    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
      sepo
      Yes I am aware of that pedestrian way, I was thinking along these lines when thinking about brunching path. So if it possible to do pedestrian way I can't work out why it can't be automated.
      • Chris FullmerC Offline
        It probably could be automated. It might not always work out exactly right, but it would probably be able to return pretty good results regularly. Ij just don't have time, and I've got a few bigger fish to fry on this plugin that are already in the works (don't get your hopes anyone, it'll be a while before I release a new version of this unfortunately 😞 )
        But, once I get some more tools worked out, it may very well work to begin implementing forked paths. I would just have to think it through a lot more.
        It might even be its own tool. More like profile builder actually. I don't have that script. Does it do what you want?
          sepo
          No, profile builder does not do the same stuff. There is similar but free tool as part of Power SU tool which works on same principal like profile builder. None of these as far as I am aware can do forking (funny word). It is quite tedious to do this pedestrian way although possible. With simple forms and flat surfaces it is quite straightforward. Little cut and paste and hiding in the workflow. But my idea was for ramps and roads...interesting bridges etc...never mind the trees.
          Anyway thanks for your reply.
            Rigth, PB doesn't do forking either. It would be cool however - for some intricate Gothic tracery for instance... πŸ˜’
            http://www.bluffton.edu/~sullivanm/italy/milan/cathedral/0025det.jpg
              saylrboy
              This is a really remarkable tool. One minor nitpick/feature request. It works great on Bezier curves, as you demo'ed in the excellent video. Unfortunately, it doesn't work very well with freehand curves. I'd like something like an O(4) Bezier curve, which the Bezier tool doesn't support. The plugin doesn't work on a group of O(2) Bezier curves, and if I draw the curve freehand, what comes out of shape bender looks pretty busted.
              Thanks again for doing this kind of stuff.
                Hmm, not sure what an O4 and O2 bezier is. IT should work on any series of connected lines. If you have 2 beziers and they are in separate groups, they would need to be exploded first.
                Do you have a picture, or better yet a model that shows the problem? Thanks!
                • ToboboT Offline
                  Tobobo
                  Chris,
                  Thanks for the awesome script.
                  Will it work on components like railings? or will i have to explode and group them?
                  Toby
                  Philippians 4:13
                  • ToboboT Offline
                    Tobobo
                    When I try the plugin it gets stuck at 5%. What could i be doing wrong? or is it my poor PC
                    Toby
                    Philippians 4:13
                      It struggles when it tries to bend shapes full of components. So try a simple shape first to find out if its working at all. If it really is getting stuck, then try opening the Ruby Console and then run the script. See if it outputs and error messages. If it does, post them back here to this thread and I'll take a look at it.
                      If its getting stuck, and not posting any errors, could you remove all other plugins, leaving just clf_shape_bender_loader.rb and the clf_shape_bender folder in place. Then see if it works any better.
                      Thanks,
                        Thats great Simon, thanks for putting that together.
                        That part on the text wrapping about the corners not working correctly.....I know 😞 It is something I want to fix so it works the way you expect it to in that example. However, there are times when it is doing what would be the desired action. So I will need to build in a toggle between the 2 solutions.
                        Perhaps I'll draw up a quick diagram that shows how it currently acts, how I would like it to act, and overlay them so you can see how they are different and then show an example for each that shows when one result would be beneficial over the other.
                        But a great big thanks to you Simon for putting all that info together!
                        • simon le bonS Offline
                          simon le bon
                          Cher Chris,
                          I appreciate that you enjoy my small contribution (very far from giving back what you give us with ShapeBender). What I wanted to demonstrate is that ShapeBender is also a high geometric precision tool, that for my part I am convinced.
                          I think it would be desirable to open a specific topic on the use of ShapeBender(as we should do for all master plugin), to collect the tests and experiments very interesting and unfortunately dispersed throughout this thread.
                          And Here the first problem I encountered, that I wanted to talk:
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/C1_005_650.jpg
                          ShapeBender encountered difficulties_01 slideshow
                          :-)s
                            Hmm, that is interesting. I will try to play with it and see if I can repeat the results. I can't think of any good reason it would do that. But that doesn't mean its not doing it. So I'll see what I can find,
                              My first guess would be to try component spray. Just unload that script and see if that does the trick. There was a problem with it and Didier uploaded a new version that fixes the problem. So remove it and that fixes the problem, download the newest update here
                              301 Moved Permanently
                              (www.sketchucation.com)
                              I really think that's it. Let me know if its not,
                              • E Offline
                                edmund
                                This plugin is great. I had all of the profiles of my fins drawn already from a physical model I had to build. So this plugin was exactly what I was looking for. Thanks a ton.
                                  Wow! Thats awesome! I'm surprised, I mean glad, that my script worked for you πŸ˜„
                                  • ToboboT Offline
                                    Tobobo
                                    Chris,
                                    Thanks for all your help that worked.
                                    Also this script is awesome (Sorry) AWESOME!!!!!!!!!!!!!
                                    And it does railings
                                    Toby
                                    Philippians 4:13
                                      Yes, I am well aware of that little detail πŸ˜„ I would like to fix it, it just will take some time and thinking. It is only on the end segemnts that those lines do not actually align correctly. In time, I'll fix it.
                                        Suggestion πŸ˜„
                                        So resize all external segments = ED! πŸ˜‰
                                          So maybe make an another external "arc half circle" πŸ˜‰
                                            Sir
                                            i get around the problem by making the curve more curvey thani need it, then intersect a plane through so its cutoff after 180 degrees rotation... its a work around, but it works!
                                            • 11
                                            • 12
                                            • 13
                                            • 63
                                            • 64
                                            • 11 / 64
