    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 412.4k Views 154 Watching
      Make sure the Outliner is closed. Making scripted changes to groups/instances with the Outliner open can give a BugSplat...
        AcesHigh
        what is the outliner? 😳
        Ive had bug splats even after exploding all components and groups into faces.
        basically it were lots of window panes, around a building of circular size. The roof of the building was inclined, so I needed to cut all the windows so they would fit against the inclined roof.
        Some of the windows would cut nice. But then, a FEW OF THEM, for no aparent reason, would give bug splats, even if I moved them, copied them and tried to cut somewhere else, if I rotated them, etc.
        I ended up cutting them using tools on surface... but needless to say, it took a much longer time. Zorro was the perfect tool for the job, if there were no bug splats. 😐
          Menu Window/ Outliner = Arborescence system of the objects 😄
            AcesHigh
            well, certainly I dont need to close it, since i NEVER opened it! 😆
              jim_tim
              Thanks for the replies, but i'm afraid the outliner is not the problem. I only opened the outliner in the first place because i was getting bug splats. I used the outliner as a quick way to get rid of things i thought might be slowing the model down or causing bug splats. I'd be grateful if anybody could try to resolve the problem in the model i attached earlier in the thread. I think zorro2 could be an amazing tool but i just keep getting bug splats constantly 👎
                dylan
                Are you getting the bugsplat just with Zorro2 or with other rubies also?
                http://dmdarchitecture.co.uk/
                  rv1974
                  Dale I noticed I always have to reverse section cut before "slice model at section".
                  May be alternatively you could "inverse" this tool?
                    putnik
                    Whaat, I've got 2 files. The first one is the original, its geometry is a result of a simple Follow Me. The second one is a derivative of the first, with some bits manually cut out. The latter Bug Splats almost every time I try to Zorro it up. The former lets me slice it any which way I want, every time. I'm on WinXP SP3, SU7. Do you mind checking it out? TIA
                    both SKPs are in the archive
                    http://keshas.info
                      putnik
                      I take it it's unresolvable?
                      http://keshas.info
                        For me "Bugsplats" arrives also 😮
                        But maybe it's not a good idea to make a zorro2 on surfaces?
                        • W Offline
                          Whaat
                          I really don't know what the problem is. Zorro sometimes just causes random bugsplats. I see no reason that it would work for the first file but not for the second. Ruby plugins are more prone to bugsplats than using straight SketchUp for various reasons. I believe that SketchUp has its own internal entity observers that are probably the culprit.
                            putnik
                            Whaat, I see. Thanks for looking into it. I've remodelled the shape slightly using different path, deleted the middle bits, and now it doesn't bugsplat as often. Go figure 😕
                            Pilou, you mean as opposed to cutting groups & components? Maybe. I'll try, but I would have thought slicing groups would be a more complex task than modifying faces directly
                            http://keshas.info
                              seanseansesan
                              Thanks a lot fotr this amazing plugin , but how d you install?
                              • Chris FullmerC Offline
                                Download it from the first post in this topic. Save it to C:\Program Files\Google\SketchUp7\Plugins folder. (thats an approximate guess of the exact path, and it might be different on your computer. But just put it in your "Plugins" folder inside your SketchUp installation folder).
                                Then it will be installed in SketchUp the next time you run SketchUp.
                                And welcome to the forum!
                                  drewskiey
                                  I am a novice to this topic and a mac user, so please bare with me... 😉
                                  I saved the file "thumbs.db" (not ".rb"?) into the plugins folder and nothing happened.
                                  I then changed the file to "thumbs.rb" and when i opened SU I received the error "Invalid char `\021' in expression".
                                  what should i change?
                                    Hi drew, delete that thumbs.rb file. Thats not the right one. I'm not quite sure where you got the thumbs file from.
                                    In the first post of this topic there is a file called zorro.rb. That is the file you want to copy to your plugins folder. So delete the thumbs.db and put the zorro.rb file into plugins, and then start SketchUp and you should be good to go,
                                    • E Offline
                                      emibgc
                                      tanx a lot man...
                                        phmeier
                                        is it too late to coment ? hope not lol !! Well im donwloading that and i really think this is fantastic ..
                                        I enjoy doing this kind of work :
                                        http://i65.photobucket.com/albums/h233/jullysixx/plantaperspectivafundoneutro.png
                                        And with this plugin i think i have some new things to try ,,,
                                        • H Offline
                                          hetneo2
                                          was wondering if some one could direct me to a location where i can get the zorro2 plugin from, cos all the forum links are blocked from my end
                                            It's attached to the very first post in this topic (go back to page 1 in the topic). If you have permission problems accessing the attachment, it's probably a browser cookie issue and please, follow the steps I sent you answering your email.
                                            • 15
                                            • 16
                                            • 5 / 16
