • GaieusG
          PushPull will give you a staircase effect. Some (mainly physical) models use that so if you like it,go with it. As was said above, you need the From contours tool from the Sandbox to have a smooth mesh.
          • Chris FullmerC
            Hi Jason, please try the contour tools. They do exactly what you want. EXACTLY. Have you seen the multiple suggestions to try them now? thanks,
              jalba
              ok. i'm getting it now. thanks for the help πŸ˜„
                jalba
                ok., now i'm getting a grasp of what i must do. But if you see attached the land boundary is not a perfect square. When applying the "from countours" command, the left hand side is not shaping well (looks like a big ditch).
                What to do in this situation? πŸ˜•
                topography drawing
                • C
                  caddict
                  difficult to understand the problem...can you post the .skp file
                    jalba
                    Here's the file. Hope you could understand. The reason it is such in a irregular pattern is because the extreme outer edge represents the boundary.
                    When applying the command you suggested, i ended up with a big ditch on the left hand side of the drawing.
                    SAMPLE LAND.
                    • GaieusG
                      Note that you can always edit a mesh manually. Turn on hidden geometry to see all the lines making up the mesh, double click on it to edit and simply delete what you don't need (see attached example where I got rid of the extreme left edges - now definitely not in a political meaning of this extreme left πŸ˜„ ).
                      You can also make alterations in it with the Smoove tool (also from the Sandbox), outline buildings, roads and such with the Drape tool and create "terraces" or anything (for buldings, roads etc. again) with the Stamp tool.
                      Untitled-3.zip
                        jalba
                        guess i'll have to go by trial and error.
                        but...uhh....dumb question.....how to display hidden edges?
                        • AnssiA
                          Anssi
                          View menu>Hidden geometry
                          Anssi
                          • GaieusG
                            And step by step. Don't worry, it's the same for everyone at the beginning. You'll get it eventually.
                              jalba
                              ok...ew issue...
                              i adjusted my countour lines on Autocad with each step up @ 1m. Checked a side view of it and everything was planar.
                              When i import it however, some of the lines are sent off canter. Quite annoying!!!!
                              How can i correct this?
                              you can see the lines that are of canter by watching the side view. please not that each contour is at a 1m interval.
                              henderson.skp
                              • C
                                caddict
                                not sure what you mean by off canter
                                first thought...in SU are you viewing in orthographic (camera>parallel projection)
                                i guess you are refering to some of the contours sitting many metres above the main group.
                                difficult to find an explanation for this...are these misplaced lines properly placed in the autocad file?
                                • Chris FullmerC
                                  I took the terrain and moved those stray lines straight down until they into the topography where I thought they would go (I could have mis-placed them). Then I ran from contours over the whole thing. And I tidied up the edge on the left by erasing some lines that were created, but not accurate.
                                  Take a look at it and see if that is about what you want.
                                  henderson tin.skp
                                    jalba
                                    hehehe you won't believe this but the reason those particular lines were offseting too much was because in the original Acad document, they were classed as 2D polylines instead of normal polylines!!!! lolz
                                    Exploded them and reformed them as normal polylines. Reimported and everything is back to normal.
                                    Thanks anyways peeps!!!
                                    • Chris FullmerC
                                      Oh I'd believe almost anything. Especially when it comes out of autocad..... πŸ˜„
                                        jalba
                                        HAHAHA!!!! low blow for the acad. You know no matter hw many times i try to figure out 3D rendering in Acad, it is still such a bitch!!!
                                          sowmya
                                          sandbox is sucj a fantastic tool... i a doing a major complicated counctry side countours and its pure magic. One feature which would be handy is when its processing to make the contour, a STOP button to cancel the process if needed...
