    [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
    251 Posts 88 Posters 216.4k Views 88 Watching
    • FrederikF
      Frederik
      Dang, Chris... This is awesome...!! πŸ‘
      Thanks...!! πŸ˜„
      Cheers
      Kim Frederik
        materialdb
        It's like the curvsticher .. I'm looking forward for the bezier-functionality!
        great work! keep it up!!
        free vismat materials: http://www.material-db.com
        • Chris FullmerC
          Yeah, that is precisely right. Currently it is only marginally better than curve stitcher (For example, mine is faster, doesn't twist geometery like shown in the video, and you can subdivide to make it a smother mesh, and it works with more than just 2 curves). But like you say, its the bezier connections that will make this awesome! I'm working on that right now and I should be able to get something up and running today.
            Daniel S
            Looks great!! Very good first version Chris!! 😍 😍 😍
            I'm wondering what will be the the missing key piece.
            There is not too much to say because you mention most of the problems in "whatΒ΄s missing".
            Having to Make the Splines with the same amount of segments is perhaps the problem that makes it more difficult to use.
            Congratulations and thank you!!!
            Daniel S
              AcesHigh
              can it already connect closed lines to open ones?
              • Chris FullmerC
                No, not at this point. Only works with open "splines" that do not close, and they have to have the same amount of edge segments.
                And unfortunately, getting it to work with closed splines will take a lot of re-programming 😞 I probably won't get to that very soon. But in time. Its definitely do-able. I just need to re-think some things.
                • utilerU
                  utiler
                  Very nice Chris, you really have a handle on what is needed.....
                  BTW, I PM'd you about another idea for a script.
                  πŸ‘
                  Just Curious...
                  • Chris FullmerC
                    Thanks Andrew!
                    PS: Yes, I got the PM. I will have to get back to you on that, it sounds very interesting. And I might need some pictures to help wrap my head around the entire idea πŸ˜„
                    • utilerU
                      utiler
                      Will send you a few pics and video's.... πŸ‘
                      Just Curious...
                      • Chris FullmerC
                        UPDATE! Script and video updated.
                        I've now got the bezier connections from spline to spling working. What does that mean?
                        Essentially the lofting actually works now. Its a huge improvement.
                        You still need to make all splines have the same amount of segments though. That will be the next piece I tackle, I promise!
                          video isn't loading.... Just get a white square...
                            It doesn't have a loading screen?
                            • Chris FullmerC
                              Sorry, its a big video. about 30mb and it takes a long time to load sometimes. So open that front page in another tab and let it load while you browse other pages.
                              EDIT: Or, as it turns out, I forgot to actually upload it to my server. 😳 Try it again, thanks for the heads up!
                              • Chris FullmerC
                                Oh your fast. Sorry, yeah I didn't upload it. So its uploading and should be ready now to try again.
                                Thanks for pointing it out!
                                EDIT: Still having issues....hold on.
                                EDIT AGAIN: OK, now its working!
                                  Loading! πŸ˜„
                                    Wow Chris, this is amazing. Thank you very much for this and all of your other scripts.
                                      Chris! That's fantastic!
                                      If you find yourself in Norway I'll buy you a big pint of beer!
                                      • C
                                        Click Draw
                                        Again.....Thanks very much. This is just amazing....great update! And if your ever in Vancouver, I'll buy you a jug of beer! 😍
                                        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                        • JClementsJ
                                          JClements
                                          Very impressive.
                                          Be neat if you could add in something like Joseph Lieblinger's Soap Skin method to flex the triangulated surface.
                                          Regards, John
                                            No possibility to automate the clicks of curves? πŸ˜‰
                                            the 10 curves are made with the Grow plug by Tig
                                            • 12
                                            • 13
                                            • 1 / 13
