    Indigo Going Commercial
    extensions
    54 Posts 14 Posters 9.6k Views 14 Watching
    • StinkieS Offline
      Stinkie
      Well ... one cannot predict the future. You always take a chance when you buy an app. Even if you're not an early buyer - I know, I got Maxwell. 👿
      Now there's a plugin that doesn't seem to be going anywhere. 😄
        remus
        From my quick browse of the beta forum i think it also has motion blur, which is quite cool. Not sure if whaat has managed to work this in to skindigo, though.
        p.s. Got my license as well, first renderer i've ever shelled out for 👍 Hopefully my investment is well spent.
          kwistenbiebel
          I must admit that I find unbiased render engines not fast enough to spend (big) money on.
          Image quality is great, yes, but the hardware is never good enough to be feasible.
          On the other hand, Whaat's Skindigo is a great plugin .
          I wish the other render engines would work in a similar way. Double click a SU material, choose a preset, change some numbers and hit render. A 12 year old can do it.
          • StinkieS Offline
            Stinkie
            You are right. But only to a degree, I think. I wouldn't use an unbiased engine if were a pro. Time is money - thus I'd use Vray. Yet, I am not a pro. I am solely in it for the pretty pictures. So at least in my case, going unbiased is a logical choice.
            Yes, it is quite the little gem. I've actually bought both SDS and PB out of gratitude. Like you, I wonder why other devs do not adopt Whaat's wysiwyg approach. God knows there's quite a few render engines out there that could do with a straightforward mat editor.
            • jeff hammondJ Offline
              so there's a mac version out now.. problem is, i can't get any of my models in there... the app seems to open fine but skindigo doesn't work with OS X..
              is there another way to get .skps into indigo or is the exporter the only way to do it?
              • W Offline
                Whaat
                Hi Jeff,
                I am currently working hard on SkIndigo OSX. Please be patient as there a lot of things to fix for it to work properly on Mac.
                As of now, the only way to use SkIndigo on a Mac is to use bootcamp or equivalent.
                I hope to have a working Mac version out within a couple of weeks.
                Dale
                  oh nice.
                  thanks for the info and good luck with figuring out your new mac 😄
                  no rush..
                    kwistenbiebel
                    I just ran a render in Indigo (skindigo 1.09 version when things were still free) for 10 hours on a 8 core Mac Pro and there is still too much noise to be presentable. The original was 2000Xsomething and I needed to downsize and denoise it a lot.
                    A biased engine would render the same image clean in about an hour. Even for a hobby I would prefer that.
                    The Indigo result:
                    http://i140.photobucket.com/albums/r3/kwistenbiebel1/indigo.jpg
                    I am not saying that unbiased is bad. As a matter of fact, I liked using Indigo in my spare time ..... I just think that one should be careful spending a lot of money on it.
                    • StinkieS Offline
                      Stinkie
                      @ Kwisten - would that be pure white you're using? 😄
                      Seriously, though, I obviously know noise is a big problem with unbiased engines. Certainly when doing sun-lit interiors. But ... I do not intend to use Indigo for those - I have a very specific use for it in mind. 😄 Which it'll serve better - more efficiently- than Maxwell. 😎
                      • StinkieS Offline
                        Stinkie
                        I always have the feeling that Fry is faster because it has more bias?
                        No idea. I keep reading claims that Fry is indeed faster than Maxwell, though. I cannot verify this myself, as I don't own the app - I basically have quite enough rendering apps.
                        The Indigo output clearly has more bleeding and color depth going on, as if the light bounces of several times more.....at the expense of longer render time?
                        Could be. I have no idea how it works. However, from all the apps I own, I feel Indigo produces the best output.
                        As a side note: In Indigo, having the option to control sun and sky seperately should be implemented.
                        In other words, the sun direct sun light should get its own 'layer' to blend.
                        +1
                          kwistenbiebel
                          My whites never go higher than RGB 220,220,220...(in any render engine).
                          The fryrender one cleared up after 5 hours, but I admit that I prefer Indigo's color bleeding much more.
                          Fry: Pure sky
                          http://i140.photobucket.com/albums/r3/kwistenbiebel1/fry-sky.jpg
                          Fry: Sky + sun....Fire flies 😡
                          http://i140.photobucket.com/albums/r3/kwistenbiebel1/fryrender-sun.jpg
                          In other words, the direct sun light should get its own 'layer' to blend.
                          • 3 / 3
