    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
    • Chris FullmerC
      It struggles when it tries to bend shapes full of components. So try a simple shape first to find out if its working at all. If it really is getting stuck, then try opening the Ruby Console and then run the script. See if it outputs and error messages. If it does, post them back here to this thread and I'll take a look at it.
      If its getting stuck, and not posting any errors, could you remove all other plugins, leaving just clf_shape_bender_loader.rb and the clf_shape_bender folder in place. Then see if it works any better.
      Thanks,
      • Chris FullmerC
        Thats great Simon, thanks for putting that together.
        That part on the text wrapping about the corners not working correctly.....I know 😞 It is something I want to fix so it works the way you expect it to in that example. However, there are times when it is doing what would be the desired action. So I will need to build in a toggle between the 2 solutions.
        Perhaps I'll draw up a quick diagram that shows how it currently acts, how I would like it to act, and overlay them so you can see how they are different and then show an example for each that shows when one result would be beneficial over the other.
        But a great big thanks to you Simon for putting all that info together!
        • simon le bonS
          simon le bon
          Cher Chris,
          I appreciate that you enjoy my small contribution (very far from giving back what you give us with ShapeBender). What I wanted to demonstrate is that ShapeBender is also a high geometric precision tool, that for my part I am convinced.
          I think it would be desirable to open a specific topic on the use of ShapeBender(as we should do for all master plugin), to collect the tests and experiments very interesting and unfortunately dispersed throughout this thread.
          And Here the first problem I encountered, that I wanted to talk:
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/C1_005_650.jpg
          ShapeBender encountered difficulties_01 slideshow
          :-)s
          • Chris FullmerC
            Hmm, that is interesting. I will try to play with it and see if I can repeat the results. I can't think of any good reason it would do that. But that doesn't mean its not doing it. So I'll see what I can find,
            • Chris FullmerC
              My first guess would be to try component spray. Just unload that script and see if that does the trick. There was a problem with it and Didier uploaded a new version that fixes the problem. So remove it and that fixes the problem, download the newest update here
              404 Not Found
              (www.sketchucation.com)
              I really think that's it. Let me know if its not,
              • E
                edmund
                This plugin is great. I had all of the profiles of my fins drawn already from a physical model I had to build. So this plugin was exactly what I was looking for. Thanks a ton.
                • Chris FullmerC
                  Wow! Thats awesome! I'm surprised, I mean glad, that my script worked for you πŸ˜„
                  • ToboboT
                    Tobobo
                    Chris,
                    Thanks for all your help that worked.
                    Also this script is awesome (Sorry) AWESOME!!!!!!!!!!!!!
                    And it does railings
                    Toby
                    Philippians 4:13
                    • Chris FullmerC
                      Yes, I am well aware of that little detail πŸ˜„ I would like to fix it, it just will take some time and thinking. It is only on the end segemnts that those lines do not actually align correctly. In time, I'll fix it.
                        Suggestion πŸ˜„
                        So resize all external segments = ED! πŸ˜‰
                          So maybe make an another external "arc half circle" πŸ˜‰
                            Sir
                            i get around the problem by making the curve more curvey thani need it, then intersect a plane through so its cutoff after 180 degrees rotation... its a work around, but it works!
                              Alsatic
                              You can also start with a circle and explode it. Then keep one additional segment on each end of the half circle and weld it. You will get something like in the picture. Then erase the two red blocs you don't need and you're done.
                              This solution has been posted on a french forum here:
                              http://www.systemed.fr/Forum/forum_posts.asp?TID=32570&PN=1&TPN=1
                              • P
                                Physicsguy1
                                It won't bend the shapes. The progress bar will completely freeze well below 20%, and won't unfreeze. i don't know what happened.
                                  Cool trick & works fine!
                                  the funny thing is that the red blocks are false in the length! πŸ˜‰
                                  circle explosed and arc curves were build with same length of their segments!
                                  • ToboboT
                                    Tobobo
                                    Try to follow what chris told me to solve my problem with the bar freezing.
                                    404 Not Found
                                    Toby
                                    Philippians 4:13
                                    • Chris FullmerC
                                      I agree, update component spray. If thats not it, we'll start debugging!
                                      • C
                                        caramel1982
                                        The sketches that you have made are just simply amazing. I can't do it myself. I need more practice.
                                        Simulation pret immobilier
                                        -- caramel --
                                        • B
                                          bianhai
                                          Nice plugin, πŸ‘ Thanks!
                                            darkPhysics
                                            Please help me! It just wont work. I have the progressbar.rb, but it wont show the preview of bend. Here is the image
                                            http://img188.imageshack.us/img188/9918/problemfyj.png
                                            . Can anyone help me? Here is my plugins folder:
                                            http://img188.imageshack.us/img188/3189/pluginsfolder.png
                                            • 11
                                            • 12
                                            • 63
                                            • 64
                                            • 10 / 64
