    Trouble shooting help, invisable lines.
    6 Posts 3 Posters 566 Views 3 Watching
      Doug
      Not sure what is going on but sometimes the "Draw" function seems to be drarwing invisable lines. I can click on a surface or in space and go through the drawing process, starting and dragging or creating a square or circle. As soon as I release or click the end point, the lines disapear. If I turn on the xray mode, I can see very the lines or shapes I've drawn.
      Any one have any thoughts?
      Thank you.
        Gjenio
        I think the problem is related to the visibility of the layers in your model. Check it out in the layer manager.
        I had some time ago the same problem, but I solved it quite immediatly
          Doug
          Gjenio, thank you for your reply but that didn't do it.
          I tryed turning all layers on and unlocking all to no avail. In xray I can see squares and circles but lines will still not draw.
            Gjenio
            Can you post the file?
            • jeff hammondJ Offline
              maybe you have 'display edges' turned off?
              window -> styles -> edit
              make sure display edges is checked
                Doug
                Jeff, That was the problem.
                Thank you...
