    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 417.4k Views 154 Watching
      what is the outliner?
      Menu Window/ Outliner = Arborescence system of the objects 😄
        AcesHigh
        well, certainly I dont need to close it, since i NEVER opened it! 😆
          jim_tim
          Thanks for the replies, but i'm afraid the outliner is not the problem. I only opened the outliner in the first place because i was getting bug splats. I used the outliner as a quick way to get rid of things i thought might be slowing the model down or causing bug splats. I'd be grateful if anybody could try to resolve the problem in the model i attached earlier in the thread. I think zorro2 could be an amazing tool but i just keep getting bug splats constantly 👎
            dylan
            Are you getting the bugsplat just with Zorro2 or with other rubies also?
            http://dmdarchitecture.co.uk/
              rv1974
              Dale I noticed I always have to reverse section cut before "slice model at section".
              May be alternatively you could "inverse" this tool?
                putnik
                Whaat, I've got 2 files. The first one is the original, its geometry is a result of a simple Follow Me. The second one is a derivative of the first, with some bits manually cut out. The latter Bug Splats almost every time I try to Zorro it up. The former lets me slice it any which way I want, every time. I'm on WinXP SP3, SU7. Do you mind checking it out? TIA
                both SKPs are in the archive
                http://keshas.info
                  putnik
                  I take it it's unresolvable?
                  http://keshas.info
                    For me "Bugsplats" arrives also 😮
                    But maybe it's not a good idea to make a zorro2 on surfaces?
                    • W Offline
                      Whaat
                      I really don't know what the problem is. Zorro sometimes just causes random bugsplats. I see no reason that it would work for the first file but not for the second. Ruby plugins are more prone to bugsplats than using straight SketchUp for various reasons. I believe that SketchUp has its own internal entity observers that are probably the culprit.
                        putnik
                        Whaat, I see. Thanks for looking into it. I've remodelled the shape slightly using different path, deleted the middle bits, and now it doesn't bugsplat as often. Go figure 😕
                        Pilou, you mean as opposed to cutting groups & components? Maybe. I'll try, but I would have thought slicing groups would be a more complex task than modifying faces directly
                        http://keshas.info
                          seanseansesan
                          Thanks a lot fotr this amazing plugin , but how d you install?
                          • Chris FullmerC Offline
                            Download it from the first post in this topic. Save it to C:\Program Files\Google\SketchUp7\Plugins folder. (thats an approximate guess of the exact path, and it might be different on your computer. But just put it in your "Plugins" folder inside your SketchUp installation folder).
                            Then it will be installed in SketchUp the next time you run SketchUp.
                            And welcome to the forum!
                              drewskiey
                              I am a novice to this topic and a mac user, so please bare with me... 😉
                              I saved the file "thumbs.db" (not ".rb"?) into the plugins folder and nothing happened.
                              I then changed the file to "thumbs.rb" and when i opened SU I received the error "Invalid char `\021' in expression".
                              what should i change?
                                Hi drew, delete that thumbs.rb file. Thats not the right one. I'm not quite sure where you got the thumbs file from.
                                In the first post of this topic there is a file called zorro.rb. That is the file you want to copy to your plugins folder. So delete the thumbs.db and put the zorro.rb file into plugins, and then start SketchUp and you should be good to go,
                                • E Offline
                                  emibgc
                                  tanx a lot man...
                                    phmeier
                                    is it too late to coment ? hope not lol !! Well im donwloading that and i really think this is fantastic ..
                                    I enjoy doing this kind of work :
                                    http://i65.photobucket.com/albums/h233/jullysixx/plantaperspectivafundoneutro.png
                                    And with this plugin i think i have some new things to try ,,,
                                    • H Offline
                                      hetneo2
                                      was wondering if some one could direct me to a location where i can get the zorro2 plugin from, cos all the forum links are blocked from my end
                                        It's attached to the very first post in this topic (go back to page 1 in the topic). If you have permission problems accessing the attachment, it's probably a browser cookie issue and please, follow the steps I sent you answering your email.
                                          talkingglue
                                          HI all,
                                          I have been having quite alot of difficulty getting access to the Zorro plug-in on this site. I have successfully registered and logged in but i keep on getting messages saying i do not have permissions to view the files in the post. If anyone could help i would be over the moon with gratitude and content!
                                          Muchos gracias,
                                          Ronan
                                          Mac OSX 10.6/Safari 4/2.2Ghz/2GB RAM
                                            Hi Ronan,
                                            Have a look at this announcement and if you seem to have login issues, delete your cookies from your browser.
                                            http://forums.sketchucation.com/viewtopic.php?f=180&t=19797
                                            Ah yeah - and welcome to SCF.
                                            • 15
                                            • 16
                                            • 5 / 16
