    Sloowwww render in v-ray
    extensions
    20 Posts 4 Posters 2.7k Views 4 Watching
    • soloS
      Check the model you uploaded, it only has 2 scenes.
      • T
        tommymartel
        first of all thank you for trying to help me!!! im very grateful!
        there you go , I saved it with another name .... it suppose to have 3 scenes
        http://rapidshare.com/files/232676433/moulin-3scenes.skp.html
        if there is no scene in the attic, just place your cam as you want...............
        • soloS
          It renders very quick on my side but materials are missing and it's very over exposed, I could'nt understand initially then I looked at your first post and noticed you are using version 1.0, and I'm using version 1.5/6 (latest version) thus they are not interchangeable.
          I would have helped you out without reward mate but my version is not the same so it won't work out, sorry about that.
          • T
            tommymartel
            well ok thank you nyways.... guess I'm gonna freehand sketch ๐Ÿ˜ฎ ill try to install 1.6 version later on... for the hundred times ๐Ÿ˜ž
            thank you!
            (by the way, there aint no way to work the same model between different versions ? :S)
            anyone else got ideas ?
            • soloS
              Unfortunately in my experiance one needs to apply the textures again and set up the render from scratch between versions for it work again.
              I use an i7 for rendering so my render times will be probably a lot faster than a quad, so please do not expect your times to increase too much between versions as your scene is very heavy with lots of complicated lighing algorithyms.
              If you are able to upgrade to the latest version and adjust the scene for render, I will be glad to render it for you to save time.
              • T
                tommymartel
                no i wont be able to upgrade and I dont wanna lose that much more time .... thanx for your help, ill try to delete some lights as this seems to be the biggest source of problem!
                thank you!
                • T
                  tommymartel
                  last question ๐Ÿ˜’
                  I achieve to setup my lights so the render dont take weeks, but now i gotta get rid of those white dots, is it related qith light cache or sumthing ?
                  can you tell what it is ?
                  thanks again now I fell im getting somewhere ๐Ÿ˜„
                    This thread as ASGVis is interesting in regards to lights and render times: http://forum.asgvis.com/index.php?topic=5208.msg28183#msg28183
                    I've seen them bright artefacts before, but I can't remember the cause. If you search the ASGVis forum you should find posts which relates.
                    • stefanqS
                      stefanq
                      white dots= pixels with value beyond 255 (very very bright pixels)
                      solution: in "Color Mapping" check "Clamp Output" and "Sub-pixel"
                      Good luck!
                      • T
                        tommymartel
                        ok i got rid of the dots but now i got those spot on my white materials ... is it related to caustics? i tried to find answer but i coulnt....
                        Thanx thomthom for the link, very helpfull, damn there is so many things to learn about vray ๐Ÿ˜›
                          Could either be because you don't have enough samples for your Irradiance map, if that's what you use. And/or it could be that your Adaptive Amount under Image Sampler is set to 1 - if so, set it to 0.85.
                          What setup do you have IR+LC?
                            hmmm... do you have caustic enabled? (not the GI caustic, but the one under the Caustic section?)
                            • T
                              tommymartel
                              i think it was my adaptive amount in image sampler... was set to 1.... and no i dont have any caustics on
                              my samples in irridiance map is 20
                              I use IR+LC
                              now im doin it with another .visopt i htink its gonna be ok!
                              thank you!
                                The Adaptice amount is best set to 0.85 - always. Check this value before you render.
