    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
    • ToboboT Offline
      Tobobo
      Chris,
      Thanks for all your help that worked.
      Also this script is awesome (Sorry) AWESOME!!!!!!!!!!!!!
      And it does railings
      Toby
      Philippians 4:13
      • Chris FullmerC Offline
        Yes, I am well aware of that little detail πŸ˜„ I would like to fix it, it just will take some time and thinking. It is only on the end segemnts that those lines do not actually align correctly. In time, I'll fix it.
          Suggestion πŸ˜„
          So resize all external segments = ED! πŸ˜‰
            So maybe make an another external "arc half circle" πŸ˜‰
              Sir
              i get around the problem by making the curve more curvey thani need it, then intersect a plane through so its cutoff after 180 degrees rotation... its a work around, but it works!
                Alsatic
                You can also start with a circle and explode it. Then keep one additional segment on each end of the half circle and weld it. You will get something like in the picture. Then erase the two red blocs you don't need and you're done.
                This solution has been posted on a french forum here:
                http://www.systemed.fr/Forum/forum_posts.asp?TID=32570&PN=1&TPN=1
                  Physicsguy1
                  It won't bend the shapes. The progress bar will completely freeze well below 20%, and won't unfreeze. i don't know what happened.
                    Cool trick & works fine!
                    the funny thing is that the red blocks are false in the length! πŸ˜‰
                    circle explosed and arc curves were build with same length of their segments!
                    • ToboboT Offline
                      Tobobo
                      Try to follow what chris told me to solve my problem with the bar freezing.
                      @chris fullmer said:
                      My first guess would be to try component spray. Just unload that script and see if that does the trick. There was a problem with it and Didier uploaded a new version that fixes the problem. So remove it and that fixes the problem, download the newest update here
                      301 Moved Permanently
                      (www.sketchucation.com)
                      I really think that's it. Let me know if its not,
                      Toby
                      Philippians 4:13
                        I agree, update component spray. If thats not it, we'll start debugging!
                          caramel1982
                          The sketches that you have made are just simply amazing. I can't do it myself. I need more practice.
                          Simulation pret immobilier
                          -- caramel --
                            bianhai
                            Nice plugin, πŸ‘ Thanks!
                              darkPhysics
                              Please help me! It just wont work. I have the progressbar.rb, but it wont show the preview of bend. Here is the image
                              http://img188.imageshack.us/img188/9918/problemfyj.png
                              . Can anyone help me? Here is my plugins folder:
                              http://img188.imageshack.us/img188/3189/pluginsfolder.png
                                The problem is with the compspray.rb
                                Update it from here:
                                http://forums.sketchucation.com/viewtopic.php?f=180&t=11746
                                Didier had a bug in it that was breaking the progressbar, but he fixed it nicely. So just update that, then it should work.
                                Let me know if that does not help.
                                  darkPhysics
                                  It didn't work with new compspray, but I removed it and it worked!
                                    I see you are on Vista.
                                    There is a good chance that when you tried to install compospray, Vista played a dirty trick on you. It has a hidden file system called "Compatibility Files" where it puts things without telling you. So try this.
                                    • Delete the existing compospray.
                                    • In the Plugins folder, towards the top is a button called "Compatibility Files" (or maybe Folders). - Click it.
                                    • Now your in a new folder, probably with other scripts. Cut and paste them all back into your regular plugins folder manually.
                                    • If there is a compospray in there, delete it too.
                                    • Now reinstall compospray, and be forewarned that it might end up in compatibility files world, so go track it down, and cut and paste it back into the plugins folder.
                                    • now start SU again, see if shape bender works and if compo spray is installed and working.
                                    I know its lame and a bit of work. Vista just does it to keep us safe 🀒 πŸ‘Ž πŸ‘Ώ
                                    Hope that helps,
                                    • simon le bonS Offline
                                      simon le bon
                                      Hi Chris,
                                      Another thing i think it would be great to fix for a next update is that construction points and construction lines they follow the Bend processes.
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_ShapeBender_CP.jpg
                                      πŸ˜‰ simon
                                        Ahh, thats a good idea! I see if I can get that to work.
                                        • ToboboT Offline
                                          Tobobo
                                          Chris,
                                          I stripped all the rubies out and it worked. I know that I should add the others back in one at a time but I have soo many scripts with references i keep getting lost on which ones need each other. Can you take a look at the screen dump and see if anything jumps out at you.
                                          Here is the console text aswell
                                          Error; #<ArgumentError; comparison of Float with nil failed>
                                          (eval);44;in `>'
                                          (eval);44;in `update'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;533;in `exploder'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;526;in `each'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;526;in `exploder'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;244;in `onLButtonUp'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;671
                                          Error; #<NoMethodError; undefined method `/' for nil;NilClass>
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender/clf_shape_bender.rb;671;in `draw'
                                          Toby
                                          Philippians 4:13
                                            magpie
                                            many thanks for your plugin...brilliant!
                                            • 11
                                            • 63
                                            • 64
                                            • 9 / 64
