    Call to Mac users for script portability
    101 Posts 10 Posters 11.9k Views 10 Watching
    • fredo6F Offline
      Jeff,
      Thanks. This is related to the registry keys in Web Dialog which creates a bad problem on Mac.
      One other problem I have is about the small button images not showing. Would you mind to display the source code (via right click), store it in a txt file and post it. It may be related to the file path.
      Again thanks very much for your invaluable contribution.
      Fredo.
      • jeff hammondJ Offline
        Jeff,
        i can't view the source code on a web dialog such as this.. only on internet web pages etc.. the only option a right click will give me on your dialog is 'reload'
        i did just notice if i right click on one of the little boxes, i have an option to 'open image in new window' and if i select that, the icon pops up in a new window.. (factory icon, green check, red X )
        i don't have any of the OS X developer tools installed on my computers and if i did, i might have more options available to help you in this dept.
        any other way i might be able to view the source code?
        Fredo.
        oh man, it's nothing for me to help out.. i'm glad to do it and i'm glad you're getting things sorted for us mac users.
        • takesh hT Offline
          takesh h
          Would you mind to try another one, when you have time.
          Fredo,
          Thanks for the new version, Default Setting Window seems to be working normally now.
          But you left out Translation window... please fix translation windows as well when you have time.
          Jeff,
          I see what you mean.
          I talk to Goh a lot by emails, so I'll point him to this thread.
          With the information provided in this thread, it should be a matter of minutes for him to fix the issue.
            @takesh h said:
            Jeff,
            thank you.
            much appreciated!
            • fredo6F Offline
              Jeff,
              Don't bother with the source code any longer. Since you can see the pictures in a separate window, it means the file paths should be OK. It is probably a problem with the Safari browser.
              • fredo6F Offline
                @takesh h said:
                te]
                Fredo,
                Takeshi,
                I hope the attached file would improve the display for all web dialog boxes. On the remaining problem of small button pictures not displaying, can you tell me if there is any improvement.
                Thanks again
                to drop into LIBFREDO6_Dir_31 folder
                  gohch
                  hi Jeff, Takeshi,
                  I've included a toolbar manager function in the latest update (version 1.1.4)of 1001bit tools.
                  (now ready for download.)
                  You can use it to manage what to show and hide. You'll need to restart SU once for the settings to take effect, after that it remains persistent for future sessions.
                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=15927&p=148542#p148542
                  Please try it out 😄
                  cheers!
                  • I Offline
                    ideas_arte
                    Mr Fredo, sincere thanks, in fact their work has value for my very special ..!
                    Thank you very much to include people who use OSX ...!
                    • fredo6F Offline
                      Hi again, dear Mac users,
                      If any of you can post a screenshot of a Default Parameter dialog box, it would help me to continue sorting out some of the issues. As far as I know, the little icon buttons still do not show their associated picture, and I need to check the question of Height dimensioning for table rows.
                      Thanks in advance
                      PS: I checked that I cannot do anything for the Color picker combo box. Background colors won't show up with Safari, due to the Mac implementation of the browser. At least the color name is shown!
                        oops, i almost missed this post 😄
                        here's a screenshot of the parameter dialog upon opening:
                        i should also add that the colors now work for the wireframe and the various deformation boxes. i haven't tested the colors for the last few updates so i'm not sure exactly which version fixed it.. (i'm using 'e' now)
                        as far as safari is concerned, i'm using a public beta for version 4.. i really don't know if that will affect anything but i'm letting you know just in case..
                        • Bob JamesB Offline
                          Bob James
                          I can't seem to make "Slicing Active by Default" preference "stick".
                          I went into preferences and marked the "Slicing Active by Default" box.
                          Then I restarted SU7 (mac) and when I went to preferences the box was empty again.
                          Comments?
                          Checking the box
                          After restarting SU7 (Mac)
                            hey bob.
                            i noticed that too.. some of the parameters are acting up now but they are still changeable..
                            try clicking the box once so the check appears..click it again so it turns yellow then one more time so it's checked and yellow.. make sure to use the 'save changes' button..
                            • fredo6F Offline
                              Jeff,
                              That works 👍
                              Thanks, now I can bend 😉
                              Interesting: I made a circle, pulled it into a column, then bent it over. I have no idea how the "windows" got in it, but it's sort of neat ❗
                              Bob,
                              Default parameters are really for configuration of the plugin and default behaviors. You normally don't need to go there frequently. If you change something in the dialog box, please make sure you do a SAVE.
                              For Bend, use F4 (or contextual menu) for activating the slicer. The script will remember the settings thorughout the Sketchup session.
                              For you example, do you mean it is not 'intentional'?
                                Bob James
                                Right. It was not intentional. I just drew a circle with the circle tool, pulled it up into a column, made it a group and bent it over. Much to my surprise it developed those neat "windows". Made me think of the Arch in St. Louis.
                                  Bob James
                                    Bob James
                                    Jeff,
                                    That works 👍
                                    • fredo6F Offline
                                      New test concerning image buttons
                                      Could any kind Mac user use the attach file and advise if the image buttons in the Default Parameter dialog boxes are displayed.
                                      Also, please tell me if the cursor is transformed into a hand when mouse is moved over the buttons
                                      Thanks in advance
                                        Bob James
                                        I don't see any image buttons nor any change in the cursor.
                                        Is this the view you wanted to see?
                                          bob, are you sure you're putting the new file in the right spot? it's supposed to replace a file by the same name located in the folder 'LIBFREDO6_Dir_31'..
                                          the icons are there.. no hand though.
                                          [edit] actually, only the factory icons are showing up.. the 'select all' check and 'clear all' X aren't showing up.
                                            Bob James
                                            Deleted it and re-installed it...
                                            • 3 / 6
