    Molding Profiles
    75 Posts 51 Posters 90.9k Views 51 Watching
      rcossoli
      exellent, thanks!!!!
      THREEDIMENSIONSWEB dot COM
      • B
        brandy20
        downloaded now!very nice job!! ๐Ÿ‘
          devincig
          Great ! It is useful for me! Than u very much !
          http://www.flickr.com/photos/8839214@N03/
            Ruturaj
            hey Ron
            its great collection.
            Thank you yaar!
            Thanks,
            RuturaJ
            • X
              xrok1
              Very generous! ๐Ÿ˜›
              โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                archmolding
                Unbelivable. Thank you so MUCH I only use SU to draw my molding and Millwork designs...Thank you!!!!!
                http://www.archmolding.net
                • L
                  lucifer1101
                  can i ask what for and how these are used in sketchup...
                  im still kinda new and just trying to get up to speed with sketchup....
                  Some of my 3d
                  • X
                    xrok1
                    use them with push/pull to build baseboards, frames ...
                    • L
                      lucifer1101
                      o i see now, how do i import them into sketchup, or do i use them as a reference to remake them in sketchup...
                      Some of my 3d
                      • X
                        xrok1
                        if you look inside the .zip files, they are already sketchup files. try it.
                        • L
                          lucifer1101
                          ok thanks heaps...
                          and thankyou for the moulds ron they should come in handy....
                          Some of my 3d
                          • W
                            woodtogo
                            Thanks for the great moldings very useful. One question though. If I want to measure the radius of any of the moldings, how would I go about that. I have tried and cannot get a radii measurement. Thanks
                            Ray
                              woodtogo, since all of the edges of the profiles have been welded together, the curves are no longer arcs so there's no radii to measure. You could use the yellow Tape Measure tool and guidelines to work out the radius of the various curves if you need them. You could also trace the arc portions of the molding profile and create arcs you can dimension.
                              • boofredlayB
                                boofredlay
                                Ray, I use Chris Fullmer's Exploded Arc Centerpoint Finder plugin all the time. It works great.
                                Of course you would have to explode the arc so you can select two lines but then you could just weld them together again.
                                http://forums.sketchucation.com/viewtopic.php?p=155504#p155504
                                  Sergio Morera
                                  Thank you Ron for this excellent library. Absolutely amazing ๐Ÿ˜
                                  • B
                                    bantymom
                                    You have made me all happy with this, but now I have a question. If I find a profile that works perfectly in the remodel I'm doing, do I then need to take it to a place that does custom millwork and have new knives made? or did these all come from one place that I could go to and order moulding? I saw that Forrester was mentioned in the initial post. Does anyone know if the profiles came from the mouldings supplied by that company?
                                    With many thanks,
                                    Banty
                                    (Old girl trying to learn new tricks)
                                    • T
                                      tolmandesign
                                      Thanks, Ron!!! Very helpful. ๐Ÿ‘
                                      • Chris FullmerC
                                        Hey Ron, good to see you here. Looks its been 2.5 years since you last posted. Wow time flies.
                                        • boofredlayB
                                          boofredlay
                                          He lives!
                                          • Chris FullmerC
                                            Wow, just this one thread has a few people that are missed around here.
                                            rhankc - 300+ posts - hasn't posted in almost a year.
                                            Juju - 1100+ posts - has not posted in nearly a year
                                            PKast - over 100 posts, has only posted 2 times this year
                                            Firkins - 70+ posts, has not posted for 2.5 years also.
                                            I guess people sort of come and go. Perhaps they <shutter at the thought> have real lives outside of SketchUp? ๐Ÿ˜„ Anyhow, it was good to see you around. I hope is well with work and with your spine - that is a generally useful thing to keep in good working order.
                                            • 3 / 4
