You Decide Competition!
the sp-challenge-05 has a twist: You get to choose what the competition is. All requests are welcome! Either reply here, or review on the model i posted on the warehouse. A poll will be created once the options are decided and we will vote on what the challenge will be. REMEMBER: The challenge starts on APRIL 9TH.
It's May.
yeah that's not good...
... Ah, you fixed it... wait... what's not good?
Oh, request; Pinball machine.
A generic keyboard and/or joystick controllable character. Think 3d Mario. It doesnt have to animate, but the user should be able to move and turn and jump around an arbitrary environment like you would in a video game. Extra credit for extra abilities like "punch".
I... uh, Physicsguy, that's the 6th challenge. 5th has started, it's a desert vehicle. I like Chris' idea
Same here. I thought about doing it once...
I think would be great to involve also Layout2 and Stylebuilder in the competition.
The project, could be everything (as said above), but i think that would be interesting to see how the competitors are able to put their project into a Blueprint and a final presentation.
The aim of sketchup is also to make the modelling executable!
That is just my point of view... -
The competitions only last a week. What about us poor souls who don't have pro?
... which includes me
BTM, you should join in the competition. You haven't posted an SP model... indeed, any models, in a whole month. That's less than me, which is saying something
Note: posted, not made.
Wow... I wonder what inspired that?
lol that is a bit obvious, but we do sometimes run out of models to make.
...I tried your game Wacov, so I decided to see what would happen if I were to have made one. It was just a test, not for posting (as mentioned), what you see is the starting, to about half-way. Above, there is a little half-destroyed village, with my FPS drones around it. Oh, did I mention that the BMW has guns that come out of the front license plate when you press V, shoot with the up key (steering of car is with WASD),
and go back in when you press C? That would be from some James Bond video-game inspiration.The major in-accuracy of the car, other than the guns and booster (thruster, spacebar) would be that I added 4 wheel turning. I do it to all my vehicles, it gives them a kind of super-handling.
...oh, if you're wondering, that's a canyon. At the bottom, there's a little stream.
You must have read my mind. Before i chose the You Decide option, i was thinking of a Role Playing Game. I already have one that i was working so i could enter it as an example. It's a 2D Mario game that works very well, and has an old level that i recreated. Shall i post it? I might add some more features. I had everything configured to lower and increase health points when you contacted an item, but i couldn't find an effective way of "ending" the game once you lost all health points. Mario himself is animated, thanks to the capabilities of SP3x. BTW i'm very happy that it is only 500KB.
Chris, how do you animate movements without a complicated array of emitters or finely tuned joints and settings? I remember seeing a knight game you posted, but i never figured out all the functions in the code. Can you just point me in the right direction? All i need is the basics.
Oh man! Your going to be sorry you asked. There are no "basics" with that example. It will melt your brain.
I pulled out all the stops with it and it was full of undocumented stuff I couldn't begin to explain. But here you go:The actual "animation" is a trick using hidden geometry. Every frame it unhides the right "frame" of groups. Look carefully at the the hero characters hidden geometry and the names of the hidden groups. And look at it in outliner.
How the frames are unhidden is also a trick. I create a few functions in hidden objects and call them in the heros ontick. Look at it again with that in mind and if you have any questions Ill try to answer.
I'd bet coin that you guys can to better with out all the fancy stuff.
You guys always amaze.
complex apparatuses using emitters work perfectly for sprites and such. i'll post an example.
Arggg.... The sprite didn't work. The emitted objects were trailing behind, even thought i set them to exist for one frame. I'll have to work with the script you used. First thing is:
push([(0.5-rightx)*1,-(0.5-righty)*1,0]) setVar("lastpos",getposition) if(frame==0) h=getVar("lastpos")-getposition h.z=0 speed=h.length setVar("lastpos",getposition) setVar("heroheading",h)What does all this do? I understand that h equates to 0(i think it does)but i'm oblivious with the <h.z=0> and <speed=h.length>. What does the period do? Where are the <speed> and <length> values obtained from?
Anyway, I have a sprite that does work, but doesn't do anything other than run, run in place, and run backwards. use a joystick. A is jump. Feel free to edit it and post it on the warehouse, because this model was intended to be a building set for my contest. If you wanted to know the contest ends on the first of june.
