    [Plugin] Material Tools
    124 Posts 44 Posters 186.2k Views 44 Watching
    • Chris FullmerC Offline
      I'll help get the ball rolling...
      Do you just want a single material applied to the entire component? Like, you want all components named "doorhandle_01" to be painted silver, regardless how deep they are buried?
      Also, how many DIFFERENT components are there? You say thousands, but is it 10os of copies of only 10 different components? Or is it really thousands of different components?
      Do you have a sample model you could upload?
        @tomi said:
        Is there a way to apply materials by layer to components, groups, and nested components? I'm loathed to edit thousands of components individually by double clicking on the component and then using the paint bucket tool.
        Are you aware of the Color By Layer function from the menu that pops up when you click the button with the arrow icon to tha far right of the layer window? Would that do the trick for you?
          If you want to transfer the layer colours to the geometry, then there's already a plugin out there. Search for " layers_materials" at http://www.sketchucation.com/extensions-index/
            Tomi
            Wow. You were quick. I can't upload the whole file because even zipped it is 25MB. Layer by colour... tried that first but it only changed the elements of the drawings that weren't components - namely one or two (the landscaping). The other suggestions sound promising, let me look into them now...
            P.S. Thanks tremendously.
              Tomi
              Yes. I'd like to apply a single material to a component, regardless of how deep they are buried.
              Yep, there's thousands of separate components all made to create a building. I've uploaded a zipped file of just the structure. Added to this is secondary structure, claddings, windows, stairs, floors - essentially every element of the entire build (right down to silly things that I probably shouldn't have detailed, like the rubber seals in between the panes of double glazing). The plan is to do an exploded perspective along the way (I'd love it if there was a plugin for this!).
              Structure.skp.zip
                Tomi
                I'm going to try this now. Do you know if it applies the layer colours to even geometry nested as components within larger components? Thanks thomthom
                  Tomi
                  Hang about, sometimes when you're stressed you miss things. I had a little meditation, came back to re-read your first comment, thomthom, and just needed to select layer by colour like you suggested. Thanks a million (and Chris) for your help. It's kind people like you who by sharing, make the world a better place. I didn't need any plugins after all, but as I'm falling back in love with sketchup, how do you load them? I went to the layers_materials plugin page and the link brought up a script...
                    Place the .rb file in the Plugins folder where SU is installed. Some plugins also include folders that needs to be extracted to the plugin folder as well.
                      Sir
                      ok, not actually thousands of components! you have lots of instances, but with the others added you'll only have a hundred or so, maybe 200!
                      have you found the components window yet? this is a good way to keep track of the components in your model. you can also use it to add materials to specific components by
                      1. insert a new copy of the component into the model, doesnt matter where
                      2. add material to that new one. this will update all instances (copys) of it throughout the model
                      3. delete the inserted component
                      repeat
                        Tomi
                        repeat
                        Thanks. Still getting my head round the nitty gritty. Thomthom's simple suggestion achieved what I wanted to do - add materials according to layer - by using the colour by layer option. But that's a great tip - my drawings is mainly organised into layers, but supposedly by this way I could have more control if needed and change individual components on the same layer. Thanks for your help.
                          Sir
                          very useful plugin thomthom. is it possible to add the functionality to remove ALL materials but ONLY from the selection?
                          fantastic!
                            fantastic!
                            Yea, that would be possible. I was thinking of doing that anyway. πŸ˜‰
                              Sir
                                Only one thing; what would be the expected behaviour if the selection contains an component instance?
                                  Sir
                                  id have to say that remove from all instances too, as you'd want them all the same, no? suppose it could always be a check before compleating the script tho, im sure someone would want it both ways!
                                    Can't you just use my GlobalMaterialChanger.rb ? ... It works on a selection, OR the whole model... and it asks if you want to 'mine' down into groups and instances etc...
                                      Sir
                                      i wasnt aware of it... ill go take a look πŸ‘
                                        Pout
                                        great! Thx!
                                          Hi Thom,
                                          sorry for bumping the topic... Could you add "Remove materials applied to back faces"? (Or is there a plugin that does that already?)
                                            Al-ka-zam!
                                            • 1 / 7
