    Soft Shadows
    extensions
    43 Posts 6 Posters 11.5k Views 6 Watching
      BTM
      Hmm... My post was a bit messed up. you were right about them being similar, I just flipped them vertically, and the latter (better) 2 images are messed up, and are showing the same one šŸ˜•
      i'll try to make some thinner lines (more detailed too). Might get them up soon, or have to wait 'till tomorrow.
      • Al HartA Offline
        Al Hart
        And you need to stop editing your posts after I have already started my reply.
        Al Hart
        IRender nXt from Render Plus
        • Al HartA Offline
          Al Hart
          Thanks - I'll give them a try - but it may take a day or two...
          Al Hart
            BTM
            Oh, and sorry, I have a habit of editing my posts after I post them 😳
            😳 , again.
            ... Newer cross-hatching textures
            Oh, and i don't know how well these will work, but I made tile-able thinner lines.
            1st
            2nd
            3rd
            4th
            This is slt3 turned on it's side, which could be the 5th layer if you wanted to go that far.
            Don't pay attention to the file names, they aren't in any order at all šŸ˜‰
            This is what sketchup looks like if they're all set as tiled masks at once, with black background and white fog.
              BTM
              ... Tomorrow I'll probably make another set, more of a straight-thin-pencil style though.
              • Al HartA Offline
                Al Hart
                Thanks for the pattern, BTM. I got the criss-cross shadows to work - the first pattern is used for the lighter parts of the shadow, and the second pattern is brought in for the darker parts (and overlayed over the first pattern).
                Also, I made these shadows red (someone had requested colored shadows, so I added a shadow color button) (I can't see that they are red. (Someone just told me that this model didn't look very good. Pay attention to the technology of the shadows, not the model or the final result. If someone has a small model which would be better for these examples, sent it to me.)
                Al Hart
                • Chris FullmerC Offline
                  I like it a lot on the house shadow that is cast on the ground. Any chance of seeing it with a regular grey shadow instead of the red? Its really looking great Al!
                  • Al HartA Offline
                    Al Hart
                    Good to hear from you again - this whole "soft shadow" think came from your idea of taking several (64 or so) images moving the sun around, and combining them to get softer shadows. As a result you will get a free copy of NprTools when it is delivered.
                    Send me a model you would like to see some soft shadows on, and I will run it through as a test case.
                    Al Hart
                      Oh I've been eagerly watching this thread Al. I think the soft shadows are coming along very well. I genereally prefer them with no hatching, but the criss-cross pattern on the last one is actually quite nice I think. I think it has to do with the density of the strokes. They are closer and tighter in that example than they have been in some of the others. I like that best.
                      Anyhow, its coming along really well. I'll find a model and PM it to you. Keep it up!
                      • Al HartA Offline
                        Al Hart
                        Thanks,
                        I'd like to try another model.
                        I'm getting tired of looking at this one.
                        There are a lot of settings here for density, color, transparency, pattern, blurring, etc. which you will be able to use when I get the Beta out.
                        Al Hart
                          BTM
                          Soft shadows could probably be good for indoor scenes (windows). Maybe you should make some indoor scenes, as well as outdoors.
                          • PixeroP Offline
                            Pixero
                            Wow, I'm really looking forward to this.
                            And colored shadows, yeees!
                            Question, does the line scale factor also go into less than 1 for getting even thinner lines?
                            • Al HartA Offline
                              Al Hart
                              Here is an interior scene:
                              Here is the result with soft shadows (no cross hatch)
                              Here is a result with cross-hatch. I don't think it worked well. I might try a light (rather than dark) hatch in the sunny area instead.
                              Here is a BW image with cross hatch.
                              Al Hart
                              • Al HartA Offline
                                Al Hart
                                The scale factor can be less than 1.
                                It scales the entire pattern, line and spaces between lines - not just the lines.
                                Al Hart
                                  kwistenbiebel
                                  Hi Al,
                                  Interesting experiments!
                                  I like the soft shadows in the first post a lot. A plugin that can output this effect as a .jpg would be great!
                                  • Al HartA Offline
                                    Al Hart
                                    Aha, this inverse image took some clever balancing and a trick ("leave shadows on, but set the sun intensity to 0 to get an image with the same lighting as the shadow image, but no sun"), but it turned out pretty well.
                                    I have added "Invert" as an option to SketchyShadows.
                                    I think Inverse mode worked better on the interior, then on the exterior. You would need less sun and more shadow for the exterior to work well.
                                    Al Hart
                                      BTM
                                      ... How many layers of cross-hatching do you think will be available, and will NPR Tools be available for macs?
                                      ... Also, just throwing this out there, but what would happen if you included cross-hatched shadows and sun?
                                      • Al HartA Offline
                                        Al Hart
                                        Probably 4 layers, but you will have to use a naming convention for the patterns (so I can select the first pattern - say Lines_1.jpg - and I can know that the other three are Lines_2.jpg, Lines_3.jpg, etc. - So I won't have to prompt for the names of all 4 pattern files)
                                        I hope to make a Mac version in time for the next "Design Visualization Center" conference. (as far as I now it is not scheduled yet).
                                        I will try to dual hatching - perhaps reversing the order or the patterns to so they won't just run together.
                                        Al Hart
                                        • Al HartA Offline
                                          Al Hart
                                          This is the first pass at double hatching - dark hatch in shadow area, light hatch in illuminated areas.
                                          There are a lot of options you can balance - cross hatch colors, cross hatch intensity, cross hatch size, cut-off between single hatching and criss-cross hatching - but this should give you an idea of what can be done.
                                          Note: the hatching here is based only on shadow intensity. If I can find a way to determine the z-depth of the image (How far each pixel is from the eye), then we could have the hatching pattern based on the distance from the eye as well - which is often very effective.
                                          Comments?
                                          Al Hart
                                            Ooh Al, I REALLY like where this is going. It sort of Gorey-esque (ok, not exactly, but perhaps in that vein).
                                            (www.spamula.net)
                                            (www.spamula.net)
                                            (sorry for the weird domain name on thos images, its nothing to do with spam. Its a literature website with some great Edward Gorey Images)
                                            With your input, this post could be even better šŸ’—
                                            • 2 / 3
