    [Plugin] UV Toolkit
    377 Posts 86 Posters 398.4k Views 86 Watching
    • GaieusG
      @thomthom said:
      At the moment I don't control at all the orientation of the texture. Further investigation will show if I can control it somehow...
      Never mind. It's already a great help and once you are over the excitement, like you say 'If you ask me about any other UV mapping feature, the answer will most likely be; "I don't know."' I already have ideas πŸ˜‰
        I have lots of ideas myself. I just don't know if I can do them. πŸ˜‰
        • free agentF
          free agent
          dammit thomthom, i want to stop using sketchup altogether and u guys keep giving me less reason to leave, cant wait to see more developement on this, please keep road kurbs in mind, perhaps a follow along path type texturing, i might be pissing in the wind but we all need to pee every now and then (i'll try work on a better analogy)... πŸ‘ πŸ‘ πŸ‘
          http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
            This is one of the final goals I hope to be able to do. πŸ˜‰
              sepo
              Nice one TT. Really useful piece of kit. πŸ‘
              • StinkieS
                Stinkie
                Why?
                Wild guess: texturing, poly count etc.
                Nice plugin, Thomas. Thanks! πŸ‘
                • free agentF
                  free agent
                  Why?
                  etc etc etc... learn ANY other modeler, that should answere the question, still love sketchup though...
                  • FrederikF
                    Frederik
                    Thanks, Thomas... πŸ‘
                    Cheers
                    Kim Frederik
                    • majidM
                      majid
                      thanx , that is great
                      • EarthMoverE
                        EarthMover
                        Thanks Thom, this is exactly what I need!! πŸ‘ πŸ‘
                        Content Creator at Skapeup
                          @gaieus said:
                          What I noticed is that you need to have the orientation of the image file in the model correct. You cannot rotate the texture using hidden geometry on an THEN apply the plugin because it will revert it to the default orientation.
                          I've managed to rotate the texture of rectangular quad-faces 90,180 and 270 degrees. But I'm experiencing some oddity with quads of an unusual shape. Getting there though. (And yes, it does rotate the texture of multiple face all at once.)
                            davide.skp
                            Fast and accurate, you are a great!
                            I try to stress a little the process with some complex geometries ..... but for now everything seems perfect!
                            Triangular faces with respect to I have a half idea ... Once I realize the concept I try to give you news!
                            once again thanks Thomas ...
                            you are a power!
                              Yea, I've been wondering how to tackle triangles. If you have some ideas that'd be nice.
                                davide.skp
                                What's next?
                                I might merge my Mirror UV Mapping plugin with this if I can get this thing working as I want.
                                In fact everything is fine until you make the
                                "Mirror UV Mapping plugin"
                                sorry, as usual, my English ... I hope is understandable!
                                base model
                                fit texture .... OK
                                the back of the model .... OK
                                Mirror UV ... very strange never notice problem with this plugin .... probabily is correlate to MAKE UNIQUE TEXTURE
                                ![this fast test seem confirm the idea ... if I "MAKE UNIQUE TEXTURE" of some face the mirror still work perfect](/uploads/imported_attachments/HCt2_005.jpg "this fast test seem confirm the idea ... if I "MAKE UNIQUE TEXTURE" of some face the mirror still work perfect")
                                • N
                                  numerobis
                                  WOW! Thank You! Very cool!
                                  @davide.skp
                                  have you tried to group all faces first and then use the mirror tool?
                                  I had this issue with imported trees. Using the mirror tool without opening the group/component worked well - applying it to the faces in the group messed up all uv's forever... πŸ˜’
                                    hmmm.... do you have that test model still? could you upload it here so I can have a look at it?
                                    btw, where you using version 0.1.x or 0.2.0 for those tests?
                                    • GaieusG
                                      I had no problem with rotating the texture on my first example but in the second (tubular) one,with hidden geometry in it, it reverted.
                                      I'll perform some further tests however.
                                        davide.skp
                                        thom, I have the model but the problem happens with all drawing, although groups geometries
                                        001.skp
                                          davide.skp
                                          As for the triangular faces, however, I think we can solve from the creation of texture ENDOW ...
                                          therefore, if you create the texture, like that crap that attached below ((do not laugh ... please! (on this machine I do not have libraries, and even software))
                                          TEXTURE BE DONE WITH THIS LOGIC
                                          potresti forcing the deformation of the side "red" retaining its position as the pivotal point of the "green" and excluding portions "black"?
                                            Ok, it's a bug when the face is not shaped like a rectangle or parallelogram. I have similar issue when I tried to make a function that rotates the texture left/right. This affects both this plugin as well as the UV Mirror plugin.
                                            I must look deeper into how skewed textures works.
                                            • 18
                                            • 19
                                            • 1 / 19
