    Call to Mac users for script portability
    101 Posts 10 Posters 9.9k Views 10 Watching
    • fredo6F Offline
      Hi again, dear Mac users,
      If any of you can post a screenshot of a Default Parameter dialog box, it would help me to continue sorting out some of the issues. As far as I know, the little icon buttons still do not show their associated picture, and I need to check the question of Height dimensioning for table rows.
      Thanks in advance
      PS: I checked that I cannot do anything for the Color picker combo box. Background colors won't show up with Safari, due to the Mac implementation of the browser. At least the color name is shown!
      • jeff hammondJ Offline
        oops, i almost missed this post πŸ˜„
        here's a screenshot of the parameter dialog upon opening:
        i should also add that the colors now work for the wireframe and the various deformation boxes. i haven't tested the colors for the last few updates so i'm not sure exactly which version fixed it.. (i'm using 'e' now)
        as far as safari is concerned, i'm using a public beta for version 4.. i really don't know if that will affect anything but i'm letting you know just in case..
        • Bob JamesB Offline
          Bob James
          I can't seem to make "Slicing Active by Default" preference "stick".
          I went into preferences and marked the "Slicing Active by Default" box.
          Then I restarted SU7 (mac) and when I went to preferences the box was empty again.
          Comments?
          Checking the box
          After restarting SU7 (Mac)
            hey bob.
            i noticed that too.. some of the parameters are acting up now but they are still changeable..
            try clicking the box once so the check appears..click it again so it turns yellow then one more time so it's checked and yellow.. make sure to use the 'save changes' button..
            • fredo6F Offline
              Jeff,
              That works πŸ‘
              Thanks, now I can bend πŸ˜‰
              Interesting: I made a circle, pulled it into a column, then bent it over. I have no idea how the "windows" got in it, but it's sort of neat ❗
              Bob,
              Default parameters are really for configuration of the plugin and default behaviors. You normally don't need to go there frequently. If you change something in the dialog box, please make sure you do a SAVE.
              For Bend, use F4 (or contextual menu) for activating the slicer. The script will remember the settings thorughout the Sketchup session.
              For you example, do you mean it is not 'intentional'?
                Bob James
                Right. It was not intentional. I just drew a circle with the circle tool, pulled it up into a column, made it a group and bent it over. Much to my surprise it developed those neat "windows". Made me think of the Arch in St. Louis.
                  Bob James
                    Bob James
                    Jeff,
                    That works πŸ‘
                    • fredo6F Offline
                      New test concerning image buttons
                      Could any kind Mac user use the attach file and advise if the image buttons in the Default Parameter dialog boxes are displayed.
                      Also, please tell me if the cursor is transformed into a hand when mouse is moved over the buttons
                      Thanks in advance
                      to drop into LIBFREDO6_Dir_31 folder
                        Bob James
                        I don't see any image buttons nor any change in the cursor.
                        Is this the view you wanted to see?
                          bob, are you sure you're putting the new file in the right spot? it's supposed to replace a file by the same name located in the folder 'LIBFREDO6_Dir_31'..
                          the icons are there.. no hand though.
                          [edit] actually, only the factory icons are showing up.. the 'select all' check and 'clear all' X aren't showing up.
                            Bob James
                            Deleted it and re-installed it...
                              where's the newest update posted at?
                              • fredo6F Offline
                                Jeff, Bob,
                                This was just a trial on one button type, but it happens to work!
                                Could you try with with new update, which should hopefully show all button images.
                                • fredo6F Offline
                                  Jeff
                                  You've too quick. The Forum went down for me a few minutes. I was updating the update to also include a change for the 'Hand'.
                                    haha.. sorry.
                                    so the latest one is:
                                    no icons at all.
                                    the hand appears when hovering over the 'select all' and 'clear all' boxes but not with the factories.
                                    • fredo6F Offline
                                      I made a mistake. this one should be better, hopefully
                                      Thanks for the 'hand'
                                        BINGO!
                                        all icons are showing and working... the hand shows up when hovering over all icons..
                                        nice work fredo.
                                        everything else looks good too (size of the dialog box, title showing, cancel-reset-save buttons are visible, colors work, function keys work, etc.)
                                        as far as i can tell, it's fully mac ready.
                                        thanks so much!
                                          Bob James
                                          Ditto πŸ‘
                                          Sorry it took so long: My wife had some "other things" for me to do.
                                            driven
                                            Mac user returning to SU (haven't really use since @last stopped sending me free pro licenses... a while ago
                                            Trying to add all the things that use to drive me mad and putting them in the right place seems to be an issue, I'm having no joy getting this to work.
                                            It is on SU, the two buttons are there and dim when clicked, but there's no tool or functionality change.
                                            Can someone out there post a screenshot or video of a working setup.
                                            I have found some of the other scrips worked after moving bits downstream.
                                            cheers in advance
                                            This is where it's not working from on mine
                                            john (OSX 10.5.6 2.8 core2 duo + macbookPro,)
                                            • 4 / 6
