    Leg for chair
    26 Posts 8 Posters 3.1k Views 8 Watching
    • G
      GLB
      Yes, seems interesting, I'll try and let you know the result, thanks
      • G
        GLB
        I did try the TapeMaker plugin, but couldn't find the way how to use my own profile for such leg ? If I use the ready made shapes, then how can I make the edges in fan shapes. Per attached the profile of leg I want to use. Thanks for your comments
          I think I could draw something like that. I'll do up a tutorial and post it.
          • boofredlayB
            boofredlay
            Ok GLB, I made a tutorial here:
            http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=18573
            Hope it helps.
            (Beat you Dave 😄 )
              Nevermind.
              Good work Eric.
              • X
                xrok1
                push\pull your shape, scale one end, then use shapebender; viola!
                • X
                  xrok1
                  • boofredlayB
                    boofredlay
                    What does the mesh look like?
                    • X
                      xrok1
                        Xrok's method is the method I was going to show. Works slick.
                        • boofredlayB
                          boofredlay
                          Yep, that works great as well. I just wonder about how much control you have if it needs to be precise.
                          I guess I am just a traditionalist 😄
                            If you place the line and curve properly, I think this would be an accurate method. It's certainly fast.
                            • X
                              xrok1
                              yes, i think any method is as accurate as you care to make it. (unless you can create a random curve 😆 )
                              • G
                                GLB
                                Many thanks to all of you, especially Eric with his great and clear tutorial.
                                I do think that shape bender is the quickest solution but it seems that I have some problem with such plugin because cannot get any final result, maybe there's a bug ?
                                So, I'll go back to work now and try to finalize such leg !
                                • Chris FullmerC
                                  There definitly bugs in the script, but they shouldn't keep it from working. I can you figure out whats wrong with it if you want,
                                  • W
                                    watkins
                                    Further to another thread, perhaps someone (David?) could make a tutorial showing how shape bender may be used to make the complex shape of the chair leg.
                                    Regards,
                                    Bob
                                      Dear Bob,
                                      Were you referring to me? Would something like this work?
                                      Cheers,
                                      Dave
                                      • W
                                        watkins
                                        Dear David,
                                        Exactly! As I said in another thread (http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=18210&st=0&sk=t&sd=a&start=120#p151205), Shape Bender is almost a loft tool, and so the more examples we have of its use the better.
                                        Kind regards,
                                        Bob
                                        Now, I had better go look at that video tutorial, hadn't I.
                                        • G
                                          GLB
                                          Hi Chris,
                                          Thanks again for your help, for the time being it seems to work quite without any problem except maybe it's not that fast but I really need to "clean" my labtop first.
                                          • Chris FullmerC
                                            ok, good. Glad its working. I'll be the first to admit its no perfect, but I'm glad some of you folks are finding ways to put it to use. I've got some ideas how to speed up certain things it does, but I won't be getting to that for a a month or two I'm sure.
                                            Thats a great tutorial Dave. I noticed that the preview geometry didn't show up like it was supposed to - soory! Sometimes it does that when the group to bend is lined up exactly on the line. But its only sometimes it freaks out and I have not been able to figure out why or when so I can't fix it. Oh well! I'll get it later. You explained it nicely that you mostly just need the start and end to correspond and hit enter and it still bends, just without a preview first. Looks great,
